Question about iLO 2600 Television
VOLUME WON'T WORK
I CAN'T CONTROL THE VOLUME ON ilo - 2600. HELP PLEASE
  • big truck Mar 12, 2008
    no audio in analog tv setting
    audio works with dvd player connected
    can not change audio setting off of mono
    Genius:
  • 1,139 Answers
Hello rapete,
This might denote a problem with the audio processor. First I would suggest you getting the following tools:
Audio signal tracer (can be gotten from Radio Shack) Audio signal generator (for signal injection) Oscilloscope (to view audio signal waveform) Multimeter (to check DC bias voltages on the processor) Schematic Diagram (to locate test points)
First I would suggest taking the oscilloscope and testing the wave forms at the audio test points denoted by the schematic diagram. This will let you know if audio is present under normal conditions.
If the above test does not produce results I would suggest that you then use the audio signal generator to inject sound into the circuit at the first audio amplifier stage then use the Oscilloscope or the signal tracer to check to see if the audio amplifier stages are working.
If the audio amplifier stages are working then the problem is going to be in the audio processor, if the test fails then you move to the next amplifier stages until you can detect the signal on the output or the next stage over. This will allow you to narrow down the trouble location.
If you don't feel like you can do these procedures, I would advise that you take the TV to a qualified TV repair facility.
I hope this helps, Thank you, Shuttle83
Posted on Jan 24, 2008
6ya staff
SOURCE:
I can't control the volume. The TV seems to be
Hi...
If the remote is lost the TV have also a control look at your TV side by side there is any button there you need to reads where is the Volume control
Regards
PCmania
Jul 08, 2009 | iLO 2600 Television
DishNetwork Remote won't program to control ilo EDTV
Hi, Hope this helps. I used code 720 for my dish remote to remote my ilo tv. It works great. Hope it works for you. Bob
Jan 11, 2009 | iLO 2600 Television
Code for my tv
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0145
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 11, 2008 | iLO 2600 Television
My 32in first was only stuck on high
you need a control board go to shopjimmy.com its a common problem but very easy to replace good luck
Apr 10, 2008 | iLO 2600 Television
Volume on tv not working
Try pressing the favorite button on the remote. "Favorite off" should display and the remote should work.
Dec 29, 2007 | iLO 2600 Television
ILO REMOTE PROBLEMS
main signal pcb bad.$150. from initial.
Nov 12, 2007 | iLO 2600 Television
Ilo 2600 remote control code
I finally found a direct tv remote code for my Ilo television. It was 10171. Others you can try that were for Direct TV remote: 10154 10236 10463 10180 10178 10019 10177 10623 10179
Sep 09, 2006 | iLO 2600 Television
Remote control
The correct model number is iLO2600.. That remote is available at http://www.remotes.com CHEAP!!
Sep 05, 2006 | iLO 2600 Television
Televison & Video Logo
105 people viewed this question
Top iLO Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
