Question about Panasonic AG-DVX100A Mini DV Digital Camcorder
Auto off s reel lock red flash
This is what I get after fast forwarding a miniDV tape
in the transport most of the time now. Often I have to
stop the tape, then start and 50% of the time banding
shows up or pixelized disruption.
I tried one pass of the supplied pany head cleaner tape
nothing changed.
Is this a head cleaning issue or is it an expensive
electronics/ repair issue? It has 244 hours on the meter.
Thank you very much
Bill Snyder 360-566-3043
mntmedia@gmail.com
  • bsnyder Jan 17, 2008
    Yes, that's not the issue.
    I know, I need to take it to digitronics in LA and I wasted my money for this service, right?
    I should have dug a bit further.
    Any other suggestions that have merit would be helpful, otherwise....
  • hawkesashley Oct 24, 2008
    I just got my dvx100a and put a new tape in with 85hrs on it and it says "auto off, reel lock" then shuts off....any solutions?
    Scholar:
  • 128 Answers
I personally am not an expert on cameras, but I bet Panasonic could help you! Try calling them at 800-211-PANA (7262)
Posted on Jan 17, 2008
    Sergeant:
    Champion:
  • 209 Answers
Did you try using a new tape?
Well I'll get back to you later...
Sony Tape Deck TC-630 D runs but the mechanisms that pulls the tape up to the heads doesn't move up when the control is turned to Forward. It moves just slightly, then stops like it's mechanically...
Commonly to all these older units and I have seen a lot of them, there are mechanical linkages that are not covered inn the owners manual as they were moving in the short term. Now after a lot of years the grease has turned to a glue or will be very thick. The mechanical links must be taken apart and regreased- I have done many but the problem is that it can take a lot of time to do this. Get a tube of Lubriplate from a Hardware store and go in and see where things do not move and that will be where the cleaning and grease will once put in make the deck like new.
Aug 19, 2013 | Audio Players & Recorders
I have a Teac A-6300 that won't go fast forward or reverse but the capstan motor is running
The Capstan motor is just for the play speed regulation so it has nothing to do with the reel motors. You can have an open safety microswitch or maybe a bad relay. It is really hard to say without looking at the unit but I am sure it is repairable. Is the right dummy plug put in the back? This can stop all transport functions if it is out.
Apr 14, 2012 | Teac Audio Players & Recorders
The auto stop mechanism seems to have completely stopped working. When play a cassette, it eats it. When you put the deck into play mode without a cassette and push on the pinch roller with your finger, it...
When's the last time it was cleaned? It surely needs it now.
Never touch the any part of the transport that directly contacts the tape with bear fingers.
This sounds like a failure of the take-up (left) reel to take up slack as it's fed in by the capstan.
You can probably trust the machine to fast forward or rewind a tape to test the ability of the reels to manage slack since either action only requires one reel to pull while the other just coasts. Failure would look like stationary tape that eventually would time out and reset the command.
If it won't do fast transport motions that eliminates the capstan/pinch roller.
If it CAN FF and REW then the capstan, pinch roller, heads or something is probably glommed up with sticky tape oxide, which brings us back to the first question.
Jun 30, 2011 | Panasonic RX-FS470 Cassette Boombox
I have a single cassette deck Philips DC 900 when you hit the play button,it plays for about 5 seconds then stops and head retracts. Belts have been replaced
It's not seeing the takeup reel turning.
Either the takeup reel isn't turning or the takeup reel sensor has malfunctioned.
Check the belt to the takeup reel by doing a fast forward.
Will it fast forward? and is the takeup reel spinning during playback?
Feb 27, 2011 | Audio Players & Recorders
VCR Model Panasonic NV-J45:- Until just yesterday, it worked fine, only last night I tried to play a tape, the green auto-tracking light flashed a few times as usual, then the tape just kept stopping, no...
The problem is caused by the idler assembly which controls play, record, rewind, and fast forward. If the take up reel stops, the vcr senses a problem and will stop the tape. The only other thing it can be is the drive belt, sometimes it will stretch and fall off or break. I suggest a tv technician or somebody that knows their way around a machine.
Jan 14, 2011 | Panasonic PV-9451 VHS VCR
I have a pioneer CT-F900 cassette deck, when I press play the reel side that should take up the slack stops and the tape bunches up and the drive mech disengages. The tape stops. Your help, please Steve
The take-up reel is dragging or the belt is stretched or broken. No surprise on a deck this old. Try Fast Forward. Try Rewind. Same result?
If it still doesn't work, and it happens with only one cassette, rap the cassette's flat side against a solid flat surface to loosen it. Try again.
If you're really an old-school deck user you probably know how to cheat the transport with no tape resent to make the capstans engage for cleaning. Try that. The two reels should spin opposite as if maintaining tension. If the right one is stationary or lethargic (try to feel how strong it pulls compared to the left one), there's a loose or broken belt.
Next step. Get out the can opener, go inside and see what's wrong. Good luck.
Dec 25, 2010 | Audio Players & Recorders
Hello I have a Kenwood KX-9050S and the right
Hi, you can check both the motor and the rubber the makes the motor move. you will need to change one of two.
May 19, 2010 | Audio Players & Recorders
''squeaks'' in reel to reel tape recorder
brakes need adjusting on the reel hubs
Apr 08, 2009 | Audio Players & Recorders
Tape won't play
I am assuming that the problem is with just the one tape...
Two things spring to mind - Either the tape has snapped or the reel lock mechanism is jammed.
1) Check the tape. With the cassette the right way up, press the little button on the right-hand end just behind the tape flap, flip the tape flap up and check that there is actually some tape there. If not, it's snapped.
2) With the cassette upside-down and with the tape flap facing away from you, you should see a small hole in the centre of the cassette about 2cm from the edge nearest you. Press something gently in here to release the reel locks. Then give both reels a couple of small turns back and forth (a finger stuck in the reel holes is ideal for this!) Before you put the cassette back into your machine, make sure there isn't any slack on the tape by gently winding any excess back in by turning the reels, but don't wind it to tightly - the moment you feel resistance, stop.
Hope this helps,
Matt
Mar 22, 2008 | JVC DF420 D-VHS Tape
Auto-stop malfunction and stuck cassette door
Hi I'm not familiar with your particular model, but the auto stop problem is common and is usually the result of a slipping drive belt, or bad idler/reel drive. The auto-stop works by popping a small tooth like plastic or nylon piece attached to an arm, when you runout of tape and takeup reel pulls the tape tight. The auto-stop mech can get contaminated with dust, and not work, or the reel for some reason does not pull the tape tight enough to fully engage that piece and the result is a ticking sound. As the deck now has your tape, I suspect the main drive belt is broken or probably slipping, and all will work fine if it is replaced. Although changing the belt is not difficult, you should probably take it to a repair shop, as getting the right size is important, and the deck may have to be dismantled to change it. Hope this helps, good luck!
Apr 28, 2007 | Sony PSYC ZS-D55 Cassette/CD Boombox
Panasonic AG-DVX100A Mini DV Digital Camcorder Logo
691 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
