Question about Zenith C27A24T 27" TV
Concierge by Zenith Input Problems.
Ok this TV has 4 plugs in the back. The Cable Antenna, The Video Input, One Audio Input, and a Speaker Out plug. Now I plugged I my xbox 360 in jammed a few buttons and presto! It works. The next night I plug it in and can't get it to work. The weird part to is that there is NO video input or any input other then the Cable Plug. So I looked on the TV and Remote and there is no AVI/Input switch buttons. There is none so please don't tell me there is a button because I know there isn't. I tried all buttons numerous times. Is there a secret way to switch the modes to the video in? When my 360 was working I think it was on a normal channel. I tried 1/2/3/4 and tried to go to 00 which is usually a different input. I tried many things and it doesn't work!!! Please help. Only thing I have which I think might work is my Ch. Preview button on the remote but I tried and it isn't working. Please help!!!
  • Anonymous Jan 27, 2008
    I'm having the same problem. I'm at this hotel and all I want to do is play my 360, but I can't get anything to work. I hear there's an RFT adapter, or maybe RTF, which plugs the audio and visual cables into a cable plug adapter. I bought a universal remote and tried to override the normal commands, but still no luck....
  • fatstack Feb 17, 2008
    can't find a way to put the tv into video mode.
I had the same tv at my motel and wanted to hook up my Wii. Turning to Channel 999 worked.
Posted on Feb 25, 2009
All you have to do is auto program channels while your A/V Device is connected and you can add AUX to the channel line up in the menu when your using AUX. Or like he said tune to channel 999.
Posted on Aug 26, 2009
I was able to reprogram my tv with the guest remote. What I did was pop the front cover off of the remote, looks like the internal part of the remote is the same, just the buttons and face plate are different, then just pushed the smaller buttons in between the timer and alarm button, this is the menu button. Below the ch preveiw button is the adj right and then all the way to the left in the same row is the adj left. Then go through the menu and have your aux input on and hooked to the TV and turn the auto program on. The TV found my input.
Hope this helps.
Posted on Dec 13, 2008
Of the 4 black buttons, the one furthest to the right is a setup menu. Press it and setup will appear. Pressing it again switches to a different set up menu. The button beside it (3rd from the left) will move you through the menu items and the one beside that (2nd from the left) will select a menu item.
UNPLUG the coax cable in the back for cable TV. Plug in your XBox and turn it on. Use the menus to select Auto Program. Choose On Air Cable TV (or something like it). The set will go through and find the channel your XBox is coming through on. You'll have to repeat the process to get cable back, but it will do the trick.
Posted on Oct 27, 2008
Got it to work.. on a Zenith concierge TV. What I did was the above suggestions as far as un-hooking the coax, hooking up the rca cables, then doing an auto program search for channels. After it finished it said "0" Channels found, I almost gave up then I hooked the Coax back up and saw a red "AUX" in upper right hand of screen. I then rebooted my Xbox and "BAM!" i saw the big white and green "X" i was so desperate to see. Good luck yall it will work!
Posted on Jul 25, 2009
Need to program the tv
Posted on Nov 04, 2010
At a hotel in Overland Park, KS, we ran into a similar problem with a Zenith H2530Y Concierge Series TV. We had a portable DVD player and wanted to hook it up to the TV. The audio and video in RCA ports on the back seemed inaccessible using our "Guest Remote."
Upon further investigation, we discovered that the buttons from the master remote were disabled only by the cover of the remote. We popped off the cover using a dime. The button between Timer and Alarm opens up the menu, and the right and left buttons beneath the Ch Preview button are for adjusting.
So, we're going to search for channels and hope that it finds the RCA inputs on the back. In order for this to work, you must first unplug the RF cable. Additionally, you're going to search within the Cable-TV input. If you've done things correctly, it will search and find 0 channels. Then, it will default to the Aux channel, which is what you want.
See our Youtube video which offers a more descriptive explanation. Just search on Youtube for "Zenith H2530Y RCA input."
Posted on Jan 22, 2010
  • 4 Answers
So I'm reading these solutions and had to say "you've got to be kidding me". So I dug in my box of universal remotes and found one that had an input select button. I programmed the remote to this TV (code 0017) and presto, I now can select any input. Got remotes?
Posted on Jul 30, 2009
Got it working for a driect tv box! but didn't use RCA cables.
I struggled with this for about an hour.... It didn't help that it is 32 inch TV. Plus it's in an enclosure mounted 6 feet off the floor. Zenith sucks... but I got the input working.
