Question about Westinghouse Dishwashers
WESTINGHOUSE 920 DISHWASHER WILL NOT FILL
Hello, Our Westinghouse 920 Dishwater will not fill with water.
I have removed the filler hose and both ends appear to be clear.
What should I check and how do I remove the kick plate from the bottom/front
of the dishwasher for easier access. Hope you can help. thanks, Darryl
6ya staff
SOURCE:
douglas smith
  • 1462 Answers
SOURCE: dishwater fills with water, hot...but doesnt wash?
when in the wash phase, listen for a low hum near the wash pump. if you hear this it indicates the wash pump capacitor is faulty or something jammed in the pump.after that you will have to access the wash pump and check if there is any supply to it
Posted on May 04, 2007
Anonymous
  • 49 Answers
SOURCE: whirlpool dishwasher adp550
f4 is a drain error, machine is still sesing water has not pumped out after 4 minutes of draining
1st check and see if water is still in bottom of machine if so check for blockeges under sink where drain hose cnnects to drain pipe.
if water has drained out you may have an water sensor fault or worst case an electronic control board fault
to reset machine hold the start button in for at least 3 seconds and it should do a drain and stop
Posted on Feb 19, 2008
appldoctom
Thomas Malailua
  • 311 Answers
SOURCE: White-Westinghouse washer will spin but water will not spin out
no its a remote electric pump,no belt.its ither blocked or fail.cut power,pop top remove frount cover an you will see pump.white or tan.remove hoses[watch out 4 water and check 4 blockage
Posted on Jan 02, 2009
Anonymous
  • 89 Answers
SOURCE: water does not fill .
chances are, your water switch is stuck..
its the thing inside the dishwashe that kinda looks like a plastic mushroom.. (its a float)
sometimes they get corroded with excess detergent.. wiggle that up and down some to free up the float and it just might fix your problem.
Posted on May 25, 2009
Anonymous
SOURCE: Westinghouse LCD TV freeze
I have the same problem ..... i just give it a good whack on the top of screen and the picture comes back.
Posted on Sep 07, 2009
Westinghouse 920
This most likely the fill valve that is leaking. See if there is a valve that is connected to it under the sink, turn it off and see if it still has the problem. If the problem goes away you need to remove the unit from where it is installed and replace the fill valve.
Feb 09, 2014 | Westinghouse Dishwashers
Westinghouse Dishwasher 905,prewash light keeps flashing and wont start to next cycle.Turn it on it makes the pump noise then the light just flashes.Help please.
Gary Miller was closest. You can also try this:
After the outlet hose has drained, open the dishwasher door and blow hard into the outlet hose (try not to get any gunk in your mouth! I usually put my hand in between the hose and my mouth.
You will find a bit of resistance then it should clear. Remove the filter (the one you remove and clean after every wash) and see if there is any gunk in the sump. Remove what you can by drawing the water out as best you can and using a rag to remove the gunk. Close the door and see if it tries to fill. Let it fill for a while until there is some water in the sump. Do the blow through the outlet hose trick again to see if it has cleared.
If you ket the dishwasher drain via the outlet hose, any gunk in the hose will end up clogging it again.
Apr 18, 2011 | Westinghouse Dishwashers
I have a Dishlex Global 500 dishwasher (DX500lWW*b). Woke up the other night to find water all over my kitchen floor. The hot water hose connector to the hot water tap split (bursted). The dishwater was...
I found this
"Hi - answer I was given by Electrolux Help was: pull machine out from under bench onto old towel, tip GENTLY onto left hand side (your left as you face the front of the machine) after it has drained, stand up gently, put back & turn on. Apparently it is the overflow trough reading as full ('oF' Overflow). Then run through some dishwasher descaler or Finish dishwasher cleaner. Worked for me."
http://www.howtomendit.com/answers.php?id=79783
Oct 05, 2009 | Dishwashers
Water does not fill .
May 25, 2009 | Westinghouse Dishwashers
Westinghouse SB907 - Water draining out right after filling up
The drain hose has to have a loop in it. In other words as the drain hose exits the dishwasher, it must go up at least 18 inches before it goes down into the drain. If not, the water will siphon out of the machine.
Apr 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Our westinghouse 921 does the first part of a cycle then switches off
most likely if your dishwasher fills and then stops with clean water still inside and hasent drained your problem is most likely your pressure switch is sensing an over fill situation possibly a blockage in the pressure switch hose or split in pressure switch hose or a faulty pressure switch.
Mar 29, 2009 | Westinghouse Dishwashers
Jan 02, 2009 | Westinghouse WWS833ES Super Capacity Top...
Dishwashers Logo
63 people viewed this question
Top Westinghouse Dishwashers Experts
GPEC
Level 1 Expert
The GreyOne
The GreyOne
Strech
Strech
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
