Hi. I will list both engine types and there respective firing orders.
Click here to view the firing order for the 2.0L 4 Cyl
Click here to view the firing order for the 3.0L 6 Cyl
Hi again. the links above are not responding properly, and i do apologize for this error. Kindly, use these links below. They are operational.
Click here to view the firing orders for the 2.0L 4 Cyl
Click here to view the firing orders for the 3.0L 6 Cyl
THANK YOU MR.MASTERS
SOURCE: whats firing order diagram of 2002 ford escape v6
Ford V6's - rear bank of cylinders are 1 - 2 - 3. Front bank are 4 - 5 - 6 starting from passenger side (front) of engine.
Your firing order is
1 - 4 - 2 - 5 - 3 - 6
You're welcome.
SOURCE: need a diagram pitcure of firing order for a 2001 Ford Escape
you didn't say which engine so here it is for both
2001 Ford Escape 2WD
2.0 liter DOHC L4 VIN "B"
3.0 liter V-6 VIN "1"
SOURCE: Engine misfire 2004 ford escape v6 3.0 ltr, need
2004 Ford Escape 3.0 liter V-6 VIN "1"
The next, I "bid" it. Good luck.
SOURCE: headlight went out in 2003 ford escape i have
you have to remove the whole headlight assembly, then pop off the front cover pull the old bulb out and put the new one in. reverse the process to re-install. there is a small plastic tab on the topfront of the headlight assembly, that is what you need to release to get the clear cover off and get inside.
SOURCE: firing order diagram ford escape
2001 Ford Escape 3.0 liter V-6 VIN "1"
I hope this helps (remember to rate this answer).
