Amana ALW880WH Top Load Washer
Problem for Amana ALW880WH Top Load Washer
Water will not stop filling the washer
By martamaria on Jan 17, 2008
The water will continue to fill the washer and the cycle does not start
Please help!
Comments:
Jan 17, 2008
- The water will continue to fill the washer and the cycle does not start
Best Solution
posted on Jun 23, 2009
Very Helpful)
wemomike
Rank: Apprentice
Rating: 100%, 3 votes
I just fixed this problem on my GE washer that overflowed earlier into my hallway and living room. The fix required removing the tube from its connection at the outer tub and cleaning out some residue that was preventing air from moving to the sensor at the top of the machine at the control panel. No tools were needed other than a large steak knife to undo the clips to remove the front panel of the machine and a small flat head screw driver that I used to clean out the plastic pressure hose.
The good news is that even if this had not worked and the sensor/switch needed to be replaced, the part is available for replacement at the local hardware superstore and a few online outlets for around thirty dollars. Replacement of the switch looks to be relatively simple by disconnecting the existing wiring housing and replacing with a new part.
There are several detailed diagrams available online by doing a search for your product/ model number.
Be sure to check the hose before replacing the pressure sensor/switch- this will save time and money.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Jan 17, 2008
Not Rated)
networkmagic
Rank: Guru
Rating: 86%, 169 votes
The water level sensor switch may be bad, or the tubing connected to it has come loose or is leaking.
Inside your washer, there is a plastic or rubber tube that extends from the bottom of the tank to the top of the washer where it attaches to a pressure sensor. The pressure sensor is probably near or attached to the water level knob. The top of the tube should be connected to the pressure sensor switch and sealed so that air cannot escape. When the water level rises in the tank...and in the tube...the air pressure inside the tube increases. When the air pressure reaches a certain point, the pressure sensor is activated which causes the water to stop and the wash cycle to begin.
The tube should be inspected to make sure it's not filling with water due to an air leak at the top. Check to be sure the tube is still attached to the pressure switch. If you are not familiar with electrical testing, you may need assistance from someone with a volt meter to test the pressure switch...although, if the tubing is okay...the switch is probably bad.
Good luck...and I hope this is helpful!
Was this helpful?
Yes
No
Popular Solutions for Amana ALW880WH Top Load Washer
Questions and Unsolved Problems for Amana ALW880WH Top Load Washer
Do you recommend Amana ALW880WH Top Load Washer?
Answer
Answer
no pressure coming out of cold water faucet. cannot unscrew hose. workmen were working on water line... (More)
Answer
Our Amana 2002 top loader washer model ALW880QAW is leaking from the transmission to the tub, where... (More)
Answer
It won't spin out fast enough which leaves the clothes dripping wet.
Answer
Motor S68pxmcm-1069 not turning the right direction. Noticed on spin cyle, loud clicking.
Answer
spin cycle on washing machine hums but will not spin washer fills with water and washes drains but... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Amana ALW880WH Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14895
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
