Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
Shut down lacie
Why does not my lacie external drive does not shut down when i shut down my pc
Should be a power switch on the back of it. Most external hard drives have to be shut down manually.
Posted on Jan 17, 2008
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
For additional questions please post in a Comment.
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
When my lacie external hard drive is connected,my
Check your BIOS > StartUp sequence
Maybe the USB boot option has much higher priority that HDD boot. Try exchanging their priority and then reboot, with your external HD connected to pc.
Jan 03, 2010 | LaCie (300951U) 500 GB Hard Drive
First time trying and i cannot access my data. This is the first time I tried to pull it up.
USB is very finnicky. Shut off your computer and external drive. Unplug the USB cord from one end (which ever is easiest). Turn on your computer. When windows is up, plug in USB cable. Turn on USB drive. Windows should recognize the USB ox and drive and attach the extra drives. But, you must have windows millenium or newer. Or you will need USB drivers for the external USB box.
May 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 500gb quadra external drive won't boot using USB cables.
Microsoft has had some issues in regard to external devices (especially after running some updates). There is a registry patch for this situation. Click below to install the patch. It should fix your external drive problem. All the best!
May 19, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
No external drive icon on desk top
This happened to me as well - i have been reading that it could be the power supply adaptor. If you can try another one - it might solve the problem. The adaptors seem to either be faulty or made to stop working. Great news for us the consumer!!
Dec 16, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Data recovery from a bad power unit
Your data on the HD is probably OK, If the PC powers up and then shuts off it usually is a heat problem. If it shuts down quickly it may be a sensor on the motherboard that detects heat and may be bad and the motherboard will need to be replaced.
If it runs for a minute or two then shuts down there is heat somewhere causing problems with the processor and the motherboard is protecting the system. Check the fans inside the PC, specifically the small one on top of the processor, then the case fans. Also check the power supply fan and see if it is working, if not the heat may be cutting the power supply's power to the PC causing the shutdown.
Sep 23, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
External hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Aug 08, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
External hard drive not openning
Good News, Your data is probably still safe. Go to best buy or online and buy a new cheap external usb case for your harddrive. you can find them for about 7-25 bucks. Make sure you get the right one for the hard drive in your lacie. Take the hard drive out of the lacie case and put it in the cheap case and you will have your data back. I had this happen to me before. If you need help just ask me... Hope this helps you
Jul 15, 2008 | Computers & Internet
LaCie Hard Drive
The hard drive has it's own power supply. If you look on the back of the external hard drive, there is a power button there to turn it off. It doesn't shut off just cause you disconnect it from the PC or turn the PC off.
Feb 01, 2007 | LaCie (300951U) 500 GB Hard Drive
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
161 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
