Software problem trying to download from cds canon creative version 2.02 on new computer running windows xp some of the programs i downloaded but when i go to print my label get message -stick caused a general protection fault in module stick.exe at 0002.2 fo8
  • 1 more comment
  • annettemarie Aug 25, 2008
    when trying to print off the label from canon creative, received a general protection fault module stick.exe error message. Went into Add or Remove programs to remove it, but it is not in the Add and Remove list.
  • bbodixie Dec 22, 2008
    the error message I get when trying to print is General Protection Fault at TV4win.exe at 0002:2BBe.
    This error started today-previously I did not have a problem
  • Anonymous Mar 04, 2009
    Same exact problem. Installed multiple times but no difference.
I had the same issue when I tried to print. I had to set my default printer to an older printer. Everything else worked fine. If you get this error when printing hopefully you can reset your default printer. I don't think the software has updated printer drivers for some of the newer printers.
Posted on Nov 10, 2010
    Novelist:
    Scholar:
  • 108 Answers
Lola.....first try googling the exact error message .....you may get the fix but you will at least get closer to a solution. you might also try reloading the software (after first deleting it all)....please use add/remove software in the control panel. Running scandisk as well (just in case you have a linked file) is also suggested.
Posted on Jan 24, 2008
6ya staff
SOURCE:
Windows 7 driver
Creative labs ct4780 is not supported by Windows 7. So you can download the driver for Windows XP and install it in compatibility mode. Click here to download the driver.
Configure the driver installation program to run in compatibility mode. To do this, follow these steps:
a. Locate the executable file for the driver installation program.
b. Right-click the file, and then click Properties.
c. In the PackageName Properties dialog box, click the Compatibility tab.
d. Click to select the Run this program in compatibility mode for check box, click Windows XP (Service Pack 2) in the Run this program in compatibility mode for list, and then click OK.
e. Double-click the executable file to start the installation program.
See: http://windows.microsoft.com/en-US/windows7/Make-older-programs-run-in-this-version-of-Windows
Apr 29, 2014 | Creative Labs CT4870 / CT4780 Sound Card
I have PrintMaster Premier 8.0, I would like to install on my computer running windows 7. It will not download. I do not want to purchase another version. Is there any updates that I can download to allow...
1. These instructions from Microsoft will explain how to run a compatibility troubleshooter for your software.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
2. Contact Broderbund directly at 800-395-0277. I use their Print Master software also and they are very helpful at the customer service area.
Sep 11, 2013 | Mindscape PrintMaster Premier 7.0
Canoscan n640 not work in windows 7
Canon stopped supporting this scanner after XP. The available software and drivers are here: http://www.canon-europe.com/Support/Consumer_Products/products/scanners/Others/N640P_ex.aspx?type=download&page=1 .
Depending on the version of Win7 on your computer, you can try one of the following workarounds. To check your version, click Start > Control Panel > System and Security > System. If it says x64, you have a 64-bit version of Windows 7. Otherwise, it is the 32-bit version.
1) If you have the 32-bit Win7, you can try the compatibility mode. Download the driver or full software from the Canon site and right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties. This may not work.
2) The option that will work for all versions of Win7 is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or upgrade to them), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the Canon site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. Also a printer cannot be installed on both the real and virtual computers at the same time. You will be prompted to uninstall one set of drivers if you try.
I hope this helps.
(the above suggestions assume you do not want to replace the scanner which would be faster.)
Jun 07, 2011 | Audio Players & Recorders
Why can't I download my CANO SCAN set up CD-Rom on to my new Windows 7
The CD-ROM has the installers for older versions of Windows. The installation routines for the newer versions of Windows have changed considerably from those that were in use when the CD was written. You can get the drivers and Canon Toolbox software for the scanner from Canon: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide25#DriversAndSoftware . Select Windows 7 in the dropdown menu. The software will work with any version of Windows 7.
The only exception is that the third-party software is not available for downloads. If you want to use the original CD software (assuming the disc is undamaged) and you have Windows 7 Pro or Ultimate, you can download and install Virtual PC and XP mode for a free XP virtual computer. Then install the scanner to the "XP computer" as you normally would. However, the virtual computer and the Win7 computer cannot both have the hardware installed simultaneously. So to share files, you may need to save them to external media (optical or hard drive). If you have one of the other versions of Windows 7, you can do the same thing with any virtual PC program and a licensed older version of Windows.
I hope this helps.
