Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca hd 52w55
The led lit 3x and came on but with no picture! then a burning smell! i unplugged it and removed the panels! no obvious burns found the bulbs appear good but it wont come on or even blink now!
  • RCA Master
  • 5,138 Answers
Its a good chance that your flyback transformer is bad and shorted hori output transistor.Asti replacement parts call 1-800-221-1828
Posted on Jan 17, 2008
Why doesn't it turn on?
Fixable but it will be a board that failed. You need to identify which one an replace that as well as the wire harness the fried.
Dec 15, 2015 | RCA LED46C45RQ 46 Inch LED Lit 1080p
My LG washer stopped mid-load at spin cycle, how can I fix this?
It sounds like a serious fault if there is no power the fuse has gone or some item has burnt out . You will have to arrange for a service engineer to look at it more closely.
Apr 28, 2015 | LG WM-2277HW Front Load Washer
Thomson 50DSZ644. Just replaced the Lamp great picture but burned smell.. after few house it smelled verry bad..and i turned off. now when i turn on the tv the picture in middle is dark and still thi
should have unplugged it when you noticed the smell.
UNPLUG and remove and look at lamp you installed--is something in the housing where lamp goes melted? I hope you did not touch the face of the bulb with your hand or fingers.
What ever is wrong find it before trying to use set again.
Dec 22, 2012 | Thomson 50DSZ644 50" DLP Rear Projection...
How do I remove odors from this dryer?
Probably build up of dust and lint inside cabinet. You need to unplug dryer, remove back panel and vacuum out lint. If excessive lint found, would indicate insufficient cleaning of lint filter or restricted outflow vent or hose. If odour is electrical smell or burning plastic check all electrical connections and insulators for signs of browning or overheating. Strong pungent smell could be motor winding overloading or burning out. Will need electrician.
Apr 02, 2011 | Dryers
Norcent plasma had smell of electrical burning and
get real bright flashlight shin close to the screen in dark roomand try to push the menu button if its the bulb you'll see some picture with flash light shining that shows your backlight is out
Feb 15, 2010 | Norcent Technologies PT-4291HD 42 in....
32 w smells of plastic burning
I would suggest to unplug it and do nto use until you find out what has gone bad, open the back up and look, you do not want to burn down you house. Warranty?
Dec 17, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I smell something burning then the tv just went off
Unplug the tv and take it to a repair shop. Obviously if you smelled something burning, then you shouldn't leave it connected.
Dec 01, 2009 | Televison & Video
Burning plastic smell westinghouse hdtv
The problem may cause by the defective transformer on Power supply board. there are 3 transformers on the power supply.
Please do the vision inspection on power supply, you should be able see the obvious burn on one of these three big transformers.
May 11, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
RCA F31317 or picture Tube
Please tell me if you can see any burned wires or components or can you smell something burning .
Feb 19, 2009 | RCA F31317 31" TV
No Power
Ok, easy !!!.( take it out the box ) Look, in the front part of the box TV ( under convergence panel controls) you will see a little black box, we call high voltages splitter ( 5 red wires go to pictures tubes and screen focus box). Replaced it. Am suggested inspected for possible leak coolant, just for be sure noy leak coolant projection and prevent future problems. I hope this help you, Thank you !!!
Aug 03, 2008 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
66 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
