Question about Kenmore 74112 Gas Dryer
Kenmore 110.70212990 My dryer spins but there is no heat, maybe the fuses need changing where do I locate those fuses. From my under standing the dryer can still operate with a fuse burnt out but will not produce any heat right?
  • 2 more comments
  • tlthill Feb 14, 2008
    Hi i've got a problem with my dryer it rotates but wont heat up
    the model #is 97520100-75201
  • unskilledmom Mar 02, 2008
    Kenmore Gas dryer problem, model 110.70212990, serial MK5215997
    Not heating properly. Takes a few cycles to dry. Some times heat comes on sometimes not. Took off back panel. Can't find anything that looks like it can be replaced by an unskilled person. Cleaned out lint trap. Unhooked vent hose, cleaned out. Don't want to spend too much money on repair bill. Again, unskilled laborer here.
  • DIY_Moderate Sep 03, 2008
    Great walk-through for diagnosis!!!
    I still have a problem/need clarification, please ;o)
    I have the Kenmore 110.70212990 gas dryer. The ignitor glows, then clicks off after 4-5 seconds, suggesting the valve coils. Those buggers are $35 each - any way to test them to see if they are indeed the culprit(s) before I shell out $70?
    Thanks!
    Mike
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    It is true that a dryer will still function in some cases with a bad component. However, it depends on WHAT component and TYPE of dryer. You listed your dryer as a "Gas Dryer". If this is true, you may have a bad igniter that is keeping the dryer from igniting. If your dryer is electric, you may have a bad thermal cut-out and/or thermostat. All of these components (if they fail) will give the very symptoms you have described. If you could verify your dryer and provide me with an EXACT model number (located around the door opening), I can give you better advice, rather than speculate. Please post back with your information.
  • 3 Answers
Here, I found the answer to my question already ;o)
Hopefully someone else will be able to benefit as well!
http://fixitnow.com/2004/11/appliance-repair-revelation-burner.htm
Posted on Sep 03, 2008
    Sniper:
  • 88 Answers
For a Gas Dryer:
1: Check if the igniter glows, if the igniter glows for a short time, followed by a distinct "click" then shuts off, you most likely have to replace the valve coils.
2: If the igniter does not glow at all, you will need to check some electrical components with an electrical meter. (or "ohm meter"..)
First check the thermal fuse, typically mounted either on the blower housing, (for dryers with a bottom lint trap) or on the rear bulkhead, (dryers with a lint screen on top). If the fuse reads OL or infinite resistance, (open fuse) replace it and check for clear venting and proper airflow at your exhaust duct. If your venting is unrestricted, also replace the operating thermostat or thermistor, whichever your dryer has.
If the fuse checks ok, then check the the igniter by disconnecting the in-line wire harness from the igniter and reading across the two pins in the harness, if you read infinite resistance, replace the igniter.
If the igniter checks ok, read across the radiant sensor mounted on the side of the burn tube, you must remove at least one of the wires from the terminals for a correct reading, again, if infinite resistance, replace.
If this doesn't help you may be looking at some electrical issues in the temp select switch, etc. Hope this helps.
Posted on Jan 17, 2008
I have a kenmore 90 series Model number 100.66904692 s/n MH4501730 Dryer runs for maybe 10 to 15 minutes then shuts off. When you push the start button you can hear a clicking sound. After it sets f
YES NOT UR THERMAL FUSE.
BUT MAYBE AN OVERHEATING ISSUE
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Jun 14, 2014 | Kenmore Dryers
My Kenmore 400series 6942 electric dryer works, but doesn't get hot. Pulled the heating element had it tested. It shows good. Had three other relay/fuses tested. They show good. It has to be easy enough...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpg if there is no heat then one of the thermal fuses is bad you will need to check the continuity on them and replace the one that does not have any continuity
Jan 20, 2011 | Kenmore 400 6942 Dryer
I have a kenmore 70 series dryer that will spin but won't heat! I changed the thermo fuses, but still have the same problem - no heat!
1)Try reseting your circuit breaker - all the way off then back on. 2)Check element for continuity or breaks in it.
Jan 13, 2011 | Kenmore 63942 Dryer
Kenmore Elite gas dryer, ''NO HEAT''.
fuse is located behind rear panel of machine white w/2 blue wires coming to it
Apr 14, 2010 | Dryers
How do I find the thermal fuse to a Kenmore Dryer? It comes on and spins but no heat.
for kenmore dryer the thermo fuse, most often they are on the air duct. or located on the heating element can. The can is located on the bottom right in the dryer and holds the heating element..hope this helps pls do let me know
Jan 12, 2010 | Kenmore Dryers
Kenmore gas dryer model #76812690 will not heat.
does the dryer heat initially when you first turn on the dryer Or no heat at all?
the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
Apr 29, 2009 | Kenmore Dryers
Runs but no heat
It may not be your heating element. Your dryer lint vent pipe out the back of the machine or maybe out the side may be plugged. You have to pull the machine out and clear that pipe or rebuild it out to a soffit vent or static vent if it is in the attic, or out through your crawl space. This will make a huge difference. If that hot air and moisture doesn't get out of the machine it just goes back into your clothes.
Good luck!!
Mar 22, 2009 | Kenmore Dryers
DRYER SPINS BUT DONT HEAT UP
Right on the back of the machine. It is the size and shape of a 1/2 dollar coin held in place by 2 screws.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 19, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer spins but does not dry clothes
Good luck!!
Mar 18, 2009 | Kenmore 83142 Electric Dryer
Kenmore 70 Series
Unless the dryer is extremely old, you do not have a standing pilot. It uses and ignitor or glow coil which could be your problem. It could also be defective gas valve coils or an open thermal fuse. Since it is a gas unit, I recommend you call a technician.
May 09, 2008 | Dryers
Kenmore 74112 Gas Dryer Logo
348 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
