Question about Archos AV 500 400-Hours Video Recorder
Help I need the factory soft ware for my AV 500 archos
  • marilyn51 Jan 20, 2008
    thanks , but it doesnt work. marilyn
  • Anonymous Sep 22, 2008
    get a new one
  • 758 Answers
Soft ware for archos AV500
Glad to help YOU!
If I got it right you are looking for DRIVERS for your Archos AV500.
Well, HERE you have the all drivers you need.
Click on EACH ONE apart to get it (download it) or to RUN it.
GOOD LUCK!
Mar 09, 2011 | Computers & Internet
I HAVE A ARCHOS AV 500 I WAS WONDRING IF THERE IS ANYWAY TO CONNECT IT TO THE TV SO I CAN WATCH THE ARCHOS VIDEOS ON MY TV THANKS
You can use a disc shaped connector hub for AV in/out connections, but no travel AV in/out. That is a separate accessory. So, if you want to see your video on a separate TV, bring the big hub, or spring for a separate set of travel connectors.
Thanks
Oct 13, 2009 | Archos AV 500 Digital Media Player
No power whatsoever to my Archos 504
There is little documentation regarding the reset. However there is one in the Archos 504. If you take the battery off and look at the connecting Pins of the battery of the main unit. You will see a small Gold Button (looks like the circuit). This is the main reset button. If you Press it all will be good. You will not loose anything unless you have a Main File corrept but at least you will get function back so you can fix the firm ware.
I hope this helps you.
Ed
Feb 21, 2009 | Archos AV 500 400-Hours Video Recorder
Can't link my archos to my laptop
1. Copy all factory installed files from the Archos on to your PC hard drive or write a CD / DVD.
2. Download the latest software from www.Archos.com and keep a copy safe (not on the Archos!) … there was a new version last week by the way …1.5.12
3. If you record any films, music, or TV that you want to keep forever then don’t keep them on the Archos!
4. Factory installed samples (photos & films), wallpaper, etc are available for download from FTP://support.archos.com
5. If you need to format the drive but it won’t talk to the PC through the normal USB, try plugging a flash memory card (the bigger the better) into the other (left hand) USB socket and copy stuff onto it.
6. Avoid changing back & forward between ‘hard drive’ and ‘windows device’ … not sure if this was the cause of the problem but you never know!
7.Always have mains power (not battery) when moving files around.
Nov 13, 2008 | Audio Players & Recorders
Problem with my Archos loading up
this wont help but snap mines doing the same
May 14, 2008 | Archos AV 500 Digital Media Player
Charging problems
I've got the same problem. The only solution I have come up with is to purchase an external battery charger.
Mar 10, 2008 | Archos AV 500 Digital Media Player
AV-500 Archos files not in correct parameter
you must update the firmware on the archos by going to the web site www.archos.com or if it is a pocket dish www.pocketdish.com both have download sections.
Feb 27, 2008 | Computers & Internet
Format Hard Drive Error
If the unit detects any form of Hard Drive Error it asks you to format the drive. Connect the unit to your PC and run ScanDisk or DOS Chkdsk on the drive. Will help to rectify any issues with the FAT. Windows XP & 2000 Running Check Disk Utility (ChkDsk) ? HARD DRIVE mode only If you still have problems with the file system on your AV 500 you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the AV 500. ? Quit all running applications. ? Properly connect the AV 500 to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f . Use e: or f: or whatever drive letter is representing your AV 500. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When finished, exit the DOS Window and properly disconnect the AV 500 from your computer. Now try using the device. DO NOT try to defrag the drive. Let us know how you get on.
Jul 26, 2007 | Archos AV 500 Digital Media Player
Archos AV 500 400-Hours Video Recorder Logo
79 people viewed this question
Top Archos Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
JonSnell Electronic
JonSnell Electronic
Are you an Archos Televison and Video Expert? Answer questions, earn points and help others
