Question about Jenn-Air JXT8030ADS Kitchen Hood
Blow back istead of suck out
I have a master electrician installed my rangehood today.I check the air damper and it seem to open both ways before i place it inside the 6" in diammeter of the unit before in do the ducting.After all said and done i turned it on but instead of sucking the air out it blow back cold air .Why?
  • 139 Answers
Re: Blow back istead of suck out
This installation guide on the Jenn-Air web site does not provide electrical details, but there are two possible problems here.
1. - The fan could be installed backwards...or it moves air the wrong way
2. - The power wires might be connected incorrectly.
My best guess is that the fan uses a standard ac-powered motor, so the polarity of the wiring would not affect the direction it turns. If that is true, then the most likely problem is that the fan is installed incorrectly.
Good luck...and I hope this is helpful!!
Posted on Jan 17, 2008
0 characters
3 Points
Hi, I am installing a DHI645KAU I think it is. It is an under the cupboard slide our 60cm range anyway. It is going into a new kitchen. The electrician said I had to cut the lead off and run a line back to...
A domestic rangehood simply gets its supply from a power point in the cupboard above. A commercial rangehood would be on a designated circuit. The same wiring code covers Australia and NZ. Ignore him.
Mar 20, 2011 | Bosch DHL755BUC Kitchen Hood
In winter, cold air blows back down and out through the fan.
Either a backdraft damper was never installed in the ductwork or the damper is stuck open...
Has it always been this way?? If so then the damper probably was never installed and you will need to have one installed to stop the air...
If it was good at the beginning and now is not then the damper is stuck will need to find it and then get it working agian...
The dampers often are right at the outlet of the hood...if you take down the hood it should be right there...
Feb 11, 2011 | Broan-NuTone Best By Broan EB12 External...
A local small contractor installed our Kobe RA3830SQ Range Hood a few days ago. We have not been too impressed with the efficiency of the fan. Today I noticed that it seems to blow out instead of sucking...
Hoods should blow out from the chimney, its defianately not a wiring problem. If it is blowing down towards your cooker instead of sucking up then you should contact Range as it could be a manufacturing fault.
Dec 06, 2009 | Kobe RA3836SQ Under Cabinet Range Hood
How to install a rangehood on a glass splashback with no pre-drilled holes in the glass
If the glass is frosted you can use a clear glass adhesive. Put blobs approximately 6 inches appart on the rear of the glass and push to wall.
Nov 18, 2009 | Faber 36quot; Stainless Wall Canopy...
Brand new Kenmore microwave fan does not **** up air
It's easier to notice air blowing out of something than it is to notice air being sucked into something. Put a pot of boiling water on the stove and see if the oven sucks up the steam from it. If it does, it's working fine.
Sep 17, 2009 | Kenmore Range Hoods
Looking for a manual for SMEG rangehood HACD60SS model bought in 2008. Rangehood may not be installed properly, it's not sucking up air into the hood.
check to be sure that the fan works, and if it does check to be sure that the air flow path to outdoors is not clogged. one way to do this is to remove the hood and slide a dry garden hose through the entire vent pipe to the outdoors.
Jun 29, 2009 | Range Hoods
Some air blows downwards from rangehood
clog? or the shutter on the end wont open.
Nov 25, 2008 | Range Hoods
Does not take up the smoke or steam - 2nd unit
It really depends on the exit. If the duct exit has to travel really far before exiting it tends to not have as much suction. And like solution 1 said. Make sure the plate was removed
Apr 12, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Distance from lowest point
Normally the rangehood should be at least 700mm from the top of the cooktop.
Nov 03, 2007 | Miele DA 249-4 Kitchen Hood
Fans are blowing instead of extracting!!!
just wondering what the problem you had was ? as i,ve just fitted a hood and have the exact same problem....
Cheers !
Aug 30, 2007 | GE Monogram ZV1050SFSS 42" Island Chimney...
Jenn-Air JXT8030ADS Kitchen Hood Logo
788 people viewed this question
Top Jenn-Air Range Hoods Experts
Richard Roth
Richard Roth
Barrett Palumbo
Barrett Palumbo
Are you a Jenn-Air Range Hood Expert? Answer questions, earn points and help others
