Question about Philips DVDR3450H DVD Recorder/HDD Recorder
Philips DVDR3450H Recorder does not record all of timed programs
I have a Philips DVDR3450H DVD recorder. When setting to record from my digibox to the internal hard drive on the recorder, I occasionally get two faults:
- the recording starts late, so I miss the first part of the program
- the recording starts on time, but does not finish, so I get about 30 minutes of a 1-hour show.
Any thoughts?
  • 1 more comment
  • BigEyesNEars Mar 04, 2008
    My Philips DVDR3450H 160GB Hard Disk recorder is freezing up occasionally while playing a title from the hard disk. This usually happens after abt. 2 hours of playback.
  • CityBoy5705 Mar 15, 2008
    Thanks for comments. I had thought of PDC issue, and had eliminated it as a cause.
    To resolve issue, I uploaded latest software from www.philips.com/support . Issue has not recurred since I did this.
    Thanks again...
  • Anonymous Mar 28, 2014
    Blu-ray player is 2 years old , only used to record occasionally, & never had a problem before. Recently deleted ~19 recorded shows to make room for a show to record, I set the timer & all seemed well, but when I checked later if it had recorded I found the message no storage device lacated. I'm not sue what happened as now I can not even view the stored shows on hard drive - has my hard drive crash & if so what can I do about it?
  • 476 Answers
When setting the record timer make sure that PDC / VPS is switched OFF.
PDC - Programme Delivery Control / VPS - Video Programming System is designed to allow for late starting or running programmes. Not all channels support PDC/VPS, so the recorder may be waiting for a PDC/VPS signal which isn't there.
Posted on Feb 16, 2008
How can I reset DVDR3450H, somethimes no menu sometimes we cannot get disk out
I have a problem getting disks out of mine most of the time, afraid to say that lifting the machine at the front, about 1cm.....and dropping it, unsticks the drawer
Xo)
Sad but it works
Jul 30, 2011 | Philips DVDR3450H DVD Recorder/HDD...
I have a DVDR3450H dvd Recorder and it cannot open when i open there is a 'philips' sign on the lcd and do nothing after some seconds it seems it restarts with the philips sign again but doesnt work.. i...
Pull out the hdd and format it in a computer in one single partition NTFS. Put the hdd back and upgrade with the last file disponible on Philips and enjoy again your device. Success.
Jun 13, 2010 | Philips DVDR3450H DVD Recorder/HDD...
Philips DVDR3450H. How format the HD?
Found a document DVDR3450H_3452H_3460H_eurp FWUpgradewk635.pdf Describes procedure of firmware update and disc formatting. Some cut'n'paste from the document:
2. Preparations for new HDD
In the event when the set unable to boot up or recordings not stored due to an defective HDD, the HDD will have to be replaced with the steps describe below:
1. Replace the Faulty HDD with a new HDD.
2. Before connecting the new HDD on the Digital Board ,the jumper pin at the connector of the HDD is to be removed.
3. Connect the new HDD to the Digital Board.
4. Power up the set . It will open the tray and prompt to load the upgrading disc.(the upgrade disc is
the same disc under firmware upgrading.)
5. The set will display
“Load”.
6. Put the upgrade disc and close the tray and the set will show
“Copy” ……… “Boot”
7. The rest of the procedure follows the software upgrade given in 1B -Procedure to apply the firmware upgrade.
*Note : 1)Do not press any button or interrupt the main supply ,otherwise the set may
become defective.
2)When the HDD formatting is successful ,the set will go to standby mode.
Jan 17, 2010 | Philips DVDR3450H DVD Recorder/HDD...
Multiregional
Not possible - you have to get a disc type called "region all". You can find unlock codes on YouTube, but they only work 3 times on a Philips, and then you're stuck.
Aug 28, 2008 | Philips DVDR3450H DVD Recorder/HDD...
I have aDVDr3460H Recorder it will not copy to disk direct nor from hdd.
Reset, then call Philips to see what exchange options you have. laser reader most likely bad
Aug 24, 2008 | Philips DVDR3450H DVD Recorder/HDD...
DVD Recorder
double check the firmware from philips website, but most likely that hard drive has an internal problem
Picture/Sound freezes
This model does NOT work well with HD boxes. I would double-check the Philips website, and upgrade the firmware for device since all 3 players were doing same thing.
Aug 13, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Problem Recording HDD to DVD-R
I had a few problems with my philips 3450 - I downloaded the latest software upgrade at www.philips.com/support , and my issues were resolved. Worth a shot...
Only other thing I can think of is you may have a faulty batch of DVD-Rs?
Best of luck!
Jan 16, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Philips DVDR3450H
Put the DVD back into the drive...Then open the DVD menu by selecting the first tittle on the disc....Hold down the up arrow on the remote to make the "Editing menu" appear....Then select "Finalize Disc".
These instructions can be found on page 54 of the instruction book.
Dec 29, 2007 | Philips DVDR3450H DVD Recorder/HDD...
Philips DVDR3450H DVD Recorder/HDD Recorder Logo
242 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
