Question about Brother MFC 6800 All-In-One Laser Printer
Reset MFC6800 to factory defaults
I need to clear all the dialing presets on a Brother MFC6800 I was given.  I'm not in any hurry, so if I get too frustrated, I can just clear all the numbers one at a time; I'd really rather just perform a factory defaults reset, though...
  • 11 Answers
Hold down MENU/SET while plugging in machine.
You shoule then see MAINTENANCE and some strange 'Y'
press 01 you should see Param Init
then press 99
that should reset every thing
Posted on Jan 19, 2008
How do I do a factory reset on Sony STR-DA3300ES receiver when the published method in the manual doesn't work?
While holding down TUNING MODE, press POWER on the receiver. All preset stations will be erased when you change
the tuning scale.
See some test modes
MEMORY CLEARING MODE
All preset contents are cleared when this mode is activated. Use
this mode before returning the product to clients upon completion
of repair.
Procedure:
1. While pressing the [TONE MODE] and [DMPORT] buttons, press
the [POWER] button to turn on the main power.
2. The message "MEMORY CLEARING***" appears and the
memories are reset to the default values.
3. When done, the message "MEMORY CLEARED*"
If you are a geek then try the SUPER MENU MODE .
Understand how to enter and exit the menu,
then See if Super reset on page 25 helps
Sony STR DA3300ES Service Manual Page 25
Oct 07, 2016 | Sony STR-DA3300ES
How do u get parental passcode
Try a reset
To restore the TV to its factory default settings:
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight System
and press OK. The SYSTEM menu is displayed.
3. Highlight Reset & Admin and press OK. The RESET & ADMIN
menu is displayed.
4. Highlight Reset TV to Factory Defaults and press OK.
5. If you have changed the default parental control PIN, enter it
now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults."
6. Highlight Reset and press OK.
7. Wait for the TV to turn off. The TV will turn back on shortly.
If you have not set a PIN, enter the
default, 0000
Feb 14, 2016 | Vizio E-Series E470I-A0 47" LED TV...
What is a 116-386 error code
Resetting to Factory Defaults / Clearing the Memory
You can selectively clear information stored in your machine's memory.
  1. Press Menu on the control panel until Maintenance appears on the top line of the display.
  2. Press the scroll buttons until you see Clear Memory on the the bottom line and pressEnter.
  3. The first available menu item, Paper Setting, displays on the bottom line.
  4. Press the scroll buttons until you see the item you want to clear.
    • Paper Setting: Restore all of the Paper Setting options to the factory default.
    • Copy Setup: Restores all of the Copy Setup options to the factory default.
    • Fax Setup: Restores all of the Fax Setup options to the factory default.
    • Fax Feature: Cancels all of the scheduled fax jobs in the machine's memory.
    • Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
    • Sound/Volume: Resets the sound and volume settings to the factory default.
    • Machine Setup: Resets all of the system settings, such as the machine ID, date and time, display language and save modes, to the factory default.
    • Set Report: Clears all records of your faxes sent.
    • RCV Report: Clears all records of your faxes received.
    • Phone Book: Clears the speed dial or group dial numbers stored in the memory.
  5. Press Enter. The selected memory is cleared and the display asks you to continue clearing the next item.
  6. Repeat steps 2 and 3 to clear another item.
  7. ORTo return to Standby Mode, press Stop/Clear.
http://www.support.xerox.com/support/enus.html
May 08, 2015 | Office Equipment & Supplies
I ned reset (lsu) for printer dell 1610n
[Clearing the Memory]
You can selectively clear information stored in your multi-function printer's memory.
Press <Menu> on the operator panel until "Maintenance" appears on the top line of the display. 1.
Press the scroll button ( or ) until you see "Clear Setting" on the bottom line and press <Select>. 2.
The first available menu item, "Paper Setting" displays on the bottom line.
Press the scroll button ( or ) until you see the item you want to clear.
Paper Setting: Restores all of the Paper Setting options to the factory default.
Fax Feature: Cancels all of the scheduled fax jobs in the printer's memory.
All Settings: Clears all of the data stored in the memory and resets all of your settings to the
factory default.
Sent Report: Clears all records of your sent faxes.
RCV Report: Clears all records of your received faxes.
3.
