Question about E-Machines eMachines Desktop PC
Screen resolutio/brightness I have an emachine laptop that recently started shutting dow randomly. Last time it did it I turned it back on and have half the brightness and can barely see images. Its about half as bright as it was.
  • 537 Answers
Are you running on battery power or AC power? Some laptops are set up so that they will be dim on battery power.
Your battery could be going south on you.
The other possibility is that either your CCFL or inverter (most likely your CCFL lamp) is failing. They can be replaced for pretty cheap (part is about $5 to $10). The labor is a bit tricky but can be done if you are careful.
Mike
Posted on Jan 17, 2008
Computer screen going staticky randomly during use, bright flashing colors.
Do a hard disk check. I would bet your hard drive is going on you. Make sure you back up everything. The other thing to check is your video card. Much easier to deal with on a tower than a laptop.
Jan 29, 2014 | Dell E228WFP LCD Monitor
Emachines e627 cutting off
over heating possibly, try and blow out the inside with a can of compressed air
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jan 27, 2012 | Computers & Internet
My laptop froze one time and i had to hold the power button to shut it down. when i turned my laptop back on which is plugged with the emprex, the emprex LCD monitor went to auto adjustment by itself and...
try to do a syestem restore on it. click on start go to programs. then accessories system tools and at last system restore. and go back to the last time it worked ok.
good to you sawdust46
Jul 31, 2009 | Emprex LM2201 22" LCD Monitor
Compaq Presario F700 Laptop power up issue
Remove your cpu/gpu heatsink, apply a ermal bonding, this will prevent shut off because of cpu/gpu overheating(chipset detects temperature faulty in the firsts seconds of operating your laptop), if this didnt resolve your problem, naybe and issue with your Mobo.
Thanks
Please leave feedback
vcrtech
Apr 27, 2009 | Compaq Presario 700 470024-192 Notebook
Random Flashes on Macbook 13" native screen
you could try reseting the pram. this is accomplished by holding down Command, Option, P, and R at startup you will want to hear the start up tones at least three times. if that doesnt work you might have an inverter issue, the inverter is located behind the screen and needs to be looked at by a pro
Jan 19, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
EMachine laptop/windows xp problem
ur window had been crashed pls install new window
Jun 15, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Mac laptop displays minimum brightness
Check to see if there is a box right below that... Saying something along the lines of readjust to brightness of surroundings, etc!  Make sure box is unchecked for you, in regrds to your issue and then see if that helps!  I will look a little further into it for you!  Let me know if that helps though!
Feb 23, 2008 | Apple MacBook Pro Notebook
Screen problem =S
Try connecting to external monitor and see if you have a same problem. You have to hold fn key at same time with f4 (or depends what is yours. Check for a key that has the screen picture) If you do not get anything that means you are having problems with video card.
Have you updated recently the driver for the video card?
Feb 11, 2008 | Dell Inspiron 6400 Notebook
Toshiba portege s100-s1133 lcd screen
A pink or red screen which may gradually turn back to it's appropriate color indicates the lcd is going out. It could last quite some time in tht condition, but it's going. replacement isn't too bad though.
good luck
Jan 20, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
49 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
