Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Code f-3 model GSX 9885JQ0 CK2406109
  • 121 Answers
What should I do when the automatic safety system detects a malfunction?
The programme is interrupted, an audible tone sound and various indicators (if available) point to the
source of the fault.
Fault description table
Small lamp lights up Digital display Audible tone Fault description
“Water tap” “H” and “F” 30 sec “Water inlet fault”
- “P” and “F” 30 sec “Draining fault”
- from “F4” to
“F16” 30 sec “Electrical components fault”
“Water Stop” “A” and “F” 30 sec “Water Stop fault”
Posted on Mar 03, 2008
2001 Suzuki GSX-R 1000 code C41
Hi, Justin for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Suzuki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
C41 FI code fuel pump not priming bad ECU Suzuki GSX Motorcycle Forums...
Suzuki Fault Codes
Suzuki GSX R1000 Service Manual
https://www.partsfish.com/page/oem-parts-for-suzuki
Suzuki GSX R1000 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 12, 2018 | 2001 Suzuki GSX-R 1000
How often should i charge my GSXR 750 battery?
Instructions
    • 1 Remove the seats from both motorcycles to access the battery. Use an Allen wrench to remove the bolts from beneath the rear of the seats' padding. Use the ignition key to release the seat lock found on an earlier GSX-R600 model.
    • 2 Start the working motorcycle and clip the red (positive) jumper cable to its positive battery terminal. Clip the opposite end of the red jumper cable onto the GSX-R600's positive battery terminal.
    • 3 Clip the black (negative) jumper cable to the working motorcycle's negative battery terminal. Clip the opposite end of the red jumper cable onto the GSX-R600's negative battery terminal.
    • 4 Rev the working motorcycle's motor to 3,000 to 4,000 RPM, while in neutral, to produce enough power to maintain an electrical charge. Maintain this engine speed for the remainder of the procedure.
    • 5 Press the starter button on the right handlebar to start the GSX-R600's motor. Release the button immediately if the motorcycle does not start within five seconds then try again.
    • 6 Rev the GSX-R600's motor to 3,000 to 4,000 RPM and maintain this engine speed for at least three minutes.
    • 7 Disconnect the black jumper cables from both motorcycles, followed by the positive jumper cables. Reinstall the seats on both motorcycles, using the reverse method of removal.
Jan 14, 2013 | Motorcycles
I have a Suzuki GSX-R 750 and my F1 one light has started to come on when I excelerate some speed what does that mean.
Odds are its your SET valve needing adjustment, have the codes pull on the bike. If it is the SET, you can remove the SET system easily or you can have it adjusted.
If you get a code.
The codes are as follows:
C14 - THROTTLE POSITION SENSOR
C15 - ENGINE COOLANT TEMPERATURE SENSOR
C21 - INTAKE AIR TEMPERATURE SENSOR
C22 - ATMOSPHERIC PRESSURE SENSOR
C23 - TIP OVER SENSOR
C24 - IGNITION SIGNAL #1
C25 - IGNITION SIGNAL #2
C26 - IGNITION SIGNAL #3
C27 - IGNITION SIGNAL #4
C28 - SECONDARY THROTTLE VALVE ACTUATOR
C29 - SECONDARY THROTTLE POSITION SENSOR
C30 - SECONDARY THROTTLE CONTROL UNIT
C31 - GEAR POSITION SENSOR
C32 - INJECTOR SIGNAL #1
C33 - INJECTOR SIGNAL #2
C34 - INJECTOR SIGNAL #3
C35 - INJECTOR SIGNAL #4
C41 - FUEL PUMP CONTROL SYSTEM
C42 - IGNITION SWITCH SIGNAL
C46 - EXHAUST CONTROL VALVE ACTUATOR
C00 - NO FAULT
Jun 28, 2011 | 2007 Suzuki GSX-R 750
2000 model gsx-r 1000. Power response.
it sounds like a carb problem.. the jets need adjusting or they might be clogged up a little or if yours is injected the same thing would apply...i would purchase a Can of Sea Foam from Autozone $10 and pour 1/3 can into 2 gals fuel and run it on the open highways for about 10 to 15 miles getting on it once in awhile but do it safely. let me know if this has helped thanks.
Apr 28, 2010 | 2001 Suzuki GSX-R 1000
MY 07 GSX R 6 OCCASIONALL POPS A RED LIGHT CODE THAT READS F1 IF
f1 on gsxr stands for fuel injection, unless bike keeps stalling ignor it.my 04 did it all the time , ithink mainly when in slow moving traffic in the wrong gear.
Sep 01, 2009 | 2007 Suzuki GSX-R 600
2008 suzuki GSX 1000 motorcycle indicates on
FI = Fuel Injection. The FI computer is telling you that it has detected a problem and the code for that problem is "C13". Telephone your dealer and ask what that code C13 indicates is wrong. Then you can determine if you want to try the fix, i.e. "clean the air filter", or if the shop must do it, i.e. "# 3 injector is restricted".
A “very helpful” rating for this answer? Thanks!
Jun 14, 2009 | 2008 Suzuki GSX-R 600
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
May 07, 2009 | Bose 3 2 1 GSX System
Draw Locked closed with DVD in player on yamaha DVR-S60
Dec 27, 2007 | Bose 3 2 1 GSX System
Bose 3-2-1 cd stuck in closed position
Take it to Bose dealer or service center near you.
If you have technical knowhow, try the image enclose. make sure its the same model.5f18d64.jpg
Dec 26, 2007 | Bose 3 2 1 GSX System
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
144 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
