Question about Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher
DISHWASHER WONT FILL WITH WATER IF I PET WATER IN, IT DOES PUMP OUT BUT WILL NOT FILL?
  • milachkaa Feb 18, 2008
    My dishwasher will not fill up with water and sounds as if it is turned on. After about 5 minutes there is a burning smell and smoke starts to come out of the vents.
    Can you please tell me what the problem can be?
  • 2,039 Answers
There a valve at the bottom its round moved it up and dowm may be there some debrie in it it should make a clicling sound when moving it dont foget to rate this hope it work cheers
Posted on Jan 17, 2008
My dishwasher does not fill or empty?
wont fill
sounds like the water intake solenoid
wont pump out
could be timer control board
water pump /solenoid
Nov 10, 2016 | Dishwashers
Dishwasher wont fill up with water
When you start the dishwasher you have probably noticed that it first drains water and is very important to hear that drain pump running all the time or stops after a while? Why?
If the drain pump runs constantly then the fault is in the phase of "drain water" or is activated anti-flood system. Reset point of pressostat is not reached after max. 120secs. Programme stop and can be continued after error remedy by pressing the programme key.
If the pump is running for a while and then stops, then the fault is in phase "fill up water". Switchpoint of pressostat is not reached
after max. 60 secs.
Usually built-in dishwashers has anti-flood system that responds in the event of water in the bottom of the dishwasher. Such a case, find and repair water leaks.
Dado
Aug 06, 2014 | Electrolux 23 in. ESI6104 Built-in...
Dishwasher wont fill all the way up
You have to remove the bottom panel of the Dishwasher to get the problem solved. For More information please visit Ice Machine Cleaner.
Oct 04, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher won't fill with water
Check the power supply to the water pump through a pocket electrical line tester or volt meter.
Poer reaches and the pump mot rotating, check the capacitor associated with the motor.
May 27, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher wont fill with water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Sep 11, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
My neff dishwasher will not fill will water and will not complete program - cleaned and checked filters to the best of my knowledge - can you help?
i if it doesnt fill with water check it is actually draining is there water in the tub etc?if it cant drain it wont fill or complete the cycles,this is usually a blockage in the pump the handbook tells you how to deal with this problem.
Jul 29, 2009 | Neff 24 in. S5555X0GB Built-in Dishwasher
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Whirpool diswasher DU929PFGG2 wont draw water
The pump may be clogged or the motor start capacitor may be bad or the fill switch may be stuck or the timer may be bad. Fill the dishwasher by hand to just below the door level and close it then see if it will run. If it then runs correctly the problem may be the fill switch. If not, it could be the motor, the cap, or the timer
Nov 30, 2007 | Whirlpool 24 in. DU930PWP Built-in...
Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher Logo
151 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
