Question about Ricoh Aficio SP C811DN-DL Printer
Servicecall service call SC548. Need Help.
  • ludwig420 Dec 08, 2008
    How can the errorcode SC548 be reset ?
    Thanks.
On the copier:
press clearmode then 107 then hold clear/stop until a new screen comes up. then press Copy Sp, then type in 5810, then hit execute, then exit out of everything and turn it off for 30 seconds. If the error comes back up place a service call for the fuser.
Posted on Oct 06, 2008
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
Service call SC548
SC 548 - Fusing unit set error or fusing unit installation error,differ to copier models.Try reset by open/close the front door or enter in SP mode and turn ON/OFF the copier.
Mar 25, 2013 | Ricoh Office Equipment & Supplies
SC548 AND SC990
Sc548 can generally only be reset by entering service mode, and generally is caused by a defective thermistor (thermostat) in the fuser, and/ or power fluctuations. Sc990 is a software issue. I'd consider a new HDD> You'll need a tech for these problems.
Aug 13, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Cames on screen SC548
Hi.
I quote from manual:
SC548: Fusing unit installation error
- Definition -
The machine cannot detect the fusing unit when the front cover and right cover
are closed.
- Possible causes -
Fusing unit is not installed
Poor fusing unit connection
To reset try going in service mode and performing a reset.
To open service mode press [All Clear(yellow)] ,[1],[0],[7],[Clear(orange)]and keep holding down the clear button for about ten seconds.
When service mode starts, go to Copier Options , then choose mode 5, and option 810. Execute by pressing 1 and ok.
Do not change anything else in service mode, or you can cause more troubles.
If that does not clear the error , then there is a faulty part, in that case call service at the number listed in the user manual.
Jan 09, 2011 | Ricoh Aficio 1035 Copier
What is error code SC548 on RICOH Aficio 2035/2045 machine. Functional problem within the copier. How do i reset the copier to operate normal?
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
Jul 19, 2010 | Ricoh Aficio 2035 Copier
I have problem with my copier aficio 450,sc548 appear,please help me solve this error
SC548 is a fusing unit installation error. The machine can not detect the fusing unit for some reason. Did you have the fusing unit out of the machine? Like to remove a paper jam? In case you do not know the fusing unit is the part that gets hot. Located right before where the paper exits the copier. It comes out the front of the machine when you have the front door open. If the front door is open it is in the upper right corner and should have a blue knob on it. Make sure this unit is all the way in. You also may have a wiring or connector issue causing this as well.
You will have to enter the service mode to reset this code.
CAUTION: Do NOT mess with this service mode in any way other than the specific function I give you. Doing so could result in damage to your machine!
Enter SP (service mode) by pressing yellow C button, then press 1 0 7 on numeric keypad and then hold down the orange C button, display will change and then from the menu select "copy SP" then type in 5801 and press #, then press "execute". Turn power off and back on. If the code is gone and the machine works then your fine. If it comes back you will need to call a servicing company and have them repair the machine.
Good Luck and Thank You for using Fixya.
May 15, 2010 | Ricoh Aficio 450 Copier
Functional error SC548-00
- Definition -
The machine cannot detect the fusing unit when the front cover and right cover are closed.
- Possible causes -
• Fusing unit is not installed
• Poor fusing unit connection
Reinstall the fusing unit, ensure proper installation. You will need to enter the service mode in order to reset this error. Enter the service mode, then turn the machine off and then on via the MAIN power switch.
Dec 14, 2009 | Ricoh Aficio 450 Copier
What does Service code SC548 on a Lanier LD435c stand for
AMCAP VIDEO CAPTURE WILL NOT FUNCTIONPROPERLY
Aug 16, 2009 | Lanier UNKNOWN
Ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Jan 07, 2009 | Ricoh Aficio 450 Copier
Service Call SC548
fuser problem . danger . call tech
Dec 18, 2008 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio SP C811DN-DL Printer Logo
1,141 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
