Question about Compaq Presario 1200 Notebook
I want to upgrade my Compaq Presario 1200 AMD laptop Hard Drive - any limitations?
From the specs, and wikipedia http://en.wikipedia.org/wiki/Compaq_Presario_1200
I gather it has a 3300 rpm hard disk... do I need to match it, or will any IDE laptop HD work with this model?
Just looking to get a larger... say 25GB HD.
TIA
  • gamesunltd11 Feb 13, 2009
    I have 3 1985 compaque presarios I want to ugrade todays standards and sell.. can this be done and what do I need to do it?
  • 383 Answers
Several companies such as AMD and Cyrix are also developing processors which are completely compatible with Intel processors. This means that they are capable of emulating every processor instruction in the the Intel chips.
INTEL SOCKET INFORMATION
Intel designed a set of sockets. Each of these sockets supported a certain range of processors. Below we have listed the complete specifications and layouts of each of these sockets.
I want to upgrade my Compaq Presario 1200 AMD lapt - socket1.gif SOCKET 1 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
SUPPORTED PROCESSORS
169 Pins 17 x 17 PGA 5v SX / SX2, DX/DX2, DX4 OverDrive
socket2.gif SOCKET 2 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
238 19 x 19 PGA 5v SX/SX2, DX/DI want to upgrade my Compaq Presario 1200 AMD lapt - socket3.gifrDrive, 486 Pentium OverDrive socket3.gif SOCKET 3 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
SUPPORTED PROCESI want to upgrade my Compaq Presario 1200 AMD lapt - socket4.gif 237 19 x 19 PGA 5v/3.3v SX/SX2, DX/DX2, DX4 OverDrive, 486 Pentium OverDrive socket4.gif SOCKET 4 SPECIFICATIONS
I want to upgrade my Compaq Presario 1200 AMD lapt - socket5.gif> PIN LAYOUT
VOLTAGE
273 21 x 21 PGA 5v Pentium 60/66MHz, Pentium 60/66 OverDrive socket5.gifSOCKET 5 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
320 37 x 37 PGA 3.3v Pentium 75-133, Pentium 75+ OverDrive socket6.gif SOCKET 6 SPECIFICI want to upgrade my Compaq Presario 1200 AMD lapt - socket7.gif Slot 6 was thought and planed of, however was never actually ever implemented in any system.
PINS
PIN LAYOUT
VOLTAGE
235 19 x 19 PGA 3.3v DX4, 486 Pentium OverDrI want to upgrade my Compaq Presario 1200 AMD lapt - slot1.gifmg src="http://i.fixya.net/uploads/images/socket7.gif" alt="socket7.gif" class="h_mi" /> SOCKET 7 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
321 37 x 37 PGA Voltage Regulator Module Pentium 75-300, Pentium 75+ OverDrive slot1.gif SLOT 1 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
242 Slot Voltage Regulator Module Pentium II / Pentium III Processors
PROCESSOR HISTORY AND INFORMATION
Below is a listing of all known processor manufacturers made to date. In the below list is information about major processors listed by the date manufactured as well as a brief description of the technology and advances of each of the processors.
INTEL 4004 - Microprocessor introduced in 1970 with the speed of 108KHz was the worlds first microprocessor.
INTEL 8080 - Microprocessor introduced in 1974 running at the speed of 2 MHz was used in the world's first PC, the Altair.
INTEL 8086 (Code Name: P1)- Microprocessor first introduced in 1976. The 80086 had a 16-bit architecture that allowed it to work with 16-bit binary numbers and pass them through a 16-bit data bus. The 8086 was available in clock speeds of 5MHz, 8MHz, and 10MHz.
MOTOROLA 68000 - Microprocessor released in 1979 was later chosen by Apple for the Macintosh computer.
INTEL 8087 - Floating-point math compressor compliant with the 8086 / 8080 microprocessor family.
INTEL 8088 - Microprocessor released in 1979. The 8088 was the first Processor used in the original IBM PC and XT personal computers because it was less expensive than the 8086 microprocessor because of the availability of less expensive eight-bit data bus supporting chips made it the microprocessor for the IBM PC. The 8088 was available in speeds from 4.77 MHz and 8MHz.and used the 16-bit architecture allowing it to work internally with 16-digit numbers. The 8088 had the ability of addressing up to 1MB of RAM.
INTEL 80286 (Code Name: P2) - Microprocessor introduced by Intel in 1982 which commonly is referred to as the 286 processor. The 286 processor supported 16-bit architecture, supported virtual memory, and was available in clock speeds of 8MHz, 10MHz, and 12MHz. The 286 was around 20 times faster than the predecessor 8088.
