Question about SanDisk Sansa m230 MP3 Player
Windows can't see all songs on M230
Girlfriend has M230 with 60+ songs stored on it. She wants all the songs copied to her PC so she can keep them while adding others to the player. When plugging the M230 via USB into Vista Business PC, only 30 of the songs are visible in WindowsExplorer. Adding the device in MediaPlayer11 shows only the same 30 songs.
How can we copy the other half of the songs off the M230 onto her PC
  • 8,596 Answers
Re: Windows can't see all songs on M230
Problem was half the songs were added in one USB mode and the other half in the other. Was able to get everything off the M230 by copying half the files, then switching modes.
Posted on May 26, 2008
0 characters
3 Points
How do i add songs into my mp3
Connect your mp3 player to your computer, once your computer installs the player, go to MY Computer, your mp3 player will be listed there. Double click on it, this will open your mp3 player. Once you mp3 player is opened on your PC, goto where you have your music stored, Right click on the song you want to add, select copy with your left mouse button, go back to your mp3 player folder, left click anywhere in that folder and select paste. This will copy your music to your player. Let me know how that works.
Nov 26, 2008 | SanDisk Sansa m230 MP3 Player
How do I get music onto my Sandisk M230
Find the song in my computer under my music, Right click on the song file and hit open with... windows media player. File should convert and store on wmp. Then you should be able to sync your player.
Nov 21, 2008 | SanDisk Sansa m230 MP3 Player
I'm new to MP3
itunes is protective of it songs so i don,t no about that
but i have a sansa m240
on the player hit the menu Button
its the shall one on the top
till it turns on then let go and press it again
scroll down to settings press the white Button
below the play Button. scroll down to usb
then select auto detect
plug in the player to your pc
you can transfer them yourself
or use windows media player 11
transfer them yourself right click on the music
go down copy click
go to my computer or computer in start menu
select sansa m230
select tcnando hit ctrl v
on the key board
to transfer the the files
to use windows media player 11
open windows media player 11
plug in player to pc
a window should pop up
follow the instructions
than click on the sync tab
you should see the sansa
click and drag the music
from the left hand side
to your players sync list on the left
and click start sync .
I hope i could help
Apr 10, 2008 | SanDisk Sansa m230 MP3 Player
The songs are not getting downloaded to my sansa m 230
Change the mode on the device. Settings>USB Then try transferring the music again. Best of Luck.
Oct 05, 2007 | SanDisk Sansa m230 MP3 Player
Sandisk sansa m230 512mb
Open the device under My Computer. Your music is in the Music folder. Select the songs to copy, right click on one and select COPY. Select the destination folder on your computer and right click an select PASTE. This should copy all of your music to your PC. If you are receiving an error about "administrator rights" you need to change the Windows User account to the Administrators account. Please add to the question, if you need more assistance. Best of Luck.
Sep 26, 2007 | SanDisk Sansa m230 MP3 Player
Copy songs from computer to sandisk m230
change the mode of the player to MSC then just drag and dropped the songs in your player. :D
Aug 28, 2007 | SanDisk Sansa m230 MP3 Player
San Disk 230 (512 MB) MP-3 Player
If you have ripped the songs using windows media player 9 then you may want to rerip then again using windows media player 10 ( provided that you disable Copy Protect Music in The RIP tab ) and windows media player 11. If the songs came from music stores (napster,Rhapsody etc.. ) you can resync them using their software. You may want to reformat your player then retransfer the songs. This is normal if you purchase the songs. It dont mean the player is faulry its just the songs.
Aug 08, 2007 | SanDisk Sansa m230 MP3 Player
Can't delete songs on sansa m230
I actually had this exact same problem with my Sansa m230, and I was running from place to place just looking for an answer; I actually stumbled across it through some related searches here on this site ('reset' specifically), and I tried it out and it worked for me. The Sansa m230 has two USB interface modes, and choosing one will make your system recognize the device differently than if the other is chosen, so songs that were uploaded using the USB setting 'Auto Detect' (which tells the thing to use something called 'MTP' mode) won't be visible again when it's connected using 'MSC' mode, and vice-versa. Simply put: Unplug the little bugger, go into the USB settings, and choose whichever of the two settings isn't already selected, and plug it back in. For the future, I'm going to erase everything from one mode and put it back in through the other mode, just so this doesn't happen again. <.
Oct 27, 2006 | SanDisk Sansa m230 MP3 Player
Setting up a playlist
Frist get get your curent windows media player updated to windows media player 11 from: When you have it plug in your mp3 player and go to sync. if you look on the left hand tool bar there will be a new item. it says sanoma on the bottom you click on album and a file will pop up. it says a track title. You go under that and right click there will be an option to add a new track you name it whatever you want. Then you go to my competer click on sansa click on the icon after thta and go to the old folder and copy the songs one at a time to move them into the new folder.
Oct 09, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
47 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
