Question about Samsung 997DF 19" CRT Monitor
I have a nice silicon graphics monitor.
I got nice silicon graphics monitor but i dont know how to use with regular pc. Can i cuse with a regular pc monitor. I dont see any power cable.
0 characters
1 Points
Aoc led showing a line of faded pixels after regular intervals
i encounter this and found out that the signal from pc is the source of the problem and not the monitor itself mine is failing video graphics card
Jan 26, 2014 | Computer Monitors
How to fix my monitor when its in sleep mode
I assume this is a Desktop computer:
The Monitor receives, graphics or text from the PC (personal computer) and displays it on the screen.of the Monitor.
If you see a message on the screen that says * NO SIGNAL * in most cases the Monitor is good, and the Monitor is either not connected to the PC or there is a problem with the PC Check the connections and the video card.
The problem could also be related a failure of the motherboard, memory or the processor
Let us know..
Nour Sabre
May 21, 2012 | HP W2007 LCD Monitor
Is there a generic power cable for this monito?
We have a generic AC adapter that will work on the SGI F180 monitor. Go to our web site at: and click on LCD power link. The correct one is the high current adapter, the F180 draws 5.8 amps at 12volts.
I hope this helps, if so please rate our solution.
Corporate Computer
Dec 29, 2009 | SGI Silicon Graphics Silicon Graphics F180...
I have 6 thin vertical lines of different colors on my lcd. dont know how to fix it
Test on another PC or another graphic card, if the same, it is a defect matrix. If still it warranty, make a reclamation.
Nov 09, 2009 | HP Compaq 1701 17" LCD Monitor
Monitor keeps blacking out, I need to do a power drain but can't remember how to do it!
i have the same problem i think. like, if i dont use it for a long time, it'll display a nice perfect image, but then it goes black. everytime i turn it on after that its only about 3 seconds then it goes black. i have 2 monitors right now and i know its not my pc.
Oct 09, 2009 | Acer AL1916W 19" LCD Monitor
SGI F180 Flat Panel Display no longer turns on.
If the power button does not stay on, the monitor might be burned out.
Aug 20, 2009 | SGI Silicon Graphics Silicon Graphics F180...
Silicon grphic 1600sw adapter to vga
You want the SGI Multilink adapter. Like the 1600SW it's long out of production though.
Ebay may be the best chance.
Feb 20, 2009 | SGI Silicon Graphics 1600SW 17.3" Flat...
The screen seems dead
Hi, normally monitors have an indicator light that lites up when power is applied. This changes color or another lites up when it receives video signal from the computer. If no light then most likely defective monitor. Possibly the only way to positively check is to replace it with another known good monitor and connect to the PC. Power up and there should be a display. If there is then the 1st monitor is defective, if still nothing then it is the PC that is defective. It might also be worth to check/replace the power cord and/or video cable if applicable. Hopes this works out for you. Good luck and post again how things turn up.
Aug 05, 2007 | SGI Silicon Graphics GDM 4011P 20" CRT...
Samsung 997DF 19" CRT Monitor Logo
18 people viewed this question
Top Samsung Computer Monitors Experts
Rugeshan Lanka
Rugeshan Lanka
Level 1 Expert
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Samsung Computer Monitor Expert? Answer questions, earn points and help others