INTEL 80287 - A compliant processor to the 286, a floating-point math coprocessor. Specially designed 286 chips have the capability of placing the optional 80287 processor on top of it, giving the computer a math coprocessor.
INTEL 80386DX (Code Name: P3) - Microprocessor manufactured in 1985 was the next generation of Intel processors. The 80386DX included the math compressor, unlike the 80386SX, and still featured the 32-bit architecture and built-in multitasking. The chip was available in clock speeds of 16MHz, 20MHz, 25MHz, and 33MHz.
SPARC - Released in 1987 is short for Scaleable Processor ARChiture by Sun - used RISC (Reduced Instruction Set) to speed up processing.
INTEL 80486DX (Code Name: P4) - Microprocessor released April 10th 1989. The 486DX featured a built-in memory cache and 32-bit architecture. It had more than three times the computing power of the 386DX and was available in clock speeds of 25MHz, 33MHz, and 50MHz.
INTEL 80386SX - Microprocessor introduced in 1989 was the next generation of Intel processors. The 80386SX lacked a math coprocessor but still featured the 32-bit architecture and built-in multitasking. The chip was available in clock speeds of 16MHz, 20MHz, 25MHz, and 33MHz.
Good Luck, Please dont forget to Rate/Thank You.
Posted on Jan 17, 2008
  • 56 Answers
Any IDE will fit, BUT there are at least two different IDE types. Parallel ATA (PATA), and Serial ATA (SATA). findout whether or not your laptop HDD is pata or sata, and then you can try looking at www.newegg.com and they will have good prices on new laptop hard drives. try looking for a 4200rpm or faster.
Need to replace pegatron motherboard nep253-69001
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01746796&cc=us&lc=en&product=3979942#N74
Scroll down a little. Stop at Motherboard - M2N78-LA (Violet)
1) Motherboard Size: 9.6 Inches X 9.6 Inches
(24.4cm X 24.4cm)
This means the Form Factor is Micro-ATX,
http://en.wikipedia.org/wiki/Computer_form_factor
http://en.wikipedia.org/wiki/MicroATX
2) Processor Socket: AM2+
http://en.wikipedia.org/wiki/Socket_AM2%2B
3) Motherboard Chipset:
Nvidia GeForce 9100
http://en.wikipedia.org/wiki/GeForce_9_Series#Geforce_9100G
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01635734&lc=en&cc=us&dlc=en&product=3979942
Since you have an AMD Phenom X4 9650 processor, make sure the new motherboard will support it.
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#.22Agena.22_.28B2.2FB3.2C_65_nm.2C_Quad-core.29
Make sure the new motherboard will support DDR2 Sdram ram memory, at 800MegaHertz. (800MHz)
That is PC2-6400
Up to 16GB of ram memory. Specs state you have 8GB installed now. (Product Specifications)
If you are running XP, Vista, or Win 7 that is 32-bit, you will ONLY see about 3.0Gb to 3.5GB.
You need a 64-bit Operating System for more than 4.0GB of ram memory.
Motherboard getting a 'little light in the rear-end'?
Check the Electrolytic Capacitors on the motherboard.
No. Not the Solid Polymer Capacitors. (Cylindrical small 'cans', with a Red mark on one side)
The Radial Aluminum Electrolytic Capacitors,
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
Yes, bad caps can be replaced. All you need is basic soldering skills.
Why do they go bad, and what makes me think other components aren't ready to go bad too?
http://en.wikipedia.org/wiki/Capacitor_plague
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 18, 2013 | HP Pavilion NP218AA p6142p Desktop PC -...
Ic for keyboard controller
It's the Super I/O chipset, or Integrated Circuit.
Uses an Intel 915 motherboard chipset, that is the mobile version. (For laptops)
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_M.2FCeleron_M_mobile_chipsets
Probably the Intel 915GMS, or Intel 915GM; since it uses Intel GMA 900 integrated graphics.
No matter because they both are paired with the Intel ICH6-M.
Intel part number 82801FBM
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Southbridge_9xx_and_3.2F4_Series_chipsets
http://en.wikipedia.org/wiki/Super_I/O
Don't know which manufacturer, nor model. Here is a list that may help you find it,
http://web.archive.org/web/20070929033214/http://www.esupport.com/techsupport/award/superio.htm
http://geekscomputer.blogspot.com/2008/07/super-io-chips.html
http://www.ebay.com/itm/NEW-HP-Compaq-V4000-DV4000-Motherboard-403894-001-/350314565363?pt=Motherboards&hash=item5190600ef3
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=468789&
HP Pavilion dv4000 Notebook PC and Compaq Presario V4000 Notebook PC - Maintenance and Service Guide
[Service Manual ]
WEAR an ESD wrist strap, and HAVE it's alligator clip attached to a good ground source.
