Question about Dishwashers
Dishwasher won't clean
I have a kitchen aid KUDS01L, it is not cleaning. It seems to have plenty water and the water is hot enough.The liquid soap was still mostly in the holder. There is something still on the door that was splashed there before, it is not washing off. Any ideas on what to.
  • 2,039 Answers
IF WATER GOES IN MAYBE THE WATER DONT SPRAY AROUND MAYBE THE SPRAYER BLOCK REOVE AND CLEAN MAYBE DE BRIE INSIDE AIR PRESSURE WORK FINE FOR THAT CHEERS
Posted on Jan 17, 2008
My dishwasher is a kitchen aid and is leaving all the dishes and glass ware with grime and dirty what to do?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Jan 14, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishes and glasses not clean, seems like spray bars not turning water seems plenty ,no clogged filters
Hi
Daniel
Dec 13, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Palmolive liquid detergent was put in rinse aid recepticle.
I don't understand your question. But, I am going to try to answer based on a "given" I picked. Please read on.
Is the problem you put non dish washing soap into the dishwasher?
... and you want to remove it (soap) without removing ...
the receptacle?
the machine?
If you have non dishwashing soap in a dishwasher, the BIG problem is the suds, followed by the soap is not effective, and it cannot necessarily be removed from the dishes. The suds go from a couple little drops of soap to enough suds to fill Grand Central Station, including your kitchen. Am I close?
What I did when (I did it) this happened is, I put a product called "Anti-Foam" (I just HAPPEN to have a hot-tub) into the dishwasher which killed the suds. I cleaned the mess up off the floor, ran the rinse cycle only, dishwasher empty. Then, I ran the dishwasher again with dishwasher soap to make sure it was clean. THEN, I took the non dishwasher soap out of the cupboard where it sat next to the dishwasher soap and put it elsewhere!
So, what should you do? Go to the pool and hot tub place near you and get a small bottle of "Anti Foam" and do as I did. Expect to pay about $10.00 for the bottle.
Alterntively, you could remove the lower basket, sop as much water out as you can and then run the machine on a rinse cycle to see what happens.
While at the pool place, you might find a hot tub you like. Hey, you already have some of the chemical!
Thanks for your question at FixYa.com
Jan 02, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Does the two drawer use liquid or powder soap? Kitchen Aid Dishwasher is not washing things clean, there is a coating of dirty food particles on the dishes. Help!
About the soap: You can use both. I prefer tablets.
About the particles: Before putting the dishes in, remove the food with a brush ($2.00) in the sink and run the hot water from the faucet for a 1-2 min until it gets really hot.
Sep 30, 2009 | KitchenAid Dishwashers
Kitchenaid KUDP01 not cleaning dishes
Remove the accumulator assembly and check the chopper to see whether it's clogged or damaged.
Jul 02, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Jun 21, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Water is plenty hot,use rinse liquid
It is common thing the inside of a dishwasher is very nasty even though it cleans you dishes it is best to run a dishwasher cleaner through the unit ever other month I do my ones a mouth jet dry makes a good cleaner it is sold right beside the rinse aid
Apr 02, 2009 | Maytag MDB9600A Jetclean II Built-in...
Kitchen aid NOT CLEANSING DISHES
It sounds like you are not getting enough water to make the dishwasher function effectively. Could be a bad valve could even be that the spray arms aren't letting through enough water.
Jan 01, 2009 | Dishwashers
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
KitchenAid KUDR01TJ Dishwasher Cleaning Problem
Sinder...this sounds more like a water temperature issue than anything else. First, turn on your hot tap. If you can't hold your hand under it after it fully heats (over 125)...you should be okay. If not, raise your water temp or use the sani cycle to raise the temp. Change brands of detergent. Salt...I don't think so. You're using detergent...not soap...which would have been affected. Pressure should not be an issue...once the unit is filled, it makes its own pressure recirculating with the wash pump.
Oct 13, 2007 | KitchenAid KUDR01TJ Dishwasher
Dishwashers Logo
138 people viewed this question
Top Dishwashers Experts
