Question about Dell Dimension 1100 PC Desktop
CD Drive The cd drive does not read any type of cd's (audio or data). the drawer does open and close, , I have checked in the device manager and that is no help either because the only cd drive that appears may also be in the my computer file but, this drive only acts like a virtual drive as there is no response to the eject command when you right click on the icon. But it is not a virtual drive so i have no answers. USED THIS SOLUTION BUT DID NOT WORK !! DOES ANYONE HAVE A ANSWER TO THIS ? Demmy Try this. Click the Start button, click Run, type regedit in the Open box, and then click OK. click the + sign next to HKEY_LOCAL_MACHINE click the + sign next to SYSTEM click the + sign next to CurrentControlSet click the + sign next to Control click the + sign next to Class Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318} Delete upper or lower filters. if you see them both delete them both.
    President:
  • 2,351 Answers
Your 1100 is not a new PC. Every CD/DVD reader, writer & rewriter out there only warrants CD/DVD players for 1 year. There is a reason. They are cheep. Everything you have mentioned points to a dead CD player. Replace your's. Here is a great place with good prices.
SAMSUNG SH-S202N 20X IDE DVD Burner Black Drive Bulk
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10007481
It is not hard to have this installed, you can do it your self. Enjoy!
Please vote.......
Posted on Jan 17, 2008
  • Mike Peluso
    Mike Peluso Jan 17, 2008
    PS. If you take a paper clip & straiten out one end of it. There is a hole in the face of the CDROM. With the PC power off. Take the straitened paper clip & slide it into the hole, there is a button release that you will come in contact with. Push harder & watch the CD drawl will open just enough for you to grab it. Pull it open by hand. Turn on the PC. Before windows finishes starting the CD draw should shut by its self. That is normal. I list this so you can remove any CD that may still be in the CDROM.
My drawer on my laptop will open but my cd is still stuck
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
if there is a small hole on the panel of your dvd drive push a staightened paper clip inside until you feel it press down this will open up the drive
if still no luck
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
May 27, 2012 | Computers & Internet
I have a Dell Inspiron 9400 laptop with a sony cdrw/dvd cr835e. The drive reads cds without a hitch. It will not read dvds. When I put a dvd into the drive, the drive attempts to read it quite a few...
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Sep 18, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
My dvd rewriteable drive does not read cd discs but only dvds, and it does not burn neither dvd or cd even though i have the proper burning tool.
what sort of burning software are you using it might be because you have not selected to burn data or an iso
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image
that seems strange if it reads dvd's it should read cd's
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jun 20, 2011 | Toshiba Computers & Internet
My dvd drives can read cd but cannot read dvd disc
that seems strange if it reads cd's it should read dvd's
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jun 15, 2011 | LG Computers & Internet
My LG dvd multirewritter is reading dvd's but not cd's ..why?
thats odd usually if it wont read cd's it wont read dvd's and vie versa
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jun 14, 2011 | Computers & Internet
LG GH22NS50 22X DVDRW SATA Drive wont read or write dvd but will read and write cd I am running xpsp2 and the drive is connected to the eide motherboaed by way of an eide to sata adaptor which is the same...
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or if this fails to fix the problem
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
if these fail to fix the problem
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected..
hope this helps
dont forget to vote
Feb 11, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Not reading off a cd or dvd et
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area if this fails to fix the problem
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
or if these fail to resolve the problem
It could be a problem with the lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
Feb 07, 2011 | ASUS (DVDRWM3N) DVD Drive
I had to restore my emachine to factory settings
Open "My Computer".
Insert a "data" CD, and hold the LEFT-SHIFT key down for a minute.
Watch the icon for the CD-drive change from the "standard" icon to something specific to the data CD.
Right-mouse-click on the CD's icon, and choose "Explore",
to open Windows Explorer to view the "data" files on the CD-disk.
Dec 11, 2009 | E-Machines emachines (emachinees) CD-ROM...
Packard bell CD rom
Cheak cd rom data cable pluge in maight be cable is unpluged and verify the port connection also
Jul 01, 2008 | Packard Bell GCD-R580B (gcdr580b) Internal...
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Dell Dimension 1100 PC Desktop Logo
62 people viewed this question
Alun Cox
