Question about IBM ThinkPad T23 2647 Notebook
Does not boot, fan spins up/down/up/down solid green light
The laptop fan spins up and down constantly, no video, no beeps at all, pulled the battery and tested w/o battery, tested with just the ac plug, pulled the memory, pulled the hdd, and also pulled the cd drive out to verify, and still nothing. The green light that looks like a lightning bolt comes on solid and that is it. Any other suggestions before i tell my friend he needs a new laptop?
  • draftndude Feb 18, 2008
    I recemtly replace the whole chasis with mainboard already attaced. When I turn on power the cpu fan turn on and off repetedly. The screen come on and all the drive's start up but no beep or text on the screen. I went through the laptop and checked all connections but still no change. Is there anything else I can try? Thanks
  • Revpilot Feb 25, 2008
    I have the same problem. The fan goes up and down and it acts as though it's sleeping. I tried taking out the battery and I tried turning it off and holding down the on key until the capacitor discharged. The problem persists. Any suggestions?
Thinkpads are notorious for this problem. Everything suggested I tried to no avail. There are hundreds of complaints about the same problem. The computer goes to sleep, makes fan noises, but won't wake up. I've owned two Thinkpads and won't buy another one. Tis a shame to buy a laptop only to have it last just beyond the warrenty period and the give out. I once heard this computer called a Stinkpad, now I know why. I wouldn't recommend anybody buying one.
Posted on Feb 29, 2008
  • 383 Answers
If your computer is not booting up You need to do this:
Getting into Windows Safe Mode.
Reason: Users who may( not be able to boot into normal mode) or are not able to troubleshoot their computer properly may (need to boot into Safe Mode) bypassing normal windows settings and startup programs and allowing the user to fix their computer.
Solutions:
Windows 95 users
Windows 98 / ME users
Windows 2000 users
Windows XP users
Windows Vista users
How to get out of Safe Mode?
Which Safe Mode option should I choose?
(Unable to get into Safe mode) see : document CH000750
Good Luck/Please dont for get to Rate/Thank You.
Posted on Jan 17, 2008
  • 2,427 Answers
Try flashing the Bios
TAKE APART THE LAPTOP
REMOVE THE BATTERY
on the main board has a smaller bios battery, remove it
hit the power button 7 times to disperse any remaing power
install back the bios battery
mount up the laptop
try it now
IF THAT FAILS YOU MAY REQUIRE A MAIN BOARD OR A PROCESSOR
If it was beeping it nwould have been memory/..
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
Dell dimension c521 solid amber light
When you plug in the power cord is there any lightswhatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your power supply is going bad or is bad. Sometimes the power supply has enough power to emit a light or make lights come on but not enough power to start the fans or disk drives.
Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 29, 2012 | Dell Dimension C521 PC Desktop
Dell inspiron 1545 14 beeps (more details inside).
This indicates a motherboard issue, sub out the ram memory one at a time, test each as you go, if no change! The motherboard will need to be replaced, or the laptop.
Apr 21, 2012 | Dell Inspiron 1545 Notebook
When i turned on switch dell vostro 230 it give no display and led colour is red
No Display, so does it seem like the computer booted up and is running except that the Display is black? Do you hear fans running, disk drive spinning, blinking lights or beeps?
I'm going to assume that in your case since you mentioned a red light that it is not booting up all the way. Therefore your problem is probably with the memory, the video card or some other motherboard issue.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 19, 2012 | Computers & Internet
I have a new violation 9053 and first time to charge the green light blinks for about 10 seconds and then goes off and thje battery is now dead it seems, no lights, no power
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Apr 01, 2012 | Computers & Internet
All lights are green except the third light is red.
Mar 31, 2012 | Computers & Internet
Hi i have an r630 desktop and it did work but now i have no power to motherboard no fans cpu but i do have power to the hard drives and rom replaced power supply same problem
Maybe your motherboard is toast.
Mar 30, 2012 | Computers & Internet
When i turn on, the green light comes on then goes out,why
Mar 28, 2012 | Computers & Internet
Fan just work for seconds
Replace the fan or your computer will run hot and keep turning off.
Or are you saying this is what happens when you power on the computer? if so: When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Laptop fails to boot. no post beeps no video Power light comes on Hard Drive light comes on briefly and the Drive can be heard spinning up then stopping. Laptop was originally purchased in North Korea
Clean first its ram module edge connector with soft eraser. But disengaged first its battery, power source and completely shutdown.
Then put it back and try to boot. If this doesn't help let me know . Leave a comment.
Apr 23, 2009 | Computers & Internet
IBM ThinkPad T23 2647 Notebook Logo
278 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
