Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
Unit won't start it just flashes CL (the door is closed)
We may have had a lightning strike. THe DW just flashes CL even though the door is closed. Custoner services said to power down the unit for 30 min and try again...that did not help.
thanks\ Glen
ghudgin@rogers.com
  • ghudgin Feb 13, 2008
    where do I get a Power Control board?
    What is the cost?
    how do I get access to it (remove it)
    thanks
    glen
    Genius:
  • 1,003 Answers
REPLACE POWER CONTOL BOARD
Posted on Jan 18, 2008
Liftmaster 3265M. Two units. Why does neither work since lightning storm?
Chamberlain Liftmaster garage door opener problems ...
? 3:10
https://www.youtube.com/watch?v=Zq_CxeTXoSM
Jul 2, 2013 - Uploaded by Mike McCarron
Might have taken a lightening strike, knocked out GFCI that was on the circuit that garage door opener was on. When I ... And sometimes after it happens it takes 30 or so seconds before the opener will work again. ... The keypad unit worked well butneither the homelink or the remote units worked.
Garage Door Openers - Lightning Strike - Forum - Bob Vila
www.bobvila.com/posts/30883-garage-door-openers-lightning-strike?...
Aug 6, 2005 - The house did not lose power and I do not believe the house was actually hit. ... the light comes on on the unit (as expected), but neither door opens or ... Afterplugging it back in, try opening the door with the hardwired button first - if it still doesn'twork, chances are your opener's taken some damage but not ...
I Have A Liftmaster Garage Door Opener Unit. The Remote Work ...
www.diyforums.net/i-have-a-liftmaster-garage-door-opener-unit.-the-re.
Jan 01, 2016 | Building Materials
Electrolux dishwasher fdb2310lcc1 flashing cl on display
Hello sandy miller, thanks for your post!
From my understanding your Electrolux dishwasher is flashing "CL". Typically, that stands for close door it could be an issue with the control panel, door latch, or door strike. I would recommend having a professional technician come out to properly diagnosis your dishwasher to avoid any unnecessary part purchases. Hope this helps. -Matt
Nov 16, 2014 | Dishwashers
Auto garage door opens will not close not the sensors
Look at the back of the motor unit and see if that little light is flashing a code. Post the code.
Aug 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only shut if I hold down wall button, sensors are aligned, one is green, one is orange, this happened after a lightning storm
If when closing the door it reverses to the open position and the main light flashes 10 times it is a door sensor problem. Make sure the small light on each sensor is on and not flickering ever so slightly. (check closely) Tweak them a little even though they may seem to be okay. Check for 5vdc between terminals 2 and 3 on the rear of the motor unit. If there is no voltage or if it is greater than 6vdc the logic board is bad.
Jul 29, 2012 | Sears Craftsman LiftMaster Chamberlain...
When I press start nothing happens then "door" flashes on screen even though the door is definitely closed
have you tried push the door in harder once u have turned it on my grandads old hotpoint washer was like this and wen used to jus push the closed door a liltte and it started
Dec 03, 2011 | Hotpoint Washing Machines
I have a 3/4 horsepower liftmaster garage door opener, both the remote and the wall button won't close the garage door but both will open the garage door. however, the garage door will close if I hold...
Sep 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
Flashes "CL" to close door when it is closed and won't start
The door switch has failed. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the process will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
May 21, 2010 | Frigidaire Dishwashers
Unit is giving me a flashing CL and won't start cleaning cycle. The door is closed.
When you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
Ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
If that did not fix the problem then the door switch has gone bad on you. You will need to replace the door switch.
If I can get the model # I will be more than happy to help you find one.
May 11, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Error code cl
See the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket. It could be that the unit is off balance making the door not even or enough play in the door so that the locking mechanisim thinking that the door was not closed try that.
Error Code: CL
Reason for the Code: Door switch open or door is open
Possible Component to replace: Door latch
Hope helps with this. Good luck.
Jan 20, 2010 | Frigidaire Dishwashers
Flashing stike laptop won't start
lightning strike usually is battery indicator try charging/replacing battery also battery might be dead and ac adapter broken
Jul 06, 2009 | Computers & Internet
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
569 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
