Question about Combination Televisions
Videocassette stuck in old Magnavox TV-VCR
A videocasette is stuck in the set and when one attempts to play it the screen reads'no cassette'
[I have been unable to jiggle it loose or the even open the case]
  • 337 Answers
SOURCE: TV shuts off after 10 sec
TV/vcr combo units develop problems in the vcr section,what happens is the cassete assembly draws too much current then the tv senses this increase and it says NO and shuts down,you will not be able to use the vcr anyway because it has a problem and the tv will continue to shutdown until the vcr is repaired,I have seen combo units with the tv working only as long as the vcr is not use.Remove the light you have in the opening and hope the tv works fine by itself.Adding a light is not safe.I hope this inf.helps somehow.Good luck
Posted on Sep 19, 2006
  • 42 Answers
SOURCE: Model Magnavox DV200MW8 DVD/VCR Combo
try then type in dvd hacks there are various sites to go can use search engines to your advantage.
good day
Posted on Feb 27, 2008
  • 78 Answers
SOURCE: Sansui TV/VCR 13" color
there is what is called a "dew sensor" in a lot of vcr's that keep you from playing a tape if it senses moisture in the unit because a tape will stick to the video head and get all bunged up. sometimes they go bad and will keep you from playing a tape even when there is no moisture present. if your are electronically inclined you can take the back off and locate the dew sensor, then disconnect it. the constant whirring noise is the unit's way of trying to dry off the video head cylinder. the dew sensor, which is usally located behind the video head, is a dark grey thing about a half inch by half inch and has two wires going to it.
Posted on May 05, 2008
  • 979 Answers
SOURCE: tape stuck in vcr
Carriage has been set out of alignment due to improper extraction- need to repair or replace the carriage loader...accordianman
Posted on Aug 01, 2008
  • 3 Answers
SOURCE: Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
On a unit I checked with this same symptom, removing the top cover allows the unit to stay on and operate normally. There is some sort of sensor at the left middle of the chassis, which, when unblocked by any opaque object, allows the unit to remain on. A temporary fix (not advisable) would be to replace the top cover with a piece of clear plastic or taut saran wrap (no vent holes needed). It's unclear exactly where/what that sensor is from a cursory test. This is a work in progress on someone else's machine that I lack full access to.
Posted on Jul 07, 2009
  • 10 Answers
SOURCE: the vcr on the tv keeps running and shutting off
All i ded was removeded a metal piece by grabbings it wit me hand. While it was off and stuff of course, i's not stoopid.
Posted on Nov 11, 2009
0 characters
1 Points
VCR stuck in VCR eject mode
You can get the manual here. Maybe it will help:
Jul 16, 2010 | Philips 27MC4304 27 in. TV/VCR/DVD Combo
Tv shuts off after 10 seconds
Many times, Cam Gear in VCR gets Stuck due to its age (Loose Belt most time).
The Cassette Housing is off Track (Usually Bent, or Toys inside!!!)
Solution, if you are not all thumbs,
1) UN-PLUG first!!
2) Get Alcohol Pad Ready.
3) Open Back Cover,
4) Clean the Belt on Worm gear (Usually Side of the mechanism towrds back).
5) while at it, Make sure to Dust with Air Aerosol (like ones that you use for computer)
50% of time this will Fix the Problem!!
Dec 05, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
Vcr wont work
Reset the VCR by unplugging/replugging, and then run a vhs cleaner.
May 20, 2008 | Philips Magnavox 20MC4304 20 in....
Tape stuck in VCR
could be that you're looking at a blown cartridge for that vcr tape. You may need to cut the tape, to extract that from the unit.
The play head would usually retract when the cartridge is removed, BUT could be compromised by some tape getting into the play head mechanism, and jamming.
be particularly careful with anything pointy or sharp, as the tape head does NOT like those objects near the read surface.
Mar 02, 2008 | Philips CCC132AT 13 in. TV/VCR Combo
good day
Feb 20, 2008 | Philips Magnavox 20MC4304 20 in....
Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
Sep 07, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
TV shuts itself off as soon as I press 'play' on video.
The set has a problem on the mechanical section of the VCR,it might be out of aligment or a part has gone bad completely and now needs to be replaced,dirty heads will not give you these symptoms,the power supply is sensing a problem and is doing what is suppose to do when it detects a problem,it seems that you only have a use for the TV unless you get the vcr repair.
Sep 13, 2006 | Philips 14PV375 14 in. TV/VCR Combo
Combination Televisions Logo
37 people viewed this question
Top Combination Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Combination Television Expert? Answer questions, earn points and help others