Press <Select>. The selected memory is cleared and the display asks you to continue clearing the next
item.
4.
Repeat steps 2 and 3 to clear another item. 5.
OR
To return to Standby mode, press <Return>.
[Page 130]
Dell Laser Multi-Function Printer 1600n User's Guide
ftp://ftp.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers/dell-1600n_User's%20Guide_en-us.pdf
Jun 12, 2014 | Dell 1600n All-In-One Laser Printer
How to reset the pages count of HP LaserJet Pro M1536dnf
Restore to factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name, phone number, speed dials, and any stored faxes in the product memory.
CAUTION: This procedure also clears all fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product.
1. On the product control panel, press the Setup button.
2. Use the arrows buttons to select the Service menu, and then press the OK button.
3. Use the arrows buttons to select the Restore Defaults
May 18, 2011 | HP Office Equipment & Supplies
6310 all in one printer
Thank you for contacting Fixya.
Please perform the steps given below in the given order to resolve this issue.
Perform a power reset of the All-in-One
1. Press the Power button to turn off the product.
NOTE: The product might not turn off after pressing the Power button. Continue to the next step regardless
2. Disconnect the power cord from the rear of the product.
3. Disconnect the power cord from the electrical outlet.
4. Wait 30 seconds.
5. Reconnect the power cord to the electrical outlet.
6. Reconnect the power cord to the rear of the product.
7. Press the Power button to turn on the product.
If issue still persists then please perform a partial reset on your unit. Please follow the instructions given below to perform a partial reset on your unit.
NOTE: A partial reset resets the following settings:
· All user menu settings are reset to the default values.
· All telephony parameter values are reset to the default values.
· Country and language user interface is reset to the default values.
· Fax memory is cleared.
Performing a partial reset of the All-in-One
1. Unplug the power cord from the product, and wait 20 seconds.
2. Press and hold # and 3 while plugging in the power cord to the product.
3. Release the buttons after the product starts up. The product will now be reset to factory defaults.
If issue still persists then please perform a semi-full reset on your unit and verify the results.
NOTE: Semi-full reset resets the following settings.
  • All user menu settings to default
  • All telephony parameter values to default
  • Initiate select country and language UI
  • Clear fax memory Clear fax journal information
  • Clear all speed dials/broadcast lists
  • Clear personal header information
  • Instant Share Settings
  • Wireless Settings Cleared
Performing a semi-full reset of the All-in-One
  2. Press and hold # and 6 while plugging in the power cord to the product.
Sep 04, 2009 | HP Officejet 6310 All-In-One InkJet...
Lc-32pd5x its a roof mount antenna not sure what brand it works fine on my other lcd
so you could not wait 1 minute while I wrote to you how to reset it?
by default from factory the pin code is 1234
heres the full user manual for your tv
http://www.cleverhome.com.au/user/Sharp-Aquos-Piano-Black-LC37PD5X-LC32PD5X-manual.pdf
if the code doesn't work heres how to reset the tv
HOW TO SET THE FACTORY PRESETS
Turn off the TV by pressing POWER on the TV.
After waiting for about 1 minute, press and hold down RESET and press POWER on the TV to turn on the
TV.
All setting items (except TV channel) return to the factory presetting.
note Password will be cleared after running the factory presetting operation.
You can run the Auto Installation again by using the following steps.
1 Turn on the power of the TV.
2 Press MENU. (Make sure the menu screen displays.)
3 Press left or right to select “Setup”.
4 Press up or down to select “Auto Installation”, and then press ENTER.
5 Press left or right to select “Yes”, and then press ENTER.
Jun 17, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How do I get off Military time?
Sorry if this posts twice...
To reset your Pure-Fi Anytime, do the following:
Press and hold the Source and Preset 2 buttons (shown below) on the top of your Pure-Fi Anytime for 5-10 seconds.
NOTE: The reset procedure will restore the Pure-Fi Anytime to factory defaults and all presets will be cleared.
Jan 21, 2009 | Logitech Pure-Fi Anywhere Portable...
Brother mfc6800 lcd screen replacement
Only an Authorized Brother Dealer would be able to puchase the LCD form Brother. Sorry!
Nov 23, 2008 | Brother Office Equipment & Supplies
Brother MFC 6800 All-In-One Laser Printer Logo
952 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
