Question about Acer AL1711 17" LCD Monitor
Rolling Horizontal Stripes
My Acer monitor has begun to have constant rolling inch wide stipes, Help, Thanks, Terri It's almost 1 year old
  • clrwtr Feb 26, 2008
    Rolling Bars that distort image.
    New Friend:
ITS THE MONITOR I HAVE THE SAME PROBLEM
Posted on Dec 04, 2012
Try a new graphics card that should cure it .if u don`t want 2 spend out straight away try to borrow 1 from someone first
Posted on Feb 25, 2008
6ya staff
SOURCE:
Problem rolling bars
It should be a main power regulator baord fault. Contact any service technician.
May 22, 2013 | Panasonic TCP50U2 50 in. TV
Wide horizontal bars ghosting across screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .also check you warrenty its usually 3 years
Apr 12, 2010 | Acer AL1916W 19" LCD Monitor
TV COLOR AND SOUND
The convergence board is shot you going to need a new board as the horizontal ic's have given out. Reapiring this would take expertise and cost you more then its worth then just get a new convergence board. Thanks and please do rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | RCA HD52W59 HDTV Projection Television
Purple and green rolling lines after lightning storm
I have exact same problem...other posts have cited improper grounding from the Cable...which makes sense as the problem does not occrr with the DVD...I have not figured out how to fix it though...
Aug 12, 2009 | Panasonic TH-50PX75U Plasma HDTV
Rolling Horizontal Lines across the screen
ground loop is problem. Many answers available via Google.
Jul 07, 2009 | Acer AL1916W 19" LCD Monitor
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
Rolling Waterfall Effect going up my westinghouse LCD monitor
try moving the monitors.
it could be feedback signal.
also try different leads or without switch.
you will then be able to narrow down the problem to one component.
Feb 25, 2009 | Acer AL1711 17" LCD Monitor
Rolling display image
You will need to take your monitor in for repair or buy a new one. I could get into the specifics about WHAT exactly causes this type of failure but bottom line is the same.
Feb 11, 2008 | Apple Studio Display 17" CRT Monitor
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Acer AL1711 17" LCD Monitor Logo
255 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
