Question about Krups GVX2-12 Electric Burr Grinder
Won't Grind without shaking it!
My Coffee grinder barely grinds any beans unless I continuously shake it. At first it only needed a every once in a while, but now I have to keep on shaking it, otherwise no beans will be ground.
  • Anonymous Dec 28, 2008
    I have the same problem, and the thing is new out of the box, used twice. Both times, same problem. What a piece of junk.
    Scholar:
  • 67 Answers
Sound like it's choked up with grounds and oil. Burrs may also be blunt. U need to dismantle and clean/ check burrs, passages and body. If you can see "flats" on the burrs or they feel not sharp when you check with finger, they should be replaced.
Posted on Jan 24, 2008
Just bought a mazzer super jolly grinder, used it once, the grind was too coarse (#6), adjusted it to a finer grind ((3), and the next time i ran it it stopped grinding, the motor is on, the grinder turns,...
yes, you have to remove the beans inside because there is beans stuck between the burrs. after removing the beans, start doing the finest first before loading the hopper then after putting the beans test the grind as you go courser.
Feb 11, 2012 | Mazzer Coffee-grinder SUPER JOLLY Electric
Hi, The machine is trying to grind beans then states that there are no beans, yet the bean holder is full. We have dismantled the holder and cleaned out the grinder block, it worked once or twice then...
IT could be that the grind is too fine and the grinder is being clogged with coffee, first try adjusting to a coarser grind at least 2 to 3 numbers, if coffee flows into the brew unit you are good to go if not, then grind chamber needs to be vac out and cleaned then adjust grind and start over.
Apr 13, 2011 | Gaggia Titanium Espresso Machine
When grinding coffee beans the grinder is not dropping the beans into the grinder part. I have to stay and shake or bang the grinder on counter to get the beans to fall through.
you must screw off the burr holder plate screw (in center) you will order one special screw, drill shaped, when the burrs roll it will mix and take down the coffee beans. That is solution i applied to many grinders. PS: beware the direction of burrs must be coordinated with new screw.
Feb 07, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
Grinder stalls constantly (motor whirring, but no grinding happening) so I shake it to get it grinding again, but the whirring/no grinding happens over and over. I have to shake the think 5 or 6 times to...
As I can see, what happens is that some coffee grains stucks in the way from the upper pot to the grinding wheel. This is not something usual, but possible if coffee grains are too big and are placed across the entry of the mill. Try cleaning more deep with some old toothbrush. Look for a clean and even surface of the duct.
Other cause might be a loosen mill hub/grinding wheel off the motor shaft, which would require dissassemble of the appliance to be repaired.
Dec 10, 2010 | Krups Burr Coffee Grinder
I have the CCM-16A grinder that gets clogged while grinding. I have to shake it so the beans keep going thru to grind. How can I clean it?
Chris, unplug the machine. The the coffee receptacle out and clean out the discharge opening with a small brush. The coffee sticks to this opening and causes the machine to stop. Its a safety feature to stop the machine when the receptacle is full. Good luck.
Feb 17, 2010 | Cuisinart Supreme Grind CCM-16PC Grinder
All of sudden my grinder plugs up. coffee settles in around the base of the burr and does not seem to fall into the grind bucket, so the machine still runs but grinding basically stops as no more more...
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Nov 03, 2009 | Solis Maestro Electric Burr Grinder
Hello. grinder won't grind
HI
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. This will be above where the brew unit was. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
Jul 24, 2009 | Gaggia Syncrony Espresso Machine
Grinder starts up but wont grind..nothing happens. one week old
I think this might be because no beans have gone down into the mill. There is a definite difference in sound when it is actually grinding beans. Try emptying the beans out, set it to the coarsest setting, put the beans back in, shake the thing a bit then turn it on.
Jan 17, 2009 | Krups Burr Coffee Grinder
Ground coffee Saeco Royal
Hi
thedalys. you probably have a bad micro switch on your doser. and that just needs to be replaced. If the grinder does not sense that the doser box is full it will keep grinding until it times out.
Guest. Try pulling the dosage lever back one click from the full and push your grind lever to the largest # and see if that helps. Sounds like you grinds are too fine and its clogging the the grind box. If the dosage level is too full it will cycle and dump the brew unit or break the brew drive gears, then you will hear a clicking noise when it trys to make a coffee.
Dec 12, 2008 | Saeco Royal Digital Plus Coffee...
Krups GVX2-12 Electric Burr... Problem:
First, unlock and unscrew the upper burr carrier. Clean and check the upper burr by gently running your finger over the teeth in the cutting direction. It shoild feel moderately sharp. If it feels very blunt, look at the teeth under a good light. If you see a substantial "flat spot" at the top of the teeth, probably the burr set will need replacement.
For the bottom burr, clean carefully its teeth, and the entire area in which it is housed. Include the outlet orofice as well. You may find a lot of oily deposits within here, so just clean them off as best as possible.
When all is clean, insert the top burr holder back in place. Screw it down until both burrs touch, then back it off (say) 1/4 turn, and lock.
Put some beans in the top, and switch on. Adjust the top burr until the desired grind is obtained.
The ground coffee should feel like a coarse sand when close to the desired grind size.
Mar 13, 2008 | Krups GVX2-12 Electric Burr Grinder
Krups GVX2-12 Electric Burr Grinder Logo
708 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
