Question about Apple iPhone Smartphone
Call forwarding TO iPhone problem
I can set up a call forward from my land line to my iPhone, but when the iPhone receives it it goes directly to voice mail without ringing. Any suggestions? I've tried redoing it several times and I've worked with both providing companies, but no solution yet.
  • Rinchen Jan 18, 2008
    I'm trying to call forward to my iPhone from a land line. Does anyone know how to program the iPhone to ring when the forwarded calls come in?
  • Anonymous Apr 01, 2014
    can't transfer internal calls to 1 of our lines, it goes direct to voice mail, how can I fix this??
Unless you are using your landline for a modem to the Internet, I strongly suggest you port your landline TO your IPHONE and have One less bill each month!!
Posted on Jan 17, 2008
How to forward all calls on KX-TG6702
The KX-TG6702 is a standard POST 2-line landline cordless telephone system. You can transfer a specific call between handsets using the Intercom without changing the line that the call came in on. Then you can use the second line for other calls, if the wiring and phone subscription is set up for that. However, if you want to forward any call to another phone number, you will need to connect your telephone provider and set up call forwarding. Follow the directions from the provider to use the service.
The manual for the KX-TG6702 is available on the product support page: http://shop.panasonic.com/support-only/KX-TG6702B.html . The direct link to the manual is currently ftp://ftp.panasonic.com/telephone/om/kx-tg6700_en_om.pdf .
I wish that I had better news for you.
Jul 16, 2018 | Lands Phones
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
HOW DO I FORWARD A CALL TO ANOTHER PHONE?
On the Land line phone, dial *72 then you should hear the dial tone again. Enter the 10 digit cell phone number that you want the land line call to go to, hang the phone back up.
*73 will set the calls back to the land line when you no longer need the calls forwarded to the cell phone.
Sep 19, 2014 | Lands Phones
Call forwarding to another land line number
When I need to leave my office unmanned, I take my calls with me. Just pick up your receiver, hit fwd/dnd button, then punch in 69 and then the number of your landline and then the pound sign. When you no longer need them to be forwarded, hit the fwd/dnd button and then 0
Jun 08, 2009 | Panasonic KX-T7431 Corded Phone
When I transfer received calls from the land line to the mobile phone, I am not receiving the faxes - - how do I set this up? so that I am not loosing faxes received?
If the call has left the physical line of the land line, you cannot transfer it back to the fax. The only way to do that is to have it actually transferred (by forwarding or similar) back to the line, but there's no possible way for the fax itself to request back the call, since it's no longer on the line.
Jun 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
INCOMING CALLS
Hi there, it is possible that you have the G1 set into "always Forward" state, which means when receiving calls the phone will forward the caller to your voicemail.
To Check and change these settings. goto the G1's Home screen, Click the "Menu" button, and then click on "Call settings". Then from here click on "Call Forwarding".
From here, the top setting should say "Always Forward" If this is set to Enabled, click on it and select Disable. This should now allow you to receive calls correctly ! if the Always forward function was disabled already, i would suggest calling T-Mobiles Customer support line to see if they have a remedy to this situation !
Hope this helps ?!
Oct 27, 2008 | HTC G1
Call fordwarding
I forward my office phone by dialing 72# and the number.
Your office phone may be on a system that did the forwarding, or you may have to CANCEL call forwarding (73#) before you can set it.
Carl
Sep 01, 2008 | Lands Phones
Iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
Jul 17, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
494 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
