Garmin Master
- Posted on Dec 04, 2009
Re: Can't load entire map to nuvi 205W
The Nuvi 2xx series has a limited memory size. You will probably only be able to have the lower 48 states on it if you live in the US. You can free up memory be deleting unused voices, vehicle icons, pictures...
- Jim
SHARCNET-USA
it says I don't have enough memory for the entire map. Can I download it to a memory card?
I did that lready. Can i run download the update and run from memory card?
I freed up everything I could. Can I download the map to a SD card?
Not sure call garmin support.
that iwill not work, dump your favorites and everything like recently found and so on, this GPS doesn't have very much memory so you need to keep only what is absolutely ness stored.
dump the language library, that is what i did.
NOT SURE I UNDERSTAND WHAT U MEAN HERE.
