Question about HP ScanJet 5300C Flatbed Scanner
NO LIGHT THE LIGHT IN THE SCANNER IS OFF, HOW DO YOU REPLACE?
Help picture solution....
Posted on Dec 30, 2009
How do I replace the scanner light in my MFC-7440N?
It would be cheaper to just replace the scanner.
Mar 01, 2017 | The Office Equipment & Supplies
How do I replace light in HP Scanjet 5470c
  • 1Unplug it from the outlet.
  • 2 Unscrew the two screws on the side of the scanner that does not house the scanner and copier controls. Remove the plastic covering from the side of the scanner.
  • 3 Open the top of it0 and push on the glass. It will pop up. Remove the glass from the scanner.
  • 4 Remove the old bulb from its lamp by unscrewing it. Screw the new bulb in place. Replace the glass into the top of the scanner.
  • 5 Place the plastic siding back on the scanner and reattach the screws.
Jul 28, 2011 | Computers & Internet
Lexmark X1150 , scanner bulb very weak, use to be bright.
the scanner does use a bulb type ic reader but its not like a normal light i would say the printer has meet its end replace printer / scanner
Sep 25, 2010 | Lexmark X1150 All-In-One InkJet Printer
Florescent light died on my scanner, glows a
The bulb is blown, it may function once in a while, but repairing may be too costly.
Your scanner has a 1200dpi resolution. There are similar, yet better scanenrs for less than $50.
You might consider an EPSON scanner/printer for under $50. Some EPSSON printers can also print CD labels, directly printing onto the CD!
Sep 28, 2009 | Plustek OpticBook 3600 Plus Flatbed...
HP Scanjet 5370c problems
Scanner part of the hardware has gone defective kindly replace the scanner.
Sep 11, 2009 | HP ScanJet 5370C Flatbed Scanner
Scanner bulb doesn't turn on during a scan
You can try to get and replace the scanner light. If it was the light, the new one will work. If it was some other electonic component that shut off the light, then the light won't work. Depends on the cost of a new light compared to getting the unit serviced by a tech. Or the cost of a new Multifunction unit. Do some research before you make the decision.
May 31, 2009 | Epson Stylus CX9400 Photo Printer
Error 3200 and no light from scanner Lamp on Kyocera FS-1118MFP
this error belogs to Exposure lamp problem ? cause of this error 1. Defective scanner PWB. 2.Defective exposure lamp or inverter PWB. 3.Incorrect shading position poor . 4.poor contact of the connector terminals Solutions:- 1. Replace the scanner PWB and check for correct operation. 2. Replace the exposure lamp or inverter PWB. 3.Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor. 4.Check the connection of connector YC7 on the scanner PWB, and the continuity across the connector terminals. Repair or replace if necessary.
Mar 24, 2009 | Kyocera FS-1118MFP Laser Printer
Canon CanoScan5000/5000F - light bulb out
TheComp, I tried what you suggested, but no luck. The scanner is dead. The computer does not even read the scanner through the usb. I called Canon tech support. They tell me that this unit is not serviceable and offered a 20% discount to buy another Canon scanner. No thanks. I don't need another piece of electronic junk. I'll wait for a sale to buy another make. Thanks for your help.
Apr 10, 2008 | Canon CanoScan 5000F Flatbed Scanner
Can recieve well, sends all black
The scanner is not receiving light. That is either because paper is covering the scanner, or the scanner light source is not working. In this case, make sure the connections are in place, if so, replace the scanner.
Feb 26, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Lamp replacement
Just replace the lamp! It's just a fluorescent light you can get anywhere. You don't need a new scanner, if I had to replace the scanner every time the lamp died I be in the poor house!
Sep 17, 2007 | Agfa DuoScan Flatbed Scanner
HP ScanJet 5300C Flatbed Scanner Logo
94 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
