Question about Toshiba TDP-T30U Multimedia Projector
Sharper Imaage My TOSHIBA TDP-S26 DPL Projector is not putting out what I think is it's sharpest images. Especially the numeric and alpha characters. I've tried the sharpness adjustments. Not getting what I want. I am projecting out about 7 feet to a 75" diagonal flat screen. Is it me or the model I have. Any suggestions
    Problem Solver:
  • 17 Answers
This is an SVGA projector with a max resolution of 800X600. Even though it can accept higher resolution signals, they are scaled down to 800X600 which causes degradation and artifacting of the displayed image. Obviously setting your computer's resolution to 800X600 will result in the best image the projector is capable of. Standard definition video (480i, 480p, S-Video or composite) signals should also display very well. High definition signals like 720p and 1080i get scaled down to 800X600 with the same issues as a higher resolution computer signal.
One thing that can have a dramatic impact on the quality of your display if you are using Windows XP or Vista is tuning your ClearType settings here:
Posted on Jan 17, 2008
I have a Toshiba TDP SW80 projector. The image turns green after about 2-3 minutes of use. I tried replacing the cord supplying the image in case that is what was causing the problem, but it did not solve...
make sure that the you have the correct input per signal. rgb and component seem the same to the projector, but have different signals. reset the settings to factory default and select the correct input and match the resolution.
Nov 10, 2009 | Toshiba TDP-SW80 Multimedia Projector
Thin black lines: projector TDP-ET20
Do a factory reset to the projector. In my experience that fixes alot of image problems.
Sep 26, 2009 | Toshiba TDP-ET20 DLP Projector
Is toshiba TDP-S8 good projector because I bought it today for $ 300.00 used. Thank you
Toshiba's s8. Designed to deliver stunning images in breathtaking XXL format, the TDP-S8 features 2000:1 contrast, the latest DLP technology for brilliant color and sharpness, and 2000 ANSI lumens brightness for top performance. The product retailed for close to two thousand dollars. Due to problems production was discontinued. If it works for you then you got a good deal. Replacement parts are easily available on for reasonable prices.
Jul 01, 2009 | Toshiba TDP-S8 Multimedia Projector
How do I check the bulb hours on a TOSHIBA TDP-S26 PROJECTOR?
I found a similar issue with another brand/type of projector and used that solution. It worked!
Mar 23, 2009 | Toshiba TDP-T30U Multimedia Projector
Colors look smeared on screen
If the colour wheel on your projector is out of sync, you will get incorrect colours.
If it is out of focus, focus the lens assembly, if misaligned colours, perform a re-convergence procedure at a fully equipped work shop with a qualified Toshiba engineer.
Oct 31, 2017 | Toshiba TDP-T30U Multimedia Projector
Toshiba projector TDP-T30
i have the same one but it needs a new lamp i will buy one of your lamps off of you let me know a price
Nov 12, 2007 | Toshiba TDP-T30U Multimedia Projector
Faulty projector
You will have to give a Make and Model of your Projector.
Could either be your lamp that needs replacement or a faulty Ballast ( lamp's powersupply )
Nov 09, 2007 | Toshiba TDP-T45U DLP Projector
Toshiba tdp-t9 (everyday t.v.) with no hdtv hookups
Yes you can hook up your Projector to ur cable box thru componet to RGB conversion Cable. that will work. i am also there on
Apr 16, 2007 | Toshiba TDP-T9U Multimedia Projector
Toshiba TDP-T30U Multimedia Projector Logo
130 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
