P4 processor reboot
Hi
i unclipped the fan to clean it but ithe whole unit came away cant start at all,i have put it all back nothing....
plz help................
  • 39 Answers
Pc turnoff and fan clip conect your pc.........
Posted on Jan 17, 2008
My led and keyboard and mouse light up when I turn on power switch, nothing happens when I push start button. My e-mail address is debandeddy@yahoo.com
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Sep 14, 2010 | ASUS P4VP- MX VIA P4M266A UATX P4/...
We have a samsung side by side fridge freezer dispenser model and the fridge side has stopped working but the freezer does appear to still be functioning. The fridge temp control keeps restting itself to...
Hi. If you remove the light unit ond the lower casing which has four screws two of which are under the small vent covers that unclip. The light unit by the way has two screws under the difuser and that unclips. Mark the top before removeing with tape to give ease of replacement. After removing the top light unit inside the fridge and unclipping the two electrical terminals it can be removed. The same is true for the lower unit. Be aware the lower unit will be frozen in place. Ease it away to break the ice seal and remove the electrical connections. Use a hairdrier on full powar to fefrost the cooler unit at the rear of the fridge. Use the same method to defrost the removed fan unit. Pay attention to the fan drain. It may need the insulation trimming to make it drain and work again when re installed. Cut it away with a craft knife. When it is dry and defrosted re install in using the reverse procedure. Be aware it will frost up again and need you to do the whole thing again as soon as the fan gives signs of fouling on ice. You will hear it catch. Regards. Paul.
Mar 16, 2010 | Samsung RS2630SH Side by Side Refrigerator
P4 System w/ Intel D865GBF Sckt 478 reboots on shutdown
it sounds like a component is overheating.  clean out all the dust from all the components and make sure the case is getting positive air pressure (more fans blowing in than out) as opposed to negative (more fans blowing out than in).  if you don't have more than one fan, then get some at newegg.com since you're running an old p4 which isnt exactly notable for its efficiency in power use (and consequently temperature).  if you're running a discrete graphics card as well, you'll want to make sure thats keeping cool.  since it isn't windows, these two components are the most likely above all other suspects.
May 18, 2009 | Intel D865GBF Motherboard
ASUS P4-533 won't power up.
Please disconnect all the connectors and put them one by one and try following DYI
1.Refix the connectors and the check the power is coming.
2.If the power is coming in the machine and the fans are moving then the issue is with the RAM refixing open the cabinet and then refix the RAM module and it will work.
Feb 19, 2009 | ASUS P4-533 Terminator (terminator p4)...
Desktop problem
Check your processor fan it might have dust on it. your pc seems to be heating up. clean processor fan properly. all noise should go away and the perfromance will come back to normal
Jan 15, 2009 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
My Computer will not work fans did work but have also now stopped
You may want to make sure that both the atx connector and the additional 4pin p4 connector are tight. Also, either tighten or remove all expansion cards because one could be loose or bad. You may also try re seating the cpu. It could also be the voltage switch on the back of the power supply (if it has one -- some do some dont). There could also be something shorting between the motherboard and the case.
Could also be the case that the initial cpu is fried due to no grease and the new cpu may not be compatible with that motherboard. Make sure that if that motherboard has jumpers that they are set correctly for you specific cpu.
YOu can find documentation and driver for your product here.
Hope this helps. Please remember to rate this information.
Thanks
Nov 15, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Processor fan
Maybe you have not put the correct fan on and it has shut down to protect itself. Processors overhead catastrophically in a matter of seconds. Also did you connect the fan to a power supply on the motherboard.
Mar 18, 2008 | Intel (SL5TL) Pentium 4, 2 GHz Processor
My processor won't start
I guess your Power Supply Unit causing the problem, try using other power supply
Mar 11, 2008 | Computers & Internet
Drk black page print
Are all the colors in the correct slots on this printer?
Dec 29, 2007 | HP LaserJet 2550L Printer
How to install intel processor cooling fan?
Hi, the strips sound ike thermal strips. Install the processor, apply the strips onto it just wide enough to cover the centre of the unit and then install the heatsink and fan on to that. Regards mistyman
Sep 24, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
