Question about Intel Core Duo T2600, 2.16 GHz Core Duo (BX80539T2600) Boxed Processor
Laptop will not power up!
When I press the power button on my Dell Inspiron E-1705, the power light and blue tooth light both come on for 5 seconds and then go off. No hard drive activity, no beeps no video, no disk drive activity or lights! I have swapped memory, removed hard drive and tried to boot, used an external monitor, tried a new power supply and battery, tested both fans for CPU and video card, reseated everything several times, replaced heat sink compound (it turned to dust when I removed the cooling coil from the top of the CPU), replaced mother board, replaced video card, checked for poor ground locations! Nothing!
The thing died about 3 months after warranty from dell ran out. Is the CPU the only thing left to replace? I am hesitant for obvious reasons ($500) but I don’t know anything left to check. This thing just locked up one morning and I had to hold the power button to power it down. It came back up for an hour or so and powered itself back down. I then backed info up and dumped the op. system, reloaded everything and it ran all day with no problems, noise, or alarms and was running faster then it did out of the box! Then after I got everything back to normal and powered it down and back up, it wouldn’t boot, only after removing all power sources for 18 – 24 hrs. would it boot, but after the dell screen it would just die. No beeps no noise, now it won’t do anything. The power led and blue tooth light up for 5 seconds and then just go off. I have been trouble shooting this thing for 4 months now and am at my braking point. Can someone please help me!?
  • Tim Bodie
    Tim Bodie Jan 23, 2008
    Yonah T2600 Intel Core Duo 2.16GHz QHJJ 2.16/2M/667 (pin 478) is the processor I have in my Dell Inspiron e- 1705 laptop... Thanks for the link!
  • lbmax3331 Mar 11, 2009
    I am having the EXACT problem as bodie2112 dell 1705 2 gig XP OS. T72 cpu. Will not power up unless you tilt the screen to an exact position 5% of the time it works, if you move the screen at all it will power off...and may or may not reboot....thanks for any insight!
I am having the same freaking problem. I took out my cpu and looked at it, the side by the last row of pins are blackened a little. it looks like something burnt it up. I am now looking for a new one, but cant find one on ebay., They look pretty cheap though. I think this might be the same problem your having. Anyways email me and if I find out anything else ill let you know, and if you figure out what might cause this let me know.
thanks my email adress is daddyforty@yahoo.com
Posted on Jan 27, 2008
  • 95 Answers
If you have replaced the motherboard I would say it is most likely the CPU. If you had not replaced the m/board I would think it was one of the power chips on the board that sends power to the cpu. If the heat sink compound had turned to dust on the top of the cpu that is certainly not going to help with cooling the cpu down. $500 sounds awful pricey for a CPU. What type and speed is it? May be able to dig one up for you in the basement that will work. At least for testing purposes. Post your type and speed of cpu that will work in your laptop.
Posted on Jan 23, 2008
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 1525 does not power up. i powered
Hi
Thank you for yuor query
Please can you try the following
1) Remove battery
2) Remove wall charger
3) Press and hold the power button in for 30 seconds
4) Plug in wall charger only
5) Retry powering the laptop and if it switches on plug battery in after 5 minutes
Regards
Shauqat
Apr 28, 2010 | Dell Inspiron 1525 Laptop
Does my 1550 have blue tooth
Here's a rundown of what you don't get in the Inspiron 1501 that comes standard with the Inspiron 1505, I am assuming yo did a typo with the 1550
  • No dedicated media buttons on the front
  • No Dell Media Direct software feature
  • No FireWire port
  • No S-Video port
  • 3-in-1 card reader instead of 5-in-1
  • No internal Bluetooth option
But if yours is the 1501 then just buy a $7 blue tooth doogle that slots into your usb then your bluetooth problem is solved.
Nov 28, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1705 9300 17inch shuts down after 15-20 mins win xp
first thing to do is run psa test. turn off laptop. remove batt use ac adapter alone. press and hold on Fn key then press power button once. complete the quick test check if you will be getting error codes like 0142 , 0146 this is hard drive replacement.
Oct 01, 2009 | Dell Inspiron 1501 Notebook
Delll Inspiron 2200 Laptop does not power on
You have all the simpthoms of an overheating laptop.
For starters, get a vacuum and **** all the dirt from the fan or fans on the back/ bottom of your laptop.
Then turn on your laptop. It should stay longer than 5 seconds.
If this solves your problem, then you are lucky.
If not, you'll need to have your laptop serviced, and clean the heat sink, and have reapplied the heat transfer compund on the processor.
Not a big deal, and not that expensive either.
If this answer helps, please don't forget to rate.
Jun 22, 2009 | Dell Inspiron 2200 Notebook
My Dell Inspiron 1000 Laptop would not power up.
possible power supply are motherboard possible bad pin on board
Mar 28, 2009 | Dell Inspiron 1000 Notebook
BLUE TOOTH PROBLEM
blue tooth are optional for Dell laptop...to veriffy if your laptop have Bluetooth built in..go to dell support web site and type in your Service Tag number...then Go to Original specification Tab
Here is the link:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?~ck=ln&~tab=1&c=us&l=en&lnki=0&s=gen
Mar 06, 2009 | Dell Inspiron 1501 Notebook
Intel Core Duo T2600, 2.16 GHz Core Duo (BX80539T2600) Boxed Processor Logo
371 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