Regards,
joecoolvette
Dec 11, 2012 | HP Pavilion dv4000 Notebook
PC Upgrade for a biostar p4m90-m7a motherboard
Biostar Support > P4M90-M7A > Main Support page,
http://www.biostar-usa.com/mbdetails.asp?model=K8M80-M7A
Uses a Socket 754 processor socket.
How pray-tell are you using an Intel processor that uses an LGA 775 processor socket?
http://en.wikipedia.org/wiki/Socket_754
http://en.wikipedia.org/wiki/LGA_775
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_Dual-Core_microprocessors#.22Allendale.22.2C_.22Conroe.22_.2865_nm.29
You aren't.
What is the motherboard manufacturer name, and model number?
Post back in a Comment.
However if we are to use the Biostar P4M90-M7A for an example;
Biostar main support page above;
Top right; small subheading -> Support
Click on the blue, (Purple?) subheading -> CPU Support
As for the motherboard in question that uses the Intel Pentium Dual Core E2200, find out what the motherboard chipset is, then you will know what CPU's are supported.
(You know now that the processor socket is an LGA 775)
Use CPU-Z from CPUID.com (TINY program, and Free),
http://www.cpuid.com/softwares/cpu-z.html
A) List of Intel Chipsets;
http://en.wikipedia.org/wiki/List_of_Intel_chipsets
B) Comparison of AMD Chipsets;
http://en.wikipedia.org/wiki/Comparison_of_AMD_chipsets
C) Comparison of Nvidia Chipsets;
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_chipsets
D) List of VIA Chipsets;
http://en.wikipedia.org/wiki/List_of_VIA_chipsets
The Northbridge chip of the motherboard chipset, handles the Processor. (Plus Ram Memory, and HIGH-speed graphics),
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
Regards,
joecoolvette
Nov 25, 2012 | Computers & Internet
I need to replace hard drive what kind
A) Harddrives are measured by their Width.
Laptop harddrives are 2-1/2 inches across in Width.
2.5
Desktop harddrives are 3.5
B) Harddrive technology has evolved from IDE (PATA) to SATA.
Doesn't matter if it is a solid state harddrive (SSD), it still uses SATA technology.
The Compaq Presario CQ70-120us Notebook PC, uses a
250GigaByte SATA 2.5 harddrive.
(250GB)
I know it's a SATA harddrive, by the manufacturer year period, and by the motherboard Chipset used. Specifically the Southbridge chip,
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=3795242#N259
Click on the + sign next to Chipset (1)
Intel Chipset Installation Utility for ICH9m for Microsoft Windows 7
The Intel ICH9m is a Southbridge chip.
(Part number Intel 82801IBM0,
SATA 3.0
One example of a harddrive replacement,
http://www.buy.com/prod/320gb-hard-drive-for-hp-compaq-presario-cq70-120us-cq70-124ca-cq70/221982377.html
[ CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply Processor for short,
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The motherboard chipset used in your laptop, consists of a Northbridge chip, and a Southbridge chip.
The Southbridge chip as we know, is an Intel ICH9m
A southbridge chip for a Mobile computer, or otherwise known as a 'laptop'. That is what the -> m, at the end stands for. Mobile.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_mobile_chipsets
Northbridge chipset will be a;
GL40, or GS40, or GS45, or GM45, or PM45
The Northbridge chip handles the Faster capabilities of a computer.
Processor, Ram Memory, and HIGH-speed graphics.
The AGP and PCI Express technologies are HIGH-speed graphics.
A graphics card in a PCI slot, or using Integrated Graphics; is NOT HIGH-speed graphics.
The Southbridge chip handles the Slower capabilities of a computer.
1) Anything using the PCI bus. (Like a PCI graphics card for one example)
2) IDE bus
3) SATA bus
4) USB bus
5) Ethernet
6) Audio (Sound)
Everything you didn't want to know, huh? ]
Regards,
joecoolvette
http://www.newegg.com/Product/Product.aspx?Item=N82E16834107022
Nov 12, 2012 | HP Compaq Presario CQ70120US Notebook PC
On an Acer 3100-1718 can I use the socket s1 turion x2 tl-64 without running into problems
Whoa! You are the MAN!!
