Question about Polaroid I533P Digital Camera
Camera my digital camera is broken. the lense wont go in, it is stuck outwards. can you help me?
  • 3 more comments
  • Anonymous Jan 31, 2009
    i have the same problem
  • Anonymous Mar 03, 2009
    i have the same problem and i did wat it say and it just wont popped
  • Anonymous Mar 24, 2009
    mi lense popped out and wont go bak in
  • Anonymous May 19, 2009
    same
  • Anonymous May 25, 2009
    My lens are broke and the pieces came out and it's jammed
    Problem Solver:
  • 7 Answers
My daughter just had this problem with her camera. The camera was off with the lens barrel extended. When I looked at it closely, I noticed that the inner part of the lens barrel was at a slight angle to the camera. I pushed firmly on the low side of the inner part of the barrel, and it popped the rest of the way out. Camera works fine now. Good luck!
Posted on Feb 10, 2008
Nikon Coolpix 4600. Lense cover does not close when camera is turned off or fully open when camera is turned on. I can move it all the way open with my fingernail. Seems like mechanical mechanism is...
Any sand in a compact camera is bad news - repair will be expensive. In your situation, I would continue to use the camera while it still works, and give serious thought to a replacement.
Jul 20, 2017 | Nikon Coolpix 4600 Digital Camera
I have a canon camera IXUS 105 and the lense is stuck out and when i turn the camera on it says 'lens error, will shut down automaticly, restart camera' i have restarted it many times but the lenses wont...
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Mar 05, 2011 | Canon Cameras
The lense on my panasonic DMC FS3 camera is stuck outwards and will not come back in.
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Apr 27, 2010 | Panasonic Lumix® DMC-FS3 Digital Camera
Lens won't retract, stuck in outward position
battery power/and or lens motor/ if lucky the lense connection, (Try removing the lenses and puting them back) may be a bad electrical connection.
Aug 11, 2009 | Kodak Easyshare Z812-IS Digital Zoom...
My camera wont turn on.
ur lens strip is broken by using in out lens dont use zoom it crecks ur belt. now send for service
Jun 18, 2009 | HP Photosmart M22 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Lense stuck
You have a cracked or stripped gear. If you ever took it to the beach it likely got sand inside. Even a little. You should try blowing out the gaps with compressed air from a can of air duster. If that doesnt work, you need it repaired
Feb 02, 2018 | Kodak EasyShare C663 Digital Camera
Zoom error
Hey MBB722,
What is most likely going on is there is something stuck in the lens obstructing its movement (i.e. sand). I don't know what you have tried and what you have not tried you can try placing the camera on a flat surface with the lens pointing upwards, and then press and hold the shutter button and while doing this turn the camera on. If this doesn't work you can try removing the batteries and waiting a minute or two and then reinserting. If these suggestions don't work you should have it looked at by an authorized service technician such as bringing the camera to a Geek Squad® precinct at a Best Buy™ store and they can send it out for service. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 01, 2008 | Fuji FinePix F470 Digital Camera
Lense wont come out
It sounds like the drive gear(s) are broken. Kodak generally doesn't sell parts for their digital products so you are stuck taking it directly to Kodak for service.
Mar 28, 2007 | Kodak EasyShare C340 Digital Camera
Polaroid I533P Digital Camera Logo
104 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
