Question about Soltek SL-915G Pro-FGR Motherboard
Won't run POST
If the machine won't run a POST is it an indication of throuble with the motherboard or processor ? Debug led shows FF.
    Genius:
  • 1,067 Answers
Mobo battery is batery in video card try pci differt video 1 pice ram or the other power grounded well with all screws
Posted on Jan 17, 2008
Help my dell is not displaying but the front led is showing the power light on CPU but is not displaying on the monitor and i have used working RAM on the Computer but the problem is the same, kindly help...
If you do not hear a post beep sound, then you may have an issue with the motherboard and/or processor. I suggest you either take it in for repair or replace yourself
If you hear the post beep sound, then listen for the sequence of beeps. This should indicate what is wrong with the machine. Generally(Note: these may be different with motherboard and/or bios type).
  • sequential long beeps indicate RAM issues
  • 1 long followed by two short indicate a display adapter issue
Mar 23, 2015 | Dell (E210882) Motherboard
ASUS Motherboard M4A88T-V EVO/USB3 won't post
Specs say it is a dual channel platform for the memory slots. It requires two DIMMs to take advantage of this, but you would have double check the manual if it will run with a single DIMM.
Feb 04, 2013 | ASUS Computers & Internet
Have a E-Machine that keep displaying in powersave mode
eMachines are a budget computer.
Designed to save the consumer money.
One of the items used that cost is saved on, is the Power Supply.
Power Supply is generic, and of low quality.
1) Low quality Electrolytic Capacitors
2) Low quality Power MOSFETs
3) Low quality Rectifier Bridge
4) Too small a gauge of wiring is used
Plus most consumers do not keep the inside of the computer clean, and if they do the Power Supply is usually neglected.
The two leading causes of desktop computer failure; the computer is dirty inside, and/or the Power Supply is bad.
With a weak voltage power rail you may see LED's light, and maybe fans spin, but there won't be enough power to turn the Processor on.
[No Processor operating, no computer. No computer = no video signal to the monitor. No Signal, Power Saver Mode, or Sleep Mode is indicated ]
1) If ALL of the LED's were lit up they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
See if there is an unused working computer that has a KNOWN to be good, Compatible power supply; that you can use for a test unit.
Or use a multimeter to test the three main voltages, coming out of the Power Supply
3.3 Volts (DC) [ Orange wires ]
5 Volts (DC) [ Red wires ]
12 Volts (DC) [ Yellow wires ]
[ALL Black wires are Ground wires ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 16, 2012 | E-Machines Computers & Internet
Intel D945GCNL has no display though ram, hard disk,power supply, processor is fine
Okay.
Provided you have checked out the simple stuff; monitor, AND monitor cable, suggestion would be to install a graphics card, and connect the monitor to it.
You won't have THE drivers for the graphics card installed yet, as you have no display, but you should get a display you can see well enough, to install the drivers.
I do need to ask a few questions before this is done, however.
1) Do you know the Power Supply is good?
Your LED lights may light, fans may spin, and it may sound like the harddrive is spinning, but the Processor may not be on.
Why?
A) IF, all of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
{ The Intel D945GCNL mobo has an LGA 775 processor socket.
Front Side Bus support is 800MegaHertz.
The motherboard chipset is an Intel 945GC (Part number 82945GC)
Can use up to an Intel Core2 Duo processor, with a 800MHz FSB.
These processors can use up to 65 Watts.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_chipsets
I'll go with the chipset info, and not the stated 1066MHz support,
http://www.overstock.com/Electronics/Intel-Essential-D945GCNL-Desktop-Motherboard-Intel-945GC-Express-Ch-Refurbished/6113423/product.html
Stated facts from Intel,
http://www.intel.com/support/motherboards/desktop/d945gcnl/sb/CS-026727.htm }
2) How do you know the;
A) Processor
B) Harddrive
C) Ram Memory
D) Power Supply
,is fine?
Connected them/it to another working motherboard? Won't work with the harddrive, unless Windows Activation screen comes up, and then the harddrive will be for THAT motherboard, and not the original one.
Post back in a Comment.
Regards,
joecoolvette
May 21, 2012 | Intel D945GCNL Motherboard
I flashed the bios on my Asus motherboard M2N-E, and then replaced the processor with a quad. Cleared the cmos and now the computer won't post? What do I need to do to get it up and running again?
Try to put back the old procie, if it runs again that means the new procie is not compatible with board.
Read the manual for the compatibilty issue for your MoBo.
Tell me if it works.
Nov 17, 2011 | ASUS M2N-E SLi Motherboard
When I start up the Acer Aspire M3710 Desktop it won't do anything but run the processor, it won't give any results of the POST and it also refuses to show anything on my screen (no Signal)....
1. Check the video cable (the one going from the monitor to the video card) 2. Check if the video card is properly connected to the motherboard (must be tightly plugged into the port)3.This could also mean that the drivers for the video card are not correctly installed
Jun 13, 2011 | Computers & Internet
JetWay J939GT4-SLI-G always showing "FF"
Try disconnecting all power connectors to the hard drives and CD-Rom drivesin the system. Leave only the motherboard connectors and the video card connector if there is one. Re-seat your RAM and then try. If it boots up, the power supply is being overloaded and it will not power on the PC.
Sep 27, 2009 | Computers & Internet
EliteGroup ECS AMD690GM-M2
get a debug card, put in the pci slot, put the processor, memory, hdd keyb, mouse on the place, double check it..turn on the power , read the last post code that display...watch for the blink of the 3 keyb lamp during power on...if there is no blink..then your o/b vga not initialized by the bios and (maybe) reading the other exp slot.
if there is a blink then check your monitor and cabling..record the last post code that display on the debug card (POST code display card), shutdown then remove all your device except for processor,ram,debug card , vga(if any external)...turn on the power again..did the post code is different or its the same with the last time?
shutdown,remove the ram, and vga (if any ext vga)..power up again (with only debug card and proc) did the code display the same or no ?
remove the proc and still with the debug card inserted in the slot..power up...what in the display?same?
you should be able to diagnose that..may be the proc (code 00 C0 C1 C2 ), may be the ram...maybe your o/b vga was dead..maybe your bios rom was still have bug (ECS ??=>does have a 2-3 years waranty..am i right?)
UDIN (indonesia)
Jun 13, 2008 | EliteGroup ECS AMD690GM-M2 Socket AM2...
Soltek SL-865PRO2-FGR Motherboard Problem:
Generally an FF code means either a dead board or a dead motherboard... =/
Although you may not have changed anything, motherboards can die for the strangest of reasons, and in my personal experience, this is what this means.
Nov 07, 2007 | Soltek SL-865PRO2-FGR Motherboard
Soltek SL-915G Pro-FGR Motherboard Logo
232 people viewed this question
Top Soltek Computers & Internet Experts
clar4444
Level 1 Expert
David
David
Paul Bade
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
