Question about Brother MFC 7420 All-In-One Laser Printer
Transmission level How do i change the transmission level on the mfc7420?..report coming back says the level is to soft
I have just received the following info from Brother Support:
To adjust the transmission level on your fax, please follow these instructions:
- Press the following buttons in quick succession: (MENU, *, 2,8,6,4) These must be pressed in under 3 seconds. If done correctly, the screen will display maintenance, but if it does not, press STOP and try again until it does.
- Once maintenance is on screen, press 1, then 0. The screen will display WSW00.
- Press 13, and the screen will display WSW13=01011110
- Press the right arrow on your control panel until the cursor is underneath the 3rd last digit, and press 0. Your screen should show: WSW13=01011010
- Press SET
- Press STOP
- Press 99 to exit maintenance mode, and once back to the time and date screen, send a single page fax to 1300 368 999 and you will receive a faxed reply that will show you your transmission level and how much it has been adjusted.
Please note if your transmission level is still not in an acceptable range ( -15dB to -18dB ) then it would be best to contact the Product Support Centre on the number listed below to discuss possible fixes.
I hope this helps.
Posted on Feb 19, 2008
  • dwaldron68 Apr 24, 2011
    I tried this today on my new Brother MFC-7440N and it corrected the transmission level problem just fine. The only thing that was different is you press OK instead of SET. Thanks for the post, it saved me a phone call!
  • John Hilvert May 01, 2013
    Definitely the way to go for Australian telco requirements. As well as replacing SET with OK, I found it best to just amend whatever WSW13 was showing with WSW13=01011010. That got me an excellent rating from Telstra.
1996 mercedes e320 every time i press the stoliretor. Check engine comes out then start checking i need to know the problem.
it is called an accelerator and if the engine light comes on then that is reporting a problem in either the engine or transmission
take it to a service center and have the fault codes read and repair what is faulty
have you checked the oil level, water level etc
May 30, 2016 | Cars & Trucks
My 2006 club car will hardly move when pressing accelerator but comes back gradually once moving - why?
check your transmission fluid levels if they are fine have the transmission filter changed
Feb 12, 2015 | Golf
My 2001 ford escape wont shift into high gear, i get to 41 mph and it just high revs and wont shift. what can the problem be?
a few reported transmission probs have been reported with your make model and year vehicle, nothing major. But if it is a slip ring then transmissin will need to be rebuilt approx 2000.00. first need to find out if transmission fluid low or has burnt smell. I suggest taking to Midas or Monroe they will give you a free "look over" and if it is something like low fluid level is easy to fix.
if you drain and fill the transmission fluid be sure to change the filter if your transmission has one. It only makes sense. I hope that your problem is just a quick fix.
Cheers!
Feb 14, 2010 | Ford Escape Cars & Trucks
Wrong Fax Number on Transmission Report
To change the fax number, do the following:
  1. Press Menu/Set 0 3
  2. Your station ID should appear, use back arrow (<) to move the cursor to the position where you want to change the number
  3. Press Menu/Set
This procedure will change your phone number which will be displayed on all cover pages and Tx reports
Best of luck.
Greg
Jul 28, 2009 | Brother IntelliFAX 2800 Laser Fax
Transmission report
Press the DATA REGISTRATION button and press SET. Push the DOWN ARROW to REPORT SETTINGS and press SET to TX REPORT and press the SET key to make the change press the DOWN ARROW until it says OUTPUT YES and press SET. Press the orange CANCEL key when done.
Apr 02, 2009 | Canon LaserClass 7000 Plain Paper Fax
Can't get transmission report on bizhub 250 to print in Portrait
to change the tray that reports print from
it can be changed in service mode soft switch 323
change bit 7 to a 1 to print from tray 1
change bit 6 to a 1 to print from tray 2
bit 5 to 1 to print from tray 3
bit 4 to 1 to print from tray 4
bit 3 to 1 to print from bypass tray
Mar 19, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
My brother mfc7420 won't send or receive faxes.
please give me more info! what is on the screen? i am a brother tech, i will try and help you but i need mmore info.
Dec 16, 2008 | Brother MFC 7420 All-In-One Laser Printer
How do you check the automatic ytransmission fluid level on daewoo lano 1999 with 1.5litre motor ? also what is ATF fluid capacity?
The ATF level is checked when your engine is at normal operating temperature, your car sitting on a flat surface with your transmission in P mode. Pull out the trasmission dipstick and check the level on it at hot.
Normally the colour of the oil should be quite clear or pink but if it smells burning or is too brownish in colour, your transmission will need a flush and the internal filter replaced as well.
Jul 20, 2008 | Daewoo Lanos Cars & Trucks
Printer doesnt come out of sleep mode (Brother MFC7420)
I'd be happy to give you the solution to this problem :)
You'll want to go into the menu and choose these options: 1,6, and 2. The final stop should give you the sleep menu.
The printer is setup for a default of 5 minutes. But you can change it from 00 to 99 minutes. To just shut it off, press the Options and Start button simultaneously and that will do the trick.
Here is the link to the manual: http://www.brother.ca/en/products/pdf/manuals/MFC7820N-UG.pdf
If I wasn't specific enough, the solution is on page 2-6
-Ernest
Apr 30, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
2,340 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
