Home theater ground loop problem
Any suggestions on how to take care of this one? My home theater setup has a mean ground loop hum.
  • sy2k Jan 24, 2009
    Thanks to the both of you. That usually does do the trick, however by taking away that ground, you've essentially created an electrical fire hazard! Great. The kit you ran into may have addressed this? I have no idea.
    Starting to think you have to upgrade the electrical wiring where you reside. Which is kinda hard in an apartment! Fact is the grounding in most American homes is ****.
Ran into this problem myself in two different homes. Went to A/V store where they install high end equipment, they explained its a problem with the way the AMP for the **** kicker and the amp in my subwoofer, and a/v processor are all plugged into the same electrical circuit in the house. They tried to sell me a $35 ground loop eliminator kit. Didn't go for the kit after looking at it, I came up with a solution that cost me $.39 cents. Thats right 39 cents. Go to Home Depot, Lowes, Ace Hardware and ask for a plug adaptor (they usually come in grey but you can shop around to find other colors). They are sold for older homes that dont have ground fault plugs only the two prong outlets. Plug your Subwoofer or your AMP into the adaptor then plug it in. All the humming and feedback noise will be a distant memory.
Posted on Jan 23, 2009
    Scholar:
  • 70 Answers
Boy you must have a mess. We will start process of elimination. Make sure power cords are out of the wall at first. First plug the preamp into the duplex then plug the amplifier into the wall. Connect the speakers then connect the wires between the preamp and amplifier. All should be well. If buzzing countinues, you need to find a ground adapter. This is a small device that on the female side has 3 prongs and the male said 2 female redeptor. If your using a AC strip plug put the adapter on and then plug in wall...
Well pick it up in the next chapter if nothing works here...
Jeff S
Posted on Jan 17, 2008
How to install grounded turntable to bose lifestyle without a hum
Try disconnecting the ground to see if the problem goes away. There may be a ground loop created by connecting the devices.
Oct 23, 2014 | Bose Audio Players & Recorders
I have extreem amount of noise between my tascam 2488 to computer based recording program , how can I delete the noise ?
What kind of noise is it? If it is hum or buzz, then you probably have a ground loop. If it is hiss, then you are picking up noise in the cable, most likely. For ground loops, see: http://www.audioholics.com/home-theater-connection/ground-loops-eliminating-system-hum-and-buzz
As for the cable, the cheap ones with the red and gray plastic ,olded ends can get noisy after awhile as the shielding is rather fragile. Cracling type noises are usually cable related as well.
Jul 30, 2014 | Tascam 2488 Portastudio Multitrack...
Subwoofer is hummig what is this noise
Hum is a constant low-frequency buzz, usually at about 60 Hz or 120 Hz, which results from voltage differences between true "ground" (what you'd get shoving a copper pipe into the ground) and the electrical "ground" of your receiver's chassis When this voltage differential exists, it's called a "ground loop," and the hum it produces is darned annoying. You'll hear the hum mainly from the subwoofer because it's a low-frequency noise, you will need a ground loop insulator they are about $20 at any electronic store
Dec 28, 2013 | Vizio 2.1 ch. Sound Bar with Wireless...
Radio interference in high voltage system
You mean, Ground loop humming, popping, buzzing in your speakers? Bypass the ground plug on your equipment and seperate the power cables from the audio cables.
Feb 23, 2011 | Audio Players & Recorders
My home theater speakers make a constant hum whenever my receiver is on. The loudness of the hum changes with the volume control, and goes away entirely when the system is muted. All components are plugged...
jd40,
Sounds like a grounding issue. The first two places to look into is the powered subwoofer and antenna. During your last test, did you leave the FM antenna and subwoofer connected? Many times the hum is directly related to the antenna and/or the subwoofer and to how they are grounded; creating a ground loop through the receivers ground on the outlet. If the antenna is grounded to the dwellings wiring, hum is inevitable and sometime you can get a ground loop hum from how or how & where the subwoofer is grounded. Try taking them completely out of the loop.
Also try taking it further back to the basics, start with the receiver plugged into a known good grounded outlet with no surge or line conditioner in the loop and nothing connected to the receiver, nothing. Use one speaker and different wire to test each speaker output while in tuner and any other mode but phono. With no signal, you will either get nothing (no hum or static) or just static in the tuner mode. No hum is a good sign. Some systems will mute the speakers if no signal is connected to eliminate the static from being produced through the speakers but a ground loop hum will most likely still be produced even in mute. If you get a hum when nothing is connected to the receiver, try looking into getting a better grounded outlet, even maybe to a different dwelling.
-Chris
Jan 30, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Humming sound coming from subwoofer what is that?
Sounds like a ground loop to me. Try throwing a ground lift (adapter that goes from 3 prongs to 2) on your sub's IEC cable. Hope this helps!
Dec 19, 2009 | KEF Audio KIT100 System
Humming/buzzing in aftermarket stereo when accelerating vehicle.
i once installed spark plug resistors (arrestors) that are supposed to help
Nov 06, 2009 | RCA Pac Sni1 Rca Ground Loop Noise...
When I hook the system up. I an hear a humming or buzzing like noise in teh system
This is the bane of all home theater installations and its called the "60 Hertz Hum" Most likely coming from your cable company.. Simple test... Disconnect any Coax cables from the outside going into your cable box or tv. Hum disappears. Most likely this is caused by a "ground loop" problem.
The solutions are far and varied. Google "ground loop hum" to find different things to try
Aug 14, 2009 | Philips HTS 6600/12 Home Theatre...
I have a Stanton T.80 and Vestax VMC-185XL mixer. I recently bought Rane Serato Scratch Live which requires the turntables to be grounded through the mixer...however, the turntable doesnt have a ground...
Hi gium
Sounds like we have reached that point where progressive crossover in technologies means that the usual cautions of earth continuity for the tone arm when using a phono preamp has gone the same way as phono preamps on home theatre.
Have you tried switching to the line level and set the mixer up for that level also. That may reduce any gain induced hum. However it sounds like an earth loop problem, where both decks will need to be earthed in the mixer. Check also that all the gear is running of the same power point. Different mains phases are sometimes available near each other, having any gear (power amps also) on a different phase will cause an earth loop problem.
Is the hum all the time independent of the volume levels, or change with levels adjustments and not at all when turned right down. Let me if changing to line levels helps. We can try some more things, like connecting a temp hookup wire earth to the RCA earth to mixer chassis. Cheers
regards
robotek
Oct 04, 2008 | Audio Players & Recorders
425 people viewed this question
 Grubhead
Grubhead
