Question about Motorola Mobility i530 Cellular Phone
Back light intermittant
Backlight on flip open screen comes on for a few days then off for a few days when phone flipped open. Backlight on keypad always works. Assume it is ribbon cable failure -- how to disassemble and possibly repair??
You probably have a defective flex cable... comes with the lcd screen....
Posted on Jan 22, 2008
The lcd of m samsung z720 doesn't lit. but the keypad has a backlight on it. what is the most probable cause of this problem?
there is nothing wrong with your LCD, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
May 01, 2010 | Samsung SGH-Z720 Cellular Phone
V3 outer screen
There's a tiny magnet in the top of the flip, near the hinge.. try taking a small magnet and hold it over the keypad near the hinge, and see if it doesn't think it's closed, if that magnet didn't get put back in the flip, then the phone won't know it's closed.
good luck!
Oct 26, 2007 | Motorola Mobility RAZR V3i Cellular Phone
My samsung d600 phone does not display anything when i turn it on however the backlight only comes on what can i do to fix this problem can you please help me
hello,
from the fault mentioned about the screen not coming on only the backlight, are you sure the phone didn't fall. if it didnt, then i can assure you that the problem is from the flex, that connects the screen to the keypad as a result of damage on the slide which is common in flip and slide phones.
the solution is for you to replace the flex of the phone. also known as the slide.
goodluck.
Jan 29, 2010 | Samsung SGH-D600 Cellular Phone
Screen not lighting up
even if you flip the phone closed the blank screen still stays white. i think the problem was the charger i had. it was to a razr and the dc output is not the same so i think i might of overcharged it at one point or time. what i did was let it run down till completely dead then charged about 10 min. when you turn it on just try to push as many as the buttons as you can at once.. mostly the top ones and soft keys. that might get the screen to come on.. then if it does change your backlight timer to like 5 seconds so when you use your phone the screen will go out when your done and it will not drain your battery.. well i hope it helps. it worked on mine
Jun 25, 2009 | Motorola Mobility V600
Blackberry Pearl 8220 backlight slow to respond
That sounds really annoying. If its not a hardware issue maybe you could look at the screenlight app to force the light on.
http://appworld.blackberry.com/webstore/content/6808
Jun 19, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Display on pearl flip when closed is always black
John-
It is possible the backlight or the LCD itself got damaged. The good news you is you can replace it.
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Checkout the guide I wrote for replacing the blackberry flip LCD displayscreen. There are also links to by the new pearl flip LCD screens2.gif
Blackberry Flip 8220 LCD screen Replacement Guide
Jun 03, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
The outside camera on my phone always comes on in my pocket. How can I put my outside camera on lock and still use my camera while my phone is flipped open??
this might work it did it to mine 2, the camera button on the side might be jammed. try to unjam it. another problem is that it might be to sensitive
May 28, 2009 | Verizon Communications LG VX8350 Cell...
BACKLIGHT STILL ON
How wet did it get? Was it submerged? The backlight would normally shut off after a short idle period or when you close the cover. If it is staying on all the time after water damage then there is still water in a component (like a capacitor) or corrosion that has opened or shorted a circuit path somewhere confusing the phone. There is a good chance that corrosion will become worse and do more damage. New problems could arise any time in the next few days or few years. If this were my phone I would disassemble it and clean it with rubbing alcohol, toothbrush, and air duster but there is some risk even for someone experienced. Also, microphones can be damaged by fluids including rubbing alcohol.
Jul 08, 2007 | Pantech C300 Cellular Phone
Motorola Mobility i530 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
