Question about Sony STR-DE595 Receiver
Equalizer for Bose 901 Series IV
I connected the Bose 901 Series IV equalizer to the tape loop but I can't get any sound when I push the MD/Tape button. I have my computer plugged into CD inpput and everything plays fine when I push CD/SACD button. It even plays fine when I Plug computer into Tae in treminal and push MD/Tape button.
Also, I don't seem to get the volume at maximum setting that I would expect from a receiver with this power output rating.
Any ideas?
  • ernestos Jun 30, 2008
    i have the exact same problem, same receiver, same 901 series 4 speakers. can't get the eq to work with this receiver. what are the options?
  • Tazmateo Sep 19, 2008
    looking for the best receiver/amp for looping in my series 4 Equalizer w/901 speakers
    Brigadier General:
  • 8,546 Answers
There's good news and bad news. The bad news is that a multichannel receiver with Bose 901's attached as you have them will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to receive its Active Equalization and for another, if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources. Tape Monitor is for analog stereo material only and on my receiver it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devises for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what I think you're trying to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). Yours does NOT so we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious place would be at one of the few OUTputs on the back, assuming you have one free to use.
I see Video 1 and MD/Tape have Audio Outputs. Use one of these to feed the Bose EQ. **
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Sony STR-DE595 (Video 1 or MD/Tape Audio Out ***) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receivers speaker level setup.
*** In either case you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. This is what's happening to you right now when you select MD/Tape. You're disconnecting the source from the 901 EQ.
You may have to get ugly with your other input components to find them all homes on the receiver. The labeling won't necessarily match up with the device types. Mine is ugly like that and I have a lot of connectors, but I have even more input devices.
If you have CD, TV Cable box and DVD (typical) you need to assess what you have that is digital and use what you can wherever you can, then the leftover analog device(s) - PC? - can go into any available analog input that is left over.
Whichever of these connections you DO NOT use for the 901's will still be available for using some kind of conventional analog recording device or sound processor such as an EQ or dbx Expander. However, as with any digital receiver, selection of that device for monitoring will kill the sound from any DIGITAL source you have playing (or maybe it just won't allow you to monitor).
Posted on Apr 24, 2009
How can i hook-up a 901 series vi equalizer to a str-de897?
I own 901's(since new) with the active equalizer powered with a non-Sony surround sound receiver.
Basically, you use the MD/Tape in/out jacks to route the signal to the Bose active equalizer. Switch the Tape Monitor switch if no sound is heard.
Here are some references.
Connect equalizer cables (4 total) to the MD/TAPE section of your receiver. OUT from the receiver to the equalizer IN and Out from the equalizer to IN on the receiver.
One issue with the equalizer running through the MD/Tape jacks is that it may affect any other speakers hooked up to your system.
Mar 15, 2016 | Audio Players & Recorders
Bose 901 Series V along with Equalizer ...What else do I need?
Nice speakers! No problem hooking up. Google "bose 901 V manual" and download the manual.
These will work with almost any receiver or amp. The speakers are connected just like any others. The equalizer goes in either an "external processor loop" OR a tape loop. You only need one Tape but it must have both Tape In and Tape Out. When you use the system you engage the "Tape Monitor" which allows you to hear the signal that is sent thru the equalizer. The HDMI is a separate issue. Any modern AV receiver should have HDMI. Just be sure it also has a "loop"--either EQ or Tape.
Aug 19, 2015 | Bose Audio Players & Recorders
Using Bose 901 Equalizer on Yamaha HTR-5840 Reciever
The manual is linked below. Page 19 advises you to use the "MD/CDR" - "IN (PLAY)" and "OUT (REC)" analog audio jacks.
Jan 27, 2014 | Yamaha HTR-5840 Receiver
How do I connect my bose equalizer to my pioneer amplifier
The manual is at
In any question regarding connections the exact models of all parts in the scenario should be defined.
"Pioneer amplifier" is not unique nor revealing. Integrated amplifer? Power amp? Tape Loops available? Pre-Outs? What's involved as a preamp?
The key thing to know is that any amplifier channels driving 901's must not drive other speakers as the Active EQ severely modifies the Line Level source input. If the EQ (or any sound processor) is used in a Tape Loop on a modern multichannel digital-audio-capable AVR, ONLY 2-channel analog sources will function when the Tape Loop is engaged; and all downstream speakers will be affected by the processing. That's par for the AVR course.
Bose 901 use in multichannel applications (which I have) will require access to Pre-Amp outputs for the chosen channels (likely the Front) and you will need to get a separate amp for the 901's, placing the EQ in series with the chosen amplifier. I currently drive mine with a Carver MT-200T.
Sep 20, 2011 | Bose 901 EQ1915 Home Equalizer
I have been using 901 speakers and eq with onkyo tx-8522 av. but now when i turn on tape 2 monitor on, the sound become very weak, even i turn the volume to the max. when i turn off tape 2, the sound come...
Qualifier: I have 901's in a 7.1 setup and have written many posts on Fixya regarding how to do it right.
ONLY now it does that? "VERY WEAK" as in attentuated somewhat or is it signal leakage, effectively silence? How is the EQ wired in? Check its own Tape Monitor button.
If you DO NOT have a separate amplifier for the 901's the EQ will affect EVERY speaker and we know that is NOT desired.
If the EQ is in a Tape Loop of a modern AVR and you activate the loop two things will happen: 1) the 901's will sound better and the rest of the speakers will be at risk from excessive amplitude at the extremes; 2) any digital source will be disabled.
Jul 10, 2011 | Bose 901 VI Main / Stereo Speaker
I have a yamaha 797 receiver and bose 901 VI to run my ps3 to my receiver it has no hdmi or optic
The manual for the 901's is here.
For the purpose of this discussion the 901 active equalizer is the same as any Tape deck or audio processor. You could place the 901 Active Equalizer in the VCR or MD/Tape loops; or remove the Pre Out / Main In jumpers and place it there but that would you could never use headphones as they wouldn't sound right with 901 active equalization. See page 10 and 11.
The PS3 is just in audio device for this topic. Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here:
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Feb 28, 2011 | Bose 901 VI Main / Stereo Speaker
Amp out and amp in for bose eq.hook up
  • 1
    Examine your receiver to be sure it has a tape monitor loop. Receivers with a tape monitor loop will have a button or switch on the front for "Tape Monitor," and have two sets of RCA connections on the back, one labelled "Tape In," and the other "Tape Out."
  • 2
    Take the two cables that are provided with the 901 speakers and insert one end of the first cable into the "Amplifier Input" jacks of the equalizer. Connect the red connector to the R input and the other connector to the L input. Connect the other end of this cable into the "Tape Out" connections on the receiver. Again, hook red to R and the other to L.
  • 3
    Connect the second cable between the "Amplifier Output" jacks of the 901 receiver and the "Tape In" connections on the receiver. Follow the guidelines in Step 2 for R and L connections.
  • 4
    Plug the 901 equalizer into a 120-volt electrical outlet. Your 901 equalizer is now installed.
  • Read more: How to Install a Bose 901 Equalizer '
    Jan 03, 2011 | Bose Audio Players & Recorders
    Bose 901 series speakers to Bose 901 Equalizer
    There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
    Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
    Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
    Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
    Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
    Apr 12, 2009 | Bose 901 VI Main / Stereo Speaker
    Bose 901 equalizer hookup
    how do I hook up the bose 901 EQ to a yamaha DSP3090??
    Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
    Sony STR-DE595 Receiver Logo
    1,419 people viewed this question
    Top Sony Audio Players & Recorders Experts
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
