Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
Blue Square at the bottom of my television screen
Hi there I seem to have this small blue square at the bottom right hand square of my television screen that is completely empty and will not disappear. My high definition television is less than one year old and this has only been happening for the last two days.
ANY ADVICE ON HOW TO FIX THIS PROBLEM?
    Sergeant:
  • 395 Answers
How large is the square? have you tried disabling the PIP on the TV?
Posted on Jan 17, 2008
  • haych112 Mar 20, 2012
    The pip setting was at the top right of the remote if you prees it twice the squar goes away
Sanyo dp50747 plasma tv is only showing in the middle of screen no video blue square showing horizontal 20 inches wide.The outside of square is blue solid both sides inside the square fuzzy lines red,...
It is line fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 17, 2014 | Sanyo Televison & Video
Blank Blue square on left hand corner of the screen ??
It might not be the same issue, but we had a blue square in the upper left hand corner of our hanspree. To fix it, either press the button headed 'pip' or go into menu, down to calibration and then uncheck the box titled 'pip' there. I hope this sorta yours as it did ours.
Nov 10, 2010 | Hannspree XV37 HDTV 37 in. LCD TV
The tv has a blue screen with av in bottom right hand side how do i get it back to reg tv?
On the remote there will be a button marked AV or TV/AV or may just have a symbol showing a square or circle with an arrow pointing into it. This button will either bring up a menu on which you can select TV or DTV, or it will cycle through the various options until you get back to normal TV. Hope this helps.
Jul 03, 2010 | Televison & Video
SEVEN SQUARES ON A PIN BOARD I CANT GET IT
Hi there,here is you answer,enjoy
There are 6 lines of pins
On each line they are in different positions
So for this occasion we are gonna number these from 1-28,from left to right then from top to bottom
We will give each square a colour and a number
1*Large blue square join the 4 corners at pins 8 to 16 to 23 to 28
2*Large yellow square join at pins 4 to 12 to 21 to 27
3*Small red square join at pins 17 to 22 to 24 to 26
4*Small brown square join at pins 14 to 18 to 20 to 25
5*Small light blue square join at pins 5 to 9 to 11 to 15
6*Small white square join at pins 1 to 2 to 6 to 7
7*Medium white square join at pins 3 to 10 to 13 to 18
Hope this helps its the easiest way i think i can describe it
JonnieC
Jan 06, 2010 | Nintendo Professor Layton & the Curious...
Crank 2 blue ray plays in a small square
Hi, Ref common problem with Blu-ray players only playing crank 2 in a small section of the screen. It seems the film needs extra buffer memory on your player. If you have a card reader slot, ie USB or SD, put in a blank card and the film plays fine. I have Panasonic DMP-BD35 which has a SD slot on the front, i used a 32MB card and the film played with no problems. Hope this info helps.
Regards. Rob.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
A BLUE SQUARE ON BOTTOM RIGHT SCREEN, 42 IN OLEVIA LCD. CANNOT REMOVE IT? THANKS
The blue square you are seeing is from PIP, (Picture In Picture). I got it the other day & found how to turn off PIP.
Feb 22, 2009 | Vizio L32 32 in. LCD HDTV
Block on screen
Hi Mary,
It's seems your panel it damaged, replacing it gonna cost you alots $$$... So just get a new one much cheaper...:) Have a nice day!
Oct 03, 2008 | Acer AL1716 17" LCD Monitor
Toshiba 40
Convergence amp ICs need replacing and quite possibly the resisors that power the IC as they usually burn open when the iC goes out. You will need two ICs. Let me know if you need any more info.
Feb 24, 2008 | Toshiba 40H80 40" Rear Projection...
CENTREX TELEVISION
on the bottom right hand of the remote there is a square with a plus in it, on the instruction book ( which my mum found, god bless her cotton socks) it says hold it down for 4 seconds, just hold it till the picture comes back, hope this helps, i had the same problem this morning.
Dec 28, 2007 | Televison & Video
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
662 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
