Question about DVD & Blu-Ray Players
I bought a sabre dvd player and when i put movies they show only black & white .
5 Suggested Answers
  • 398 Answers
SOURCE: sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Posted on Sep 01, 2007
  • 11 Answers
SOURCE: Dvd plays in black and White
There are a couple of things you could try with this. One, is to make sure that the video input is connected properly. The second would be to make sure that the DVD that played in black and white automatically changed your settings to PAL rather than NTSC.
Posted on Jul 06, 2008
  • 2794 Answers
SOURCE: DVD Player won't play movies in color
It could be the av cables being faulty or shorted. Try replacing them with another set and see if it goes away.
Posted on Jul 21, 2008
  • 158 Answers
SOURCE: dvd player no clour pictures only black white view
set the colour system to PAL
Posted on Jul 31, 2009
  • 10 Answers
You have posted this in the Panasonic DMR-ES30VS section.
Please note which product section you are in before posting your question.
For the Sony DVP-SR200P there could be multiple reasons for it only showing in B&W.
Was this a recent problem, is this a new hook-up, has it always been this way?
  1. In the setup menu there is a setting for Custom Picture Mode.
    Could someone have turned the color down?
    You can go to the setup menu and "Reset" the player to the factory settings.
  2. How is this connected to your TV?
    Check all cables to make sure they are plugged in, test each one by unplugging it, and then plug it back in fully.
    If you are using a composite cable (1 cable yellow plug), be sure you have plugged it in from yellow to yellow.
    If you are using the component (3 cables red-green-blue plugs) hook-up, be sure you are using cables only designed for component hook-up, and have plugged them in correctly, red to red, green to green, blue to blue (Be sure you've plugged the red cable into the red video not red audio).
    Are the cables in good condition?
    No breaks, loose connectors, they weren't smashed under a piece of furniture?
    Have you tried a different set of cables?
  3. Test the DVD player on another TV.
    Does the same thing happen?
    Did you "Reset" the DVD player?
    Maybe the DVD player is bad?
  4. Find another DVD player and test it with your TV.
    Does it work OK, or is it black and white too?
    Maybe the connectors on the TV are bad?
    Is there a custom setting on the TV for that connection?
    On some TVs you can adjust the settings for each input (INPUT 1, INPUT 2, ....) maybe the color setting is turned down?
There are may possibilities, but these are some of the basic things to check.
Best wishes,
Posted on Sep 14, 2009
0 characters
1 Points
I bought a technics home stero with a dvd/cd disc changer at a yard sale. and when I try to play a movie it shows up in black and white. What can I do to get it to show the movie in color. I traded out my...
Sounds like it is set to PAL when I imagine from "yard sale" you could be in the US so wuld need NTSC? It could also be set to S-VHS output or component,and you are using the scart or composite. It can't process both at once
Oct 10, 2010 | Technics DVD-A10 DVD Player
My dvd player only plays movies in black and white
my dvd player only plays movies back in black and white...not color. why?
Jan 21, 2010 | Cyberhome CH-DVD 300 DVD Player
Our dvd player now only works showing movies in black and white. What can we do? It use in color but for some unknown reason the movies are in black and white.
someone must have pressed something mistakenly.
Check the DVD remote and press PAL/NTSC. The color should appear.
Or you could also check the video wire at the back of the DVD and TV, maybe it has loosed contact.
I wish you all the best.
Jan 07, 2010 | Toshiba SD-2800 DVD Player
My dvd player pdv 709 wont show the movie .it shows half
my Portable DVD Player just stop playing movies. i put a movie on and it want read or it will start the movie snd just stop and want play no more
Oct 23, 2009 | Durabrand PDV-709
DVD player now showing in black and white
Make sure your av channel is av2 and not av2s as this will give b/w playback
Sep 13, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
Show movies in black and white no color
unit is in a progresive mode. need to turn back to interlaced.
Jun 01, 2009 | Sony DVP-NS575P DVD Player
Jul 06, 2008 | Apex Digital AD-1110W DVD Player
DVDs are only in black and white
Jimbo.. is your new TV HD compatiable??
Nov 11, 2007 | Apex Digital AD-1110W DVD Player
DVD & Blu-Ray Players Logo
156 people viewed this question
Top DVD & Blu-Ray Players Experts
Are you a DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
