Question about Archos 605 WiFi Digital Media Player
TV Scheduler not turning on Cable Box
It seems that after I upgraded my Archos 605 firmware to ver 1.7.13, my device is no longer turning on the cable box to begin recording. It works fine when I manually test the IR code - any clues? Thanks in advance.
  • ArchosJim Jan 17, 2008
    here is the answer from Archos Support, it worked for me...
    Turn the device completely off and hold down the Power and LCD/TV button down
    until the repair options show. This will walk you through the repair. This
    will help to re-flash the firmware and make sure it runs correctly.
I have the same problem and it won't change channels after the 1st program. I just leave the cable box on. This is not the best answer but it works for now.
Posted on Jan 17, 2008
My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Jul 29, 2009 | Archos 605 WiFi Digital Media Player
605 not recognized by Windows Media Player 11.0
You may require a driver to work with your device. Try downloading driver from company's web site.
Jul 15, 2009 | Archos 605 WiFi Digital Media Player
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 20, 2009 | Archos 605 WiFi Digital Media Player
After formatting the archos5 ,the device doesnt get recognised
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* When the white option screen comes up, just pick the format disk
Mar 16, 2009 | Archos 605 WiFi Digital Media Player
Archos DVR Station & 605 wifi PMP
Not sure if this will help you or not, but I have a 404 and was having issues with the scheduler changing the channels for me also. Then I realized that it is a infrared transmitter - the same frequency as a remote I realized what I was doing wrong - Your archos station must be facing the cable box that it is turning on. I had my archos on top of the cable box and it was not working - but when I turned the cable box and the archos station to face each other - so the signal can transfer - it worked just fine. Hope that helps!
Oct 22, 2008 | Archos 605 WiFi Digital Media Player
I cannot get my sons new Archos 605 to video from the tv. I feel like taking it back- what a waste of money!
I've had a similar problem. It finally started working though.....to a fashion.
I can now record the channel I am watching, but it does not record if the TV is switched off and I cannot get the scheduler to work at all.
When I first got mine 2 weeks ago, it would only record ITV, no matter what channel the TV was on.
Then on the 2nd day, it just seemed to kick in and whatever channel I put the TV on, the Archos displayed the corect channel.
Jul 28, 2008 | Archos 605 WiFi Digital Media Player
DOWNLOADING TV SCHEDULER
Mate Ive got the exact same problem ... If anyone out there knows how to fix this solution.. please help! thanks
Mar 17, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 wifi 4gb DVR issue
the power is low because you did the
same thing as me not chargeing it before you turn it on first
Jan 21, 2008 | Archos 605 WiFi Digital Media Player
No longer a tv picture to record on my 605 wifi passthrough device
have been onto technical support today with video recording problems and they have suggested that 1.7.13 may not be the best of firmware platforms, and that i install 1.7.06. Might be worth checking with them to see if you get similar advice.
Archos 605 30 gb
Yes you can download music from the net
No you can't use it as a word processor (not yet anyway)
Widgets are not yet available - they are due any time now
Check you have the output from the cable box to the input on the docking station and the output from the docking station to the input on the TV. Double check all your connections. If in doubt, rip them all out and start over. Once connected you will have to set the TV to one of the Aux channels to see the content and ensure you hit the TV button on the Archos to push the output to the TV.
Oct 03, 2007 | Archos 605 Digital Media Player
Archos 605 WiFi Digital Media Player Logo
48 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
