Fujitsu 36CS Air Conditioner
Problem for Fujitsu 36CS Air Conditioner
Low temp conditions
By HVAC TECH 1 on Jan 17, 2008
I have a 3 ton cooling only unit that will only work down to 0 degrees F. I know this is the factory limit but the problem is the unit cools a server room. I need to make this unit run at a colder temp. I was thinking of interupting the outdoor air thermister with a 75 k ohm resistor. Will this work?
Comments:
Jan 17, 2008
- This unit is aou36clx
Solution #1
posted on Jan 17, 2008
Not Rated)
bobotfel
Rank: Guru
Rating: 87%, 282 votes
75k ohms resistor is lower than 0 degrees F in equivalent temperature may be compressor cannot operate because the maximum setting of thermostat. is from 17 to 18deg. C. You can use 11 to 12k ohms the temp. for this is about 23 to 24 deg. C. The resistor resistance is fixed so the compressor continue running without cut out. The only problem for this is the compressor, because the design of the compressor is for high temp. Continue running of compressor can produce icing in suction and evaporator coil and cause damage of compressor due to liquid slugging.
Comments:
Jan 18, 2008
- Thats why the coolest setting of the thermostat is 17deg. C because the design of is the for the compressor is for the the high temp. Even the chillers or centralize air conditioning the lowest setting temp. is 42deg.F or 5.5deg C setting the temp. lower than this can damage the compressor.
Jan 18, 2008
- Actually you can bypass your themistor with resistor, but its still useless because running the unit lower than 0deg. C can form icing in your evaporator.You can use 11 to 12k ohms the temp. for this is about 23 to 24 deg. C. The resistor resistance is fixed so the compressor continue running without cut out.
Was this helpful?
Yes
No
Popular Solutions for Fujitsu 36CS Air Conditioner
Questions and Unsolved Problems for Fujitsu 36CS Air Conditioner
Do you recommend Fujitsu 36CS Air Conditioner?
Answer
Answer
There was a wreck with a gas truck and a train about 4days ago and it mest up some power lines down... (More)
Answer
Our fujitsu invertor airconditoning unit is making a high pitched sound when operating. We had it... (More)
Answer
the timer light keeps flicking and the air con doesen't work ???
Answer
all the lights keep flashing on & off and absolutely nothing is happening when i try to turn the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu 36CS Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
