Question about Mitsubishi WS-48311 48" Rear Projection Television
Setting is set to 480i stretched, can I change this or...
I don't have the remote and the setting is set to 480i stretched, can I change this option somehow or is it my image that is stretched on the sides?
Thank You.
If my image is stretched how can I fix it?
  • 975 Answers
The display format for this unit is 1080i , so yes you should be able to change the format , I guess your gonna need the remote for this setting , in case you decide to get a remote , let me give this link , good luck and hope my solution is helpful.
www.remotecontrolwarehouse.com/MITSUBISHI/290P111010.html
Posted on Apr 26, 2008
6ya staff
SOURCE:
Menu segreto hannspree hsg1113
http://translate.google.com
Secret service menu Hannspree HSG1113
https://electronicshelponline.blogspot.com/2015/03/hannspree-lcd-tv-how-to-enter-service.html
Possible menu - Quoting from link above:
SERVICE MODE [Hanspree AT06 42" LCD TV] (Horizontal Frequency 31.5KHz to 48KHz)
* In the TV mode, adjust volume to Zero and press number keys 9 > 8 > 7 > 6 to enter service mode.
* To exit, press the EXIT button on the remote control.
SERVICE MODE (Hanhspree GT02 32E - GT03-37E1)
1 Switch on the LCD TV .
2 Press 9-9-1 on the remote control to enter the internal Service menu.
3 Press MENU to switch the service mode pages.
4 Press ?? to scroll through the various menu options.
5 Press ?? to change the menu settings.
6 Press MENUto save the new settings and switch to next page and press EXITto exit from service mode to normal mode.
TV / AV / S-VIDEO / WHITE BALANCE / BRIGHTNESS & CONTRAST ADJUSTMENTS
WHITE BALANCE ADJUSTMENT
1 Press 991 on the remote control to enter the internal Service menu.
2 Press MENU to switch to the PW106 Scaler Menu page
3 Press ?? to scroll to Page 2-3 options
4 Press ??
to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings.
5 Press EXIT to save the new settings and exit. [Don't adjust others setting in page 2-3]
Click on the Pictures to Zoom In
BRIGHTNESS ADJUSTMENT
1 Repeat the above mentioned step 1 to 2
2 Press ?? to scroll to PW106 FE VDC Menu Page 2-1 options
3 Press ?? adjust the Brightness setting.
4 Press ?? to scroll to TV/AV/S Parameter=AV1 setting and pressuto run the setting. (This procedure will copy the settings of AV1 to S & TV)
ATSC DTV WHITE BALANCE / BRIGHTNESS / CONTRAST ADJUSTMENT
2 Press ?? to scroll to PW106 Scaler Menu Page 2-3 options
3 Press ?,? to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings
4 Press to save the new settings and exit. [Don't adjust others settings in page 2-3]
YCbCr & YpbPr of COMPONENT 1, 2 WHITE BALANCE/BRIGHTNESS/CONTRAST ADJUSTMENT
Getting COMPONENT-1 connect to 1080i signal. (The settings could not be saved if signals input from COMPONENT 2 or connect to other sources such as 720P, 480P, 480i,etc.
WHITE BALANCE ADJUSTMENT OF Component
1] Repeat the above mentioned step 1 to 2
2] Press ?? to scroll to PE106 FE ADC page 2-3 options
3] Press ?? to adjust the Offset Red and Off Blue settings.
4] Press ??to adjust the Offset Green setting.
5] Press ?? to adjust the Gain Green setting.
6] Press ?? to scroll to 480i/480P/720P Parameter=1080i setting and press ? to run the setting. (This procedure will copy the setting of 1080i to 480i/480P/720P)
7] Press EXIT to save the new settings and exit.
WHITE BALANCE ADJUSTMENT OF PC INPUT
1.Connecting to VGA Timing mode
2.Under service mode, Press ?? to scroll to PE106 FE ADC page 2-2 options
3.Press ?? to adjust the Offset Red, Offset Green and Off Blue settings.
4.Press ??
to adjust the Gain Red and Gain Blue settings.
5.Press EXIT to save the new settings and exit.
May 14, 2018 | Hannspree Televison & Video
Rca How To Set my RCA LED32B30RQ - 32"from 480i to 720p
Refer its user manual. It must have details, if there is a facility to change the resolution.
May 01, 2013 | Televison & Video
I'm running 720p on my 360, because it's clearer than the 768p PC Mode. But 720p Overscans the picture which makes it larger. Any way to fix this?
If you are using the Component Cables make sure the switch on the cable(part that you insert into Xbox 360) is set to HDTV and not TV because if its set to TV, no matter what resolution you choose it will go back to 480i.
If your using HDMI cable make sure that your TV is also outputting at an HD resolution. Like okay let me explain this more clearly I'm not sure on Sony HDTV's but we have a 46" Sharp Aquos HDTV LCD. I found out that the TV itself was still set to output at 480i even though the Direct TV receiver was set to HD so I went to my TV's options and changed to output the TV at 1080i then after that everything was clear because both the receiver and the HDTV was outputting at HD.
That maybe your problem. If your 360 in the settings menu is saying its at 720p and your TV still looks long, maybe your TV's Zoom options are set to Stretch or Zoom, so basically you need to change your TV's options to output at Normal.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 08, 2011 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Where do you go to to change the component-1 settings from 480i to 1080i on the menu?
That is done in the menu of the source. I.E.sat receiver,cable box, ect...
Dec 13, 2010 | Televison & Video
How do we get the picture back to normal? The picture seems to be stuck in a zoom mode. The wide button does not fix this.
its probably a zoom setting on your cable or sat box.
sat - push the format button at the top or bottom of the remote to switch modes
cable -
go in to the cablebox menu, go to video settings, make sure its set to 1080i and 480i for 4:3 over ride, not stretch or zoom
Jun 07, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
How change from hdv to estandar definition
In this type of camcorder The lower video quality.
Standar Quality o standar definition will be 480i setting.
in the setup menu it will be an option to change the size of the picture to 480i. thas the standar o lower quality if you want to have a longer recording time in this HD camcorder
Recording modes
1080i (1440x1080), 1080/30p, 1080/24p (via 2:3 pull-down), 480i
Oct 07, 2009 | Video Cameras
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
Adjust the system's video output settings. Select the best output settings for the TV in use.
1. Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1
HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p
Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i
Composite / S Video *3 480i 576i
AV MULTI / SCART *4 480p / 480i 576p / 576i
*1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5. Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
6. Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
7. Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
I have two Sharp Flat Screen TV model # LC-26SB14U. One is hooked up to a regular Dish Network HD receiver. The other is hooked up to a HD DVR receiver. Both are hooked up to the same Phillips DVD player....
if you using the component input on both tvs I will check the settings on the receivers, "HD setup", the difference is because the settings are set one on 480i and the other on 1080i
Dec 02, 2008 | Sharp Televison & Video
Picture shifts to left
I had the offset left issue for non-HD channels with my Panasonic 42" plasma, using Comcast HD cable box. Went into the configuration menu (to get there with the newer Comcast boxes, you have to turn the box off, then hit the menu button on the box immediately after). You will see on the menu a resolution (probably says 1080i), then below it a "4:3 override". Our said 480i. When I changed it to "none", so that it stayed 1080i, it worked! It also works by selecting 480p, but then the picture is stretched.
Mar 13, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Mitsubishi WS-48311 48" Rear Projection Television Logo
197 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
