If you are unable to use your memory card, your LG CU515 has a data cable connection which supports charging and mass storage mode.
Once you connect your phone to your PC with this cable, you should be able to transfer your pictures.
USB Connection Mode:
You can transfer files between a compatible PC to
the memory in your phone using the Mass
Storage. When you connect the phone to a PC
using the USB cable, this will be displayed as a
removable disk through Windows Explorer.
After connecting your phone to your computer with the data cable on your computer, click: START > Computer > and look for the phone in the list of storage devices.
On your PC, double click on the icon that identifies your phone - and locate the folder where the picture's on your phone are located. Then double click on your picture's folder on your PC. Simply drag and drop the pictures from your phone to your PC.
If you do not have a Data cable, one can be purchased either at your local cellular retail store or on eBay:
Click on this link:
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=lg+cu515+usb+cable&_sacat=See-All-Categories