http://www.cpu-world.com/CPUs/K8/AMD-Mobile%20Sempron%203500+%20-%20SMS3500HAX4CM.html
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors#.22Keene.22_.28Socket_S1.2C_F2.2C_90_nm.2C_Low_power.29
1) Socket S1 processor socket,
http://en.wikipedia.org/wiki/Socket_S1
2) Core Technology - Keene
Core Architecture - 90nm (90 NanoMeter. One nm = 1 Billionth of a Meter)
3) Voltage Range:
0.950 Volts to 1.125 Volts. (DC)
4) Front Side Bus = 800MegaHertz
5) Can use up to 25 Watts of power. (Thermal Design Point)
http://www.cpu-world.com/CPUs/K8/AMD-Turion%2064%20X2%20Mobile%20technology%20TL-64%20-%20TMDTL64HAX5DM.html
http://en.wikipedia.org/wiki/List_of_AMD_Turion_microprocessors#.22Tyler.22_.2865_nm.29_2
2) Core Technology - Tyler. Architecture - 65nm
FLAG
3) Voltage Range:
1.075 to 1.10 to 1.125 Volts (DC)
4) FSB = 800MHz
Same specs for the AMD TMDTL64HAX5DC
The Core technology concerns me.
Probably what is concerning you, huh?
Not a very technical answer, but,
http://www.ebay.com/ctg/AMD-2-2-GHz-Dual-Core-Processor-/74092943
,for 18 bucks I would go for it.
Won't hurt the motherboard, just won't work if it isn't supported.
Regards,
joecoolvette
Oct 22, 2012 | Acer Aspire 3100 Notebook
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
Click on the CPU tab.
(Features / Specification / Download / Support / FAQ / CPU / etc)
Will support Up To an AMD Athlon XP 2600+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Maximum Front Side Bus support is 266Megahertz.
(Max FSB = 266MHz)
(Motherboard manual states 133MHz.
Note that AMD processors are 'Double-pumped'.
This = 266MHz )
Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.
Note in the CPU Support chart where it states -
Socket 462 > AMD Athlon XP > 2600+ (.13u)
The .13u stands for 130nm core architecture technology.
(nm = NanoMeter.
1 Billionth of a Meter )
NOTE*
For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.
'Sempy', or Sempron processors are at the bottom.
Low L2 processor memory cache compared to Athlon XP or Duron models.
http://en.wikipedia.org/wiki/List_of_AMD_Duron_microprocessors
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.html
Regards,
joecoolvette
Oct 13, 2012 | EliteGroup L7VMM2 Motherboard
2.6 volt ram
For the Compaq Presario SR1920NX?
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3184154
Product information > Product specifications > Compaq Presario SR1920NX Desktop PC Product Specifications,
Memory:
PC3200
That is DDR Sdram, that operates at a maximum frequency rate of 400MegaHertz. (400MHz)
JEDEC voltage standards for DDR Sdram is 2.5 Volts,
http://en.wikipedia.org/wiki/DDR_SDRAM
(Specification standards
Read down )
JEDEC,
http://en.wikipedia.org/wiki/JEDEC
The motherboard, may not have SPD features. (Serial Presence Detect)
Do not know if the ram memory does, either.
SPD,
http://en.wikipedia.org/wiki/Serial_presence_detect
Sometimes it takes turning the computer off, wait 1 minute, then turn it back on. Sometimes it takes 2 to 3 times of this.
If BIOS doesn't set the voltage up 1/10th of a volt, you may have to do it manually in your BIOS Setup (Utility)
Where did you get DDR Sdram that uses 2.6 Volts, and is it high-performance ram memory?
Post the manufacturer name of the ram memory, and it's manufacturer code, in a Comment.
[The normal factory default setting for the ram memory voltage, is 2.5 Volts. I would see if BIOS Setup will allow bumping the voltage up, before I would EVEN think of a BIOS upgrade ]
Regards,
joecoolvette
Jun 02, 2012 | HP Compaq Presario SR1920NX PC Desktop
Will a AMD Athlon 64 processor work in a Compaq Presario SR1050NX Desktop? My old processor Died and I purchased one of these off of Ebay, now just want to make sure it will work...
No Donnie, the motherboard for the Compaq Presario SR1050NX won't support an AMD Athlon 64 processor.
The reason why is;
A) The Processor socket on the SR1050NX's motherboard is a Socket A. (Also known as Socket 462)
Hp Support > Compaq Presario SR1050NX > Specifications > Motherboard Specifications >
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00072236&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=405454
CPU = Central Processing Unit. Another term used is Microprocessor, or Processor for short.
Look to the right of the CPU heading:
Socket A (Processor socket)
This is the Socket A processor socket used on your motherboard,
You can click on the photo of the Socket A processor socket, to the upper Right, to enlarge.
The AMD Athlon 64 line of processors came out after the Socket A, and used the Socket 939 first.
Then on to the Socket AM2.
(Socket 940 for some models)
List of AMD Athlon 64 Microprocessors,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors
http://www.weirdstuff.com/cgi-bin/category/10201
Oct 12, 2010 | Compaq Presario SR1050NX (DW257A) PC...
Compaq Presario 1200 Notebook Logo
538 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
