Using the instructions below try
Cleanup first, if that doesn't work... (if you have a backup of all your music on your computer), try the
format option
This is from Creative's website:
Zen V Plus and Zen V
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the
Reset hole located below the power switch.
2. Press and hold the
Play button while powering on your player.
3. When the player displays the Creative logo, release the
Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the
Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot
Reboots the device.
Message Edited by Jason-CL on
09-11-2006 12:02 PM
Forum Administrator
Creative Labs