Feb 12, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
My old computer with a Borland dBase 5.0 program on it crashed but the hard drive was salvaged and I have hooked it up to my new computer. However, my old computer ran Windows XP on 32 bit, the new one...
Do I need Windows XP Mode?
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software. Visit the Windows 7 Compatibility Center to find software that works with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
It's the best of both worlds: The new Windows XP Mode lets you run older Windows XP business software right on your Windows 7 desktop.
Designed primarily with small- and medium-sized businesses in mind, Windows XP Mode comes as a separate download and works only with Windows 7 Professional, Ultimate, and Enterprise. Windows XP Mode also requires virtualization software such as Windows Virtual PC. Both are available free on the Microsoft website.
Download
Learn how
Jan 23, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
I am trying to download OmniFormPremium50.exe onto a computer running Windows XP Pro. I downloaded the software from the Nuance website and it is currently in the downloads section of my computer; however...
I looked at the specs for this program and did not see Windows XP listed as an operating system that this software on. It does say the program will run on "any platform" but the information may be dated. Here is the site that I looked at:
http://wareseeker.com/Business-Finance/omniform-premium-5.0.zip/3d1596d667
I found another site that has a version of the program that runs on XP, although it seems to cost more. Here's a link to that site:
http://www.nuance.com/omniform/premium/
I'm wondering if it is possible that you have a version that does not run on XP. I don't know where you obtained your version but I would check the source to verify that it runs on XP before trying to figure out this problem any further.
Hope this helps. Good luck!
Mar 13, 2010 | Computers & Internet
Can I load Canon Creative Program version 2.0 on to a computer running XP professional? Will this program work with my computer?
That program is pretty long in the tooth! It was originally written for Windows 95...
You may be able to install it on XP, but the functionality may be limited and you may have some driver issues. I suggest getting a more modern program rather than trying to install this dinosaur.
Jan 04, 2010 | Canon Computers & Internet
Update software complatible with windows vista
Ever since vista dropped alot of support files for simple thing like Creative's older model Mp3 Players, try going to creatives website, and look in the support section for a driver update for VIsta.
Feb 10, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Problem with Zen nano
· 1. remove all creative software from your pc (do this from start menu/settings/control panel/add or remove programs)
2. Uninstall Windows Media Player 11 and Windows Media Player 11 runtime. This will rollback the pc to an earlier version of WMP.
3. Download the latest version of the zen driver from this location:
http://us.creative.com/support/downl...ame=Windows+XP
4. Make sure the zen is not connected to the pc and install run the exe file to install the software on your pc. at some point, the install will tell you that the unit is not connected. Connect the unit to proceed. it will also notify you that you are replacing an existing software, or something to that effect. I accepted or said OK to this popup. Once the firmware is installed, my started to work fine. You can now reinstall WMP from microsoft website. Hope this works for you.
you might want to verify that your new player has the latest firmware available, as this might address the unresponsive-button issue you're having. Firmware updates are surprisingly easy - you just download the firmware file from Creative's website, plug in your player, and double-click the downloaded file. It's that easy.
All else failes download the recovery tool from creatives website.
Jan 07, 2008 | Creative Labs Zen Nano Plus MP3 Player
Creative Webcam Instant drivers for Vista
My wife has a new computer with Vista on it.  I tried to plug in my Creative Webcam Instant into it, thinking there would be no problems.  Turns out that Creative doesn't support Vista for a couple of its webcams.  I fixed it, though, and now there's no problems.  What you have to do is take advantage of a couple of Vista's less-obvious features.  Put the Creative CD in.  On the CD (not in a folder on the CD), there's a setup.exe.  Right-click it and select "Properties".  On the "Compatibility" tab, enable the option to run it in compatibility mode for XP SP2.  Then also check the "run as administrator" option, just for good measure.  After that, it will install just fine (otherwise, the Creative installer tells you that it doesn't support your version of Windows).  Then, after it installs, find the program's executable.  It should be in the relevant program files folder (if you're not sure, hover over the webcam center shortcut in the start menu, and see where the program is actually located).  Do the same thing for the program executable (right-click, compatibility tab, enable compatibility mode for XP SP2, enable running as admin for good measure).  If it doesn't work for you after all that, I don't know what to tell you.  It works just fine for me now (it didn't want to otherwise).
Dec 22, 2007 | Computers & Internet
Open Questions:
Computers & Internet Logo
1,135 people viewed this question
Ekse
Marvin
Marvin
