hello, a problem like could be as simple as bad drivers, Bad VGA cable(bent pin maybe) or not as simple problem meaning bad onboard video chipset.
is it so bad that you can even navigate through few windows?
if so you would need to guy a cheap video card or ask a friend to lend you one so you can test before you go out and buy one.
so lets say u can read and nevigate a bit in windows: follow this: go to start -> run and type in "devmgmt.msc" (without quotes) scroll down to your video card, right click and delete your video card and restart you PC. After restart check to see if it is readable. if so download driveres here:
http://downloads.emachines.com/drivers/video/ATI_video_6_14_10_6525.zip
if not readable: get another card, go in computer bios disable onboard video, install card, plug monitor cable to new card and restart your PC when system is up install drivers for new card if required.
good luck, hope it helps.
regards
Amar Sondhi
This is the OEM mother brd? What do I need to check? I am concerned that is is a virus, bios or something else?
