Question about Ricoh Aficio FX10 Fax Laser Printer
Can't print from domain PC's
I have just upgraded the PC with the ricoh fx10 multifunction on it and it will print with administrative permissions but ordinary users cannot use it
because of the way the print driver works
what do I need to do to get ordinary users to print?
  • gotty Apr 01, 2008
    I have already found a work around by making the user a poweruser from the domain on the local machine
Try to call this phone number for help they can assist you at 1-800-577-4264
Posted on Mar 31, 2008
6ya staff
SOURCE:
I can't download flash-player.
If you don't have administrative permission to install programs on your machines, then its highly likely that you are in a domain controlled environment like a school (am I getting close?), or other organisation.
The reason administrative permission is required is to protect the domain from damage by malware and copyright protection etcetera.
In short, the administrator doesn't want you to view video and trying to circumnavigate him will lead to tears.
Besides, any solution that would allow you to do this would require an installation and you cant do that since you're not an admin.
May 02, 2014 | Mozilla Computers & Internet
Cant open ricoh fx10 to get to toner cartridge
open front dor . turn grenn lever right , pull out the toner support
Oct 31, 2013 | Ricoh Type 1110D - toner cartridge for...
Access local disc C
You may have to remove it from the domain and deleted the object in AD. Then re-add it. You locked out all trusted domain users, and possibly including yourself.
You also try logging in locally and adding the domain account to the Administrators group. You need rights for all this, so you may have to have a domain administrator do this for you.
May 01, 2013 | Computers & Internet
Form feed message
if ur using print servers
check properties for print permission or promt for print
May 23, 2012 | Ricoh Aficio CL7300D Laser Printer
Cause of user profile not loading
The question is:
What causes a user profile not to be loaded in Windows domain based network?
the answer is:
there are probably 3 broad reasons for this,
1. the user corrupted their profile somehow, such as shutting down without logging off (hard power off)
2. the connection to the domain was lost ungracefully, and offline information was not copied entirely, causing a mismatch of some encrypted profile data, (effectingly corrupting again) and preventing the logon.
3. an unknown event took place between the last time the user sucessfully logged on, and this time where the profile is now not loading. this could be hardware related (faulty Hard disk), RAM parity errors( bad memory), a change to the user profile SID details on the domain controller or other domain change.
Usually the cause is not so much a problem, unless it consistantly reoccurs.
Fixing it however, in XP is fairly easy.
with an account with domain admin rights, just navigate to the UNC path "\\computername\c$\documents and settings" - note the name of the folder/user affected, and just .old their profile folder.
example, username is Philip. - you see in their c:\documents and settings\ folder the folder called Philip, rename it to philip.old or something else.
You have to ensure this is done while the user is logged off, as files in this folder will be in use otherwise. potentially useful to reboot the computer before navigating to the profile folder.
Jul 11, 2010 | Microsoft Windows XP Professional
Smoke
well this is really dangerous...this shows a power problem with the printer...so better let the device cool down and change its location before printing
Jun 07, 2010 | Ricoh Aficio FX10 Fax Laser Printer
Two domain controllers. Rights and Policy conflict
The system administrator must administrate the system. You should never have a system administrator that you don't trust. Technically, you would have to make the company president the system administrator and then create a domain administrator on a second server that has control over just that server. So the president could control all of the permissions of the entire organization but the system admin could control whatever users the president allowed him to.
Oct 26, 2017 | Microsoft Windows Server 2008 Enterprise...
Cannot print large PDF files on any of the Ricoh multifunction printers
what are the modle numbers ? can you print to them if you send smaller packets to them ? if so you may need to upgrade the memory in them.
Mar 16, 2010 | Ricoh Aficio GX3000 All-In-One Printer
Domain users can not print in domain
you need to chek the permissions on your server for the printers make sure everone has the right to print
Apr 21, 2009 | Office Equipment & Supplies
Ricoh Aficio FX10 Fax/copier
I called the Ricoh 800 number at 1-800-577-4264 and they found me a local tech to fix the problem it is a motor/or part proble code try the number and they can help you out.
Feb 29, 2008 | Ricoh Aficio FX10 Fax Laser Printer
57 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