In the menu (accessed from the front of the tv) I selected "cable 2" then used coaxial, then turned the TV to channel 4.
Posted on Mar 13, 2008
Agh. I spent hours on this. I eventually used the menu button on the front of the TV, scrolled through to features, and was able to select an input from there. Unbelievably frustrating, but it works now. I guess you have to go through that menu to find the input every time you switch between TV and movies.
Posted on Jun 13, 2008
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
Zenith TV has no place for yellow, red, white composite plugs
This TV doesn't have an AV input, so there are no input jacks other than the antenna connector. If you want to connect a device that has only AV outputs (your red, white and yellow plug) you will need an RF converter. This will take the AV signals and convert them to a channel 3 or 4 signal you can tune in on the set.
But since you don't seem interested in spending any money, you'll probably not like to hear that the converter runs around $15 most places. Take heart, there is an alternative. Find a VCR (if you don't have one already) that has an RF output. Many of the the newer DVD/VCR combos only have AV outputs. You're looking for one that has an "out to TV" threaded connector on the back. These units already have an RF converter built in. Connect your AV plugs to the line in jacks on the VCR and switch to that input, and you can use your video game or DVD player through the VCR.
Jun 20, 2009 | Zenith SY2549S TV
Don't know how to connect my vcr to my tv
You can either plug RCA cables from the audio and video, audio is red and white for stereo or just one of them for mono, the video is yellow, from the "outputs" on the VCR to the matching colors on the tvs "inputs". You can also connect the antenna output on the VCR to the antenna input on the tv and put the tv on channel 3 or 4, if done this way connect the antenna/cable to the VCR antenna in and connect a cable from the antenna out to the tv.
May 27, 2009 | Televison & Video
Cannot get DVD's to play on our TV.
It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
1) COMPONENT VIDEO (Red, Green, Blue)
If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
2) COMPOSITE VIDEO (Yellow)
If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
3) COAXIAL JACK (Antenna port)
If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
(I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
May 04, 2009 | Televison & Video
Cannot connect zenith vcr to zenith tv thru cable box
Hello mcgillicu390,
From your VCR you should have an (RF OUT) and an (RF IN) Connector (these also might be marked as ANT IN and ANT OUT, or CABLE IN and CABLE OUT).
The same goes for your TV (RF IN), (ANT IN) or (CABLE IN).
Now, take your Coaxial Cable (Cable with screw on or Push on connector with a wire in the center of it) and connect it to the TV (RF IN), take the other end of the same cable and connect it to the VCR (RF OUT).
Then connect your cable TV set top box or antenna to the (RF IN) of the VCR.
If you are using a cable box set your VCR and TV to Channel 3 or 4 (depending on your area)
If you are just using the VCR and an antenna set your TV to channel 3 or (depending on your area).
That should do it for coaxial connectivity.
If you are using the composite video and Audio cables to connect to your TV here are the directions for that.
Looking at the back of your TV you will see Three RCA type connectors colored as Yellow, White, and Red. Yellow is Video, White is your Left Audio, and Red is your Right Audio. They should be marked as (Video IN), (R Audio IN), and (L Audio IN). *note these markings may not be exactly like what is written, however the indicators should be close to what you are seeing.
Now look at your VCR, you may see a lot of RCA Connectors (up to 6 of these connectors) don't worry, you are only looking for the ones that say (Video OUT) (R Audio OUT), and (L Audio OUT).
Once you find the connectors on both pieces of equipment, take the Yellow, Red, and White tipped cables and plug the in their respective jacks Yellow tipped cable connects VCR (Video OUT) to TV(Video IN). Red tipped cable connects VCR (R Audio OUT) to TV (R Audio IN), and finally White tipped cable connects VCR (L Audio OUT) to TV (L Audio IN),
Once the cables are connected you will be able to use the composite selection on your remote to view the images from your VCR, the VCR in this case will be acting as the tuner for your TV with out you having to set the TV to channel 3 or 4, you will just have to use the AUX or whatever setting on you remote that allows the composite video to display.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 27, 2009 | Zenith B27A11Z 27" TV
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
Sep 27, 2008 | Televison & Video
Zenith Concierge hotel tv wont work with my xbox 360
I doubt the TV even has a tuner if it is designed for a hotel. It may be a "dumb" receiver, nothing else. Do to channel 2 and then press the down arrow for channel, does it flip to 138 or AV1?
Mar 19, 2008 | Zenith C27A24T 27" TV
Zenith C27A24T 27" TV Logo
8,234 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
