Question about Denon AVR-3300 Receiver
Denon AVR-3300 remote
My 3300 remote will not function... only the ON SOURCE & OFF buttons are functioning as of now. The problem is resent and started when I was attempting to integrate a HD DVR (DIRECT TV unit) into my system. I couldn't get the audio opt 1-3 on the FUNCTION selection for TV / DBS to work but manage to work it through FUNCTION selection for DVD on opt 1.
I tried every button on the unit and the remote at some point during this rather frustrating scenario. Did I lock the remote up and if so, how do I unlock?
3 Suggested Answers
  • 74 Answers
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF] AVR-3300/1 3.3E*
Posted on Jul 22, 2009
  • 961 Answers
SOURCE: I just purchased a Sony
Your reciever has three digital optical inputs so, what it comes down to is how many thing do you want to hook up and what input/otput do you have on your TV. Best case scenario would be to hook your cable box directly to your TV Via HDMI out, if you have HD, on your cable box to Sat/cable input on your TV. Next best would be using componenet cables for video and digital optical for audio. Last would be RCA(yellow, white and red, from Cable box to TV input. Then, you would connect your TV to receiver via(best) digital optical, or RCA. You can try to patch the video through the reciever using component or RCA to TV/DBS on receiver then out to TV but. alot of times you will lose the video in the transfer and it uses more cables, thus more margiin for error. You would set your TV menu to cable/sat and your reciever to which ever input you choose.
Posted on Jul 03, 2011
Denon AVR-3200 wont go into standby mode
Not sure what you mean by standby mode. The power button on most of the audio remotes I deal with merely turns the equipment on and off.
Nov 24, 2013 | Denon AVR-3200 Receiver
On the left side above the function there will be a button named Source. Click on it and you can switch inputs with the roller.
Mar 03, 2011 | Denon AVR-3801 Receiver
How to access denon avr-3300 system setup
First make sure that your remote control is set to "Amp" as it can control many different devices.
Then make sure that you have connected the Monitor Out socket on the receiver to your TV.
Next make sure your TV is set to show the picture from the input you connected to the Denon monitor out.
Now press set-up button on the remote and the System Setup menu should appear on your TV.
If this helps then please rate my answer,
Many thanks,
Mar 02, 2011 | Denon AVR-3300 Receiver
Dear sir, The denon AVR 3300 receiver quits after playing a while; somtimes it quits after an hour,sometimes after 2 hours! Can you tell me how the sleep timer functions..... Thank you Cees van...
There is no sleep timer on the 3300. You are experiencing an "over heat" shut down. The 3300 is notorious for over heating at almost any volume level. It must be vented constantly with an external fan pulling air completely through the cabinet. Don't use it at all until you do this. The internal fan is week and will start to make noise from too much heat. Replacing the Denon fan will not solve this either. See my other posts about this issue.
Oct 03, 2010 | Denon AVR-3300 Receiver
No sound from new sony bravia to denon avr 1610
TV's are not your best source of audio. Get the TV-related audio digitally from the source, NOT the TV.
Jun 25, 2010 | Denon AVR-3300 Receiver
Go over here:
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
I had the same problem. Unfortunately Denon no longer mfgs. the remote for this receiver,
their solution is to offer a remote for a "similar" model. Problem is it doesn't work on all the
functions for the AVR-3802. My solution was to purchase an aftermarket universal remote
(Logitec Harmony 550 in my case}. The cost was a little less (approx. $90) vs. the price
quoted by Denon (somewhere around $120), and it works on all the functions.
I don't know if a budget priced remote (All-in-one, etc.) would be able to do th same.
There are several different programmable remotes on the market that should do the trick,
Logitec just happens to be one of them.
Good Luck
Mar 24, 2009 | Denon AVR-3802 Receiver
Denon RC-980 subsitute remote for Denon AVR-3200
I have a remote left over from my denon ACR3200. the remote is RC-825. It is currently listed on Ebay.
Dec 24, 2008 | Audio Players & Recorders
Denon AVR-1707 Receiver - remote stopped working
please apply a new fresh battery to it-confirm from right orientation(polarity)-try to apply a contact cleaner spray over the bad button and press it many times.-remove any thing between remote and receiver.-you can use universal remote and confirm befor you buy the new remote that it support your receiver.
Sep 21, 2007 | Denon AVR-1706 Receiver
Denon AVR-3300 Receiver Logo
389 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
